@zildan -- sarumina coane ! un bine public !
Hello to everybody, i'm italian, i would to know how can i enter in the cccam menù. I tried menù-cas-red button-2320 but it doesn't enter. Could someone help me please? Thanks
@samu
- download yours last version from here : [Only registered and activated users can see links. Click Here To Register...]
- put that on a FAT formated memory stick
- press the button in the right-down corner of the remote
- press BLUE
- select the file an press OK ...you will have the last FW version !
Then menu-cas-RED-2320 ...
- goto CAS and put Network server ON then exit
- will apppear Network and EMU Key
- goto network ->server setup ...
Thanks for your answer mihaip. When i check the Fw version i found this on my tv:
Optibox ALLIGATOR
VVPL016:09 25/01/2010
CC5-X F32 R256
ES4C1N0PX cjil 29/12/08
B04.21 R4.02K4.01
Is this the last one?
If yes i tried your suggestions but i can't find the cccam menù. Maybe something goes wrong. I press menù button, then go on Cas without enter on the only two options (network and cas), click on red button, then 2320 on the remote control).Nothing...it doesn't appear. When i go in Cas---> Cas, i don't have an options called Network server :(
Samu 6 stampa: MENU-Reset di fabbrica-Red Button-2320 e andrà nascondere il menu.
RULE 12
Devo fare reset di fabbrica?
Si Reset di fabbrica-Red Button-2320
RULE 12
Non funziona
mie mi se blocheaza sunetul la jiji cam la 15 min (uneori se deblocheaza singur da la maxim 1 ora tre sa fac ch+/ch- ca sa deblochez)
iar jsp sports face cum am zis ... in rest n-am mai avut linii sa vad cum merge cu noile setari cccam
@samu
16.09 is the actual version ! maybe is a good ideea to download yourself from the site ... reflash the STB !
- menu-CAS-RED ... ask for code : 2320
- the CAS menu will show EMU Key !!! that means the EMU system is active !
- enter CAS submenu ... then Network Server : ON and SAVE !
- exit CAS submenu and enter Network ... you'll see Server setup !!!
S-a gasit cauza primara ! urmeaza rezolvarea ...deocamdata o solutie pompieristica :
- menu-cas-RED-2320 ... dezactivati meniul EMU !
- toate abilitatile clientului CCCam ramin active !
astept ca si voi rezolvarea definitiva !
Cum se comporta Aligatorul in Terestru HD?
Colegul nostru , @Afaco , demn de toata increderea, zice ca bine ! din pacate la Cluj nu am semnal DVB-T !
un buna seara...mai intai si intai...
am dm500 clona...am dolce..am digi..si abia acum invat sa folosesc sharing...
deh...mi-a trebuit bataie de cap...la anii mei....
am comandat si un alligator....care tb sa vina:clap:
intrebarea este clara....cred...
SE MERITA???... caci dupa chinurile prin care treceti...pe mine ma trec toate apele.....:comp:
Pe terestru foarte bine chiar fara pene de sunet.In Bucuresti se vad perfect cele 3 posturi HD.
