(PR) Corsair Launches the Multi Frame Pegboard for Platform:4 Desks
Corsair today launched the Multi Frame Pegboard for Platform:4, a smart vertical expansion that clears clutter off your desk and keeps gear within easy reach. Designed to attach seamlessly to the Platform:4 desk, this versatile add-on creates new space for storing, organizing, and displaying everything from streaming hardware to tools and collectibles.
Featuring two pegboards, three adjustable shelves, and 13 included hooks, the Multi Frame Pegboard is all about flexibility. Its sturdy aluminium 3060 T-channel rails follow a universal standard, supporting a wide range of aftermarket accessories. Included t-nuts and adapters make it easy to mount Elgato gear like the Key Light and Flex Arm, or even your own 3D-printed hardware. Horizontal and vertical rails allow hardware to be mounted exactly where it's needed, and shelves can be repositioned to match each user's setup.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Formally Launches Ryzen Threadripper PRO 9000 and Radeon AI PRO 90
AMD today formally launched a slew of new hardware for workstations. These include the new Ryzen Threadripper PRO 9000 "Shimada Peak" line of high core-count processors, and the Radeon AI PRO 9000 line of graphics cards that cover a range of use-cases spanning from edge AI acceleration to professional visualization. The Threadripper 9000 series is based on the "Zen 5" microarchitecture, and "Shimada Peak" is a variant of the "Turin" MCM powering 5th Gen EPYC processors, which comes with workstation-relevant I/O. Meanwhile, the Radeon AI Pro 9000 series is based on the same RDNA 4 graphics architecture powering the Radeon RX 9000 series gaming graphics cards.
The Ryzen Threadripper 9000 series comes with CPU core counts of up to 96-core/192-thread, with an IPC uplift from the "Zen 5" microarchitecture over the previous Threadripper 7000 series "Storm Peak" processors powered by "Zen 4." More than IPC, workstation users should benefit greatly from the architecture's full 512-bit FPU data-path, offering significant increases in performance of applications that leverage the AVX-512 instruction set. AMD also fine-tuned the IOD (I/O die) to support increased memory speeds of DDR5-6400 (native), AMD EXPO profiles, and CKD. With these changes, and minor increases in clock speeds for certain SKUs, AMD is promising a 16% uplift in performance over the Threadripper 7000 series predecessors in workstation benchmarks, and a significant 25% increase in SPEC Workstation AI and ML benchmarks (comparing identical core-counts and frequency).[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Lossless Scaling 3.1 Update Brings 2x Performance Increase and More Vi
The developer of the Lossless Scaling utility has released version 3.1, introducing both visual enhancements and significant performance improvements, up to 2x in "Performance Mode" depending on hardware and settings. Although there may be a slight dip in image fidelity, users with older graphics cards or integrated solutions will appreciate the ability to boost frame rates without lowering resolution. In addition to this new mode, the v3.1 update improves timestamp filtering for sharper details during rapid motion and refines border handling to eliminate jagged edges. Ghosting and object flicker have been reduced, and smarter interface detection keeps menus and heads‑up displays stable under scaling. Frame generation is powered by LSFG, while scaling options include LS1, AMD FidelityFX Super Resolution, NVIDIA Image Scaling, Integer Scaling, Nearest Neighbor, xBR, Anime4K, Sharp Bilinear and Bicubic CAS.
Version 3.1 also expands localization support to include Finnish, Georgian, Greek, Norwegian, Slovak, and even the constructed language Toki Pona, reflecting the tool's growing international audience. Developed and maintained by a single creator, Lossless Scaling competes directly with proprietary upscalers, such as NVIDIA DLSS and AMD FSR, without requiring dedicated machine-learning hardware and is offered at a one-time price of $6.99. Its built‑in algorithms are tailored to different content types: LS1 or AMD FSR is recommended for modern games, Integer Scaling or xBR works best for pixel‑art titles, and Anime4K excels with cartoons or anime. For optimal results, users should cap their game at a stable frame rate to provide the utility with sufficient resources to operate and run their titles in windowed mode on Windows 10 version 1903 or later.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) KDE Releases Plasma 6.4
A new version of Plasma is here, and it feels even more like /home, as it becomes smoother, friendlier and more helpful. Plasma 6.4 improves on nearly every front, with progress being made in accessibility, color rendering, tablet support, window management, and more. As this is going to be a long read, let's get right into it…
Window Management
Plasma already offers Virtual Desktops to help organize your windows and activities; and customizable Tiles you can stick windows to so they don't overlap, allowing you to see everything important at a glance.[Only registered and activated users can see links. Click Here To Register...]
Intel Arc "Battlemage" B770 GPU Support Lands in Popular AIDA64 Tool
More confirmations regarding the final release of the Intel Arc "Battlemage" B770 GPU have landed, this time with the update of the popular AIDA64 tool. Just days after support for BMG-G31 GPUs, supposedly the SKUs behind the higher-end B770 and B750 models, has landed in the [Only registered and activated users can see links. Click Here To Register...], diagnostic tools are next. In the latest AIDA64 beta version 7.99.7817, FinalWire has added an interesting "GPU information for Intel Battlemage (BMG-G31)" section as a feature update. This means that the tool can now officially recognize Intel's upcoming GPUs and allow users to perform diagnostics. Additionally, the tool also supports the now finalized PCI Express 7.0 controllers and devices, as PCI-SIG has ratified the [Only registered and activated users can see links. Click Here To Register...] of the PCIe Gen 7 standard.
With this confirmation, higher-end Intel Arc B770 and B750 GPUs are getting more credibility for an actual release. We expect to hear more about it in the coming weeks as the rumored Q4 launch nears. Earlier rumors suggest that Intel will pair 32 Xe2 cores for the B770 model with 16 GB of GDDR6 memory on a 256-bit bus. Will Intel satisfy the needs of Arc graphics gamers who have been waiting for a higher-end card remains to be seen. Drop your expectations in the comments, and let us know.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Gamdias Introduces New ATHENA P3 PC Case
GAMDIAS, a global leader in high-performance gaming hardware, proudly announces the launch of the ATHENA P3, a cutting-edge mid-tower chassis engineered for gamers and PC enthusiasts who demand uncompromising airflow and expansive hardware support. Continuing the legacy of the ATHENA series, the ATHENA P3 features a mesh-dominant front panel with dual solid bar accents, delivering both strong airflow performance and a bold, streamlined design. "Our design philosophy with the ATHENA P3 was to merge premium airflow with visual appeal and builder-friendly features," said Stimson Wang, CEO of GAMDIAS Technology. "This case reflects our pursuit of high-performance computing with seamless aesthetics and thoughtful design elements that elevate any gaming setup."
AIRFLOW-OPTIMIZED DESIGN WITH GAP BRIDGING BRACKET AND HIGH-PERFORMANCE FANS
Built for superior thermal performance, the ATHENA P3 is equipped with three 140 mm PWM ARGB intake fans at the front and a single 140 mm PWM ARGB exhaust fan at the rear, delivering optimized airflow straight out of the box. At the heart of its design is a gap-bridging front bracket, uniquely developed to seal airflow leaks between the mesh panel and the fan mounts—ensuring consistent, focused cooling efficiency. The case also includes a pre-installed 8-port PWM ARGB hub for streamlined control of fans and lighting through motherboard synchronization or the dedicated LED button. A seamless tempered glass side panel offers a clean, unobstructed view of your build, showcasing its cooling power and craftsmanship.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) NetEase Games Reveals the First AAA Single-Player Title - Blood M
NetEase Games and 24 Entertainment (Lin'an) Studio today unveiled Blood Message, a cinematic, single-player, linear story-driven action-adventure currently in development for PC and consoles. Powered by Unreal 5 Engine and enhanced with proprietary tools and technologies by the studio, Blood Message is NetEase Games' first AAA single-player title, blending brutal survival combat with profound Eastern storytelling.
Blood Message introduces a forgotten odyssey of loyalty and survival where players join Dunhuang's uprising, taking control of a nameless messenger and his young son in this immersive third-person action-adventure. Caught in the crossfire of a righteous uprising and driven by loyalty to both family and country, players will embark on a perilous eastward journey to deliver a message that holds the fate of their war-torn homeland. Amidst the shifting sands of history, they will etch a final tale of loyalty.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ASUS Republic of Gamers Announces ROG NUC (2025) Gaming Mini PC
ASUS Republic of Gamers today announced ROG NUC (2025), the world's first sub-three-liter gaming mini PC powered by Intel Core Ultra 9 processors (Series 2), supporting up to 96 GB of RAM and equipped with the latest NVIDIA GeForce RTX 5080 Laptop GPU. Designed to cater to gamers and creators, this compact powerhouse pushes the boundaries of power and portability, delivering up to 4X faster rendering performance compared to previous models and redefining the capabilities of a mini PC.
Unmatched performance
At the heart of the new ROG NUC (2025) is an Intel Core Ultra 9 275HX processor (Series 2), reaching boost speeds of up to 5.4 GHz and supporting up to 96 GB of high-speed DDR5-6400 MT memory. Engineered with 24-core hybrid architecture, an integrated NPU, and a powerful GPU, this cutting-edge processor ensures seamless real-time rendering and effortlessly handles the demanding gaming and creative workloads.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Humanoid Robots to Assemble NVIDIA's GB300 NVL72 "Blackwell Ultra"
NVIDIA's upcoming GB300 NVL72 "Blackwell Ultra" rack-scale systems are reportedly going to get a humanoid robot assembly, according to sources close to [Only registered and activated users can see links. Click Here To Register...]. As readers are aware, most of the traditional manufacturing processes in silicon manufacturing, PCB manufacturing, and server manufacturing are automated, requiring little to no human intervention. However, rack-scale systems required humans for final assembly up until now. It appears that Foxconn and NVIDIA have made plans to open up the first AI-powered humanoid robot assembly plant in Houston, Texas. The central plan is that, in the coming months as the plant is completed, humanoid robots will take over the final assembly process entirely removing humans from the manufacturing loop.
And this is not a bad thing. Since server assembly typically requires lifting heavy server racks throughout the day, the humanoid robot system will aid humans by doing the hard work, thereby saving workers from excessive labor. Initially, humans will oversee these robots in their operations, with fully autonomous factories expected later on. The human element here will primarily involve inspecting the work. NVIDIA has been laying the groundwork for humanoid robots for some time, as the company has developed NVIDIA Isaac, a comprehensive CUDA-accelerated platform designed for humanoid robots. As models from Agility Robotics, Boston Dynamics, Fourier, Foxlink, Galbot, Mentee Robotics, NEURA Robotics, General Robotics, Skild AI, and XPENG require models that are aware of their surroundings, NVIDIA created Isaac GR00T N1, the world's first open humanoid robot foundation model, available for anyone to use and finetune.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) OXS Announces New Storm A2 ANC Wireless Gaming Headset
OXS, a pioneer in gaming audio technology, today proudly unveils the launch of the A2 ANC Gaming Headset, a cutting-edge addition to the world of gaming accessories. Featuring a 40 mm neodymium driver and Xspace spatial audio technology, the A2 ANC seamlessly bridges the worlds of gaming, work, and everyday listening with immersive sound and unparalleled versatility. The OXS A2 ANC Wireless Gaming Headset is available from the OXS Website and Amazon US / Amazon UK in black and white colorways at MSRP $129.99 / £129.99
Precision-engineered for clarity, ultra-low latency, and adaptive noise cancellation, the Storm A2 enhances every aspect of audio engagement. Whether deep in battle or settling into a music session, less than 20 ms latency ensures fluid, responsive gameplay while advanced Active Noise Cancellation (ANC) eliminates distractions. When focus shifts, intuitive ANC ON and Passthrough modes adjust to changing environments—perfect for work, travel, or on-the-go listening.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Samsung Reportedly Achieves 70% Yields for Its 1c DRAM Technology
Samsung has achieved better production results for its advanced memory technology, according to Sedaily, as cited by TrendForce. The company's sixth-generation 10 nm DRAM, called 1c DRAM, now shows yield rates of 50-70% in testing. This represents a significant improvement from last year's results, which were below 30%. Samsung takes a different path from its rivals, while [Only registered and activated users can see links. Click Here To Register...] and [Only registered and activated users can see links. Click Here To Register...] stick with 1b DRAM technology for HBM4 products, Samsung opts to create the newer 1c DRAM. This choice comes with more risk; however, it might bring bigger rewards, as the improved production rates enable Samsung to expand its manufacturing operations. The company plans to increase 1c DRAM production at its Hwaseong and Pyeongtaek facilities with expansion activities expected to begin before the end of this year.
These developments also support Samsung's HBM4 production schedule since the company aims to begin mass production of HBM4 products later this year. Yet, experts in the field point out that the product is still in its early stages and needs ongoing monitoring. Samsung planned to begin mass-producing sixth-gen 10 nm DRAM by late 2024. Instead, the company chose to remake the chip's design. This decision caused delays of more than one year however it was made to achieve better performance and yields. The new DRAM products will be manufactured at Samsung's Pyeongtaek Line 4 facility as these chips will serve both mobile and server applications. Separately, [Only registered and activated users can see links. Click Here To Register...]-related production will take place at Pyeongtaek Line 3.[Only registered and activated users can see links. Click Here To Register...]
Intel's Core Ultra 7 265K and 265KF CPUs Dip Below $250
Intel's high-end "Arrow Lake" processors have just become significantly more affordable, with the Core Ultra 7 265K and 265KF now priced below $250 US at major American retailers. In recent weeks, Intel has officially reduced its suggested retail prices from $399 to $309 and from $384 to $294, and retailers have pushed the savings even further. Today, shoppers can pick up the unlocked Core Ultra 7 265K for $239.99 and the graphics-disabled 265KF for $229.99 at Micro Center, reflecting a roughly 40 percent discount off launch pricing. In addition to these cuts, Micro Center is bundling the 265K with an ASUS Z890 AYW Gaming Wi-Fi motherboard and a 32 GB G.Skill Ripjaws S5 DDR5-6000 memory kit for $499, saving buyers approximately $70 compared to purchasing the components separately. Newegg's deal includes a free 16 GB Patriot Viper Venom DDR5-6400 kit with the 265K, while Amazon's Spring Bundle features two full-price PC games, Dying Light: The Beast and Civilization VII, plus software licenses valued at $159.
Internationally, similar markdowns are appearing across Intel's Arrow Lake‑S lineup. In the UK, LambdaTek lists the Core Ultra 9 285 K at £481.18, the 265K at £234.04, and the 265KF at £230.97. The mid-range Core Ultra 5 245 K and 245KF both dip under £220. With their 20 cores and strong multithreaded performance, the Core Ultra 7 265K and 265KF now stand out in the sub‑$250 segment, especially when bundled with motherboards, memory, and games. Consumers should balance these productivity gains against expected Arrow Lake gaming results and keep an eye on AMD's upcoming 3D V‑Cache processors, which promise to intensify competition in the under‑$300 market later this year.[Only registered and activated users can see links. Click Here To Register...]
(PR) Cadence Launches Cache-Coherent HiFi 5s SMP for Next-Gen Audio Ap
Next-generation consumer and automotive audio is becoming increasingly sophisticated, and market drivers such as generative AI-based audio processing, immersive soundscapes, and advanced infotainment in software-defined vehicles demand stepped-up audio DSP performance. However, a single DSP can no longer meet escalating compute needs, while multiple DSPs pose significant programming challenges.
Today, OEMs and SoC vendors must perform all multicore hardware design and software development on their own while facing increased time-to-market pressures. At the same time, programmers are grappling with the complexity of software-based synchronization of shared memory regions and the proper partitioning of tasks across the multicore cluster. This can result in designs falling short of performance expectations.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Readies Ryzen 5 9600X3D to Spice Up the Mid-range
AMD is giving finishing touches to the Ryzen 5 9600X3D processor, which could improve the company's standing in the mid-range, against Intel's Core i5-14600K and Core Ultra 5 245K. This came to light when AMD inadvertently leaked the SKU in its processor support list for the recently launched Radeon AI R9700 graphics card. The Ryzen 5 9600X3D will likely be a 6-core/12-thread processor based on the "Granite Ridge" silicon with 3D V-Cache memory. The processor is based on the latest "Zen 5" microarchitecture.
3D V-Cache is 64 MB of stacked cache on top of the 32 MB on-die cache, for a total of 96 MB last-level cache. Clock speeds of the 9600X3D could end up similar to those of the 9600X, given that AMD has changed the way the L3D (3D V-Cache die) stacks with the CCD (CPU complex die), inverting them, such that the L3D serves as a base tile for the CCD on top, giving the 9600X3D similar thermal and overclocking characteristics to the regular 9600X. The introduction of 3D V-Cache could significantly improve the gaming performance of the 9600X3D over the 9600X, giving gamers in the sub-$300 processor market segment a compelling alternative to the i5-14600K and the 245K.[Only registered and activated users can see links. Click Here To Register...]
Logitech's Upcoming MX Master 4 Leaks
The first decent high-resolution images of Logitech's upcoming MX Master 4 mouse has leaked, courtesy of the EUIPO or European Union Intellectual Property Office, which is somewhat embarrassing when you consider that the EUIPO claims to protect your intellectual property. Anyhow, the mouse appears to have been given some major design updates, without straying too far from its predecessor. Most notably, it now has two buttons that cover the entire front of the mouse, which makes it look a lot cleaner than the MX Master 3s that has a bit of plastic on the right side of the right button. They also almost appear to be translucent, but that could just be the renders.
Gone are all the ridges on the thumb rest and read of the mouse and the thumb rest button appears to now be the entire side surface, rather than just the bottom of the thumb rest. It's unclear what the circle made up of dots is meant to symbolise though, but it appears that Logitech has come up with some new kind of functionality for the thumb rest button. A third thumb button has also been added in front of the previous two and the thumb scroll-wheel appears to be protruding rather than being slightly recessed as it is on the MX Master 3s. Finally there's an LED just behind the scroll-wheel lock button, which most likely is a battery/charge indicator. The MX Master 4 should be launching any time now, as the first leak was already a couple of weeks ago.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
