Diabolic Parasite is an ESP32-S3-based USB dongle for penetration testing and security research. It supports...
NAS used to store your files in your local network for easy access, but new...
M5Stack CoreS3 Lite is a cost-optimized ESP32-S3-based IoT Vision AI controller providing a cheaper version...
Some high-performance RISC-V processors are in the pipeline for the rest of the year 2025,...
The Luckfox Lyra Pi is a compact, Raspberry Pi-sized SBC built around the Luckfox Core3506...
The Waveshare Core1121 is a compact, multi-band LoRa module based on the Semtech LR1121 transceiver...
Dream RF’s DreamHAT+ is a mmWave Radar HAT+ for the Raspberry Pi 4B and 5,...
The PD.Charger-GSM v2.5 is an industrial-grade solar and LiFePo4 charger/controller with MPPT support, designed for...
Render of the BME690 8x shuttle board Bosch Sensortech BME690 8x shuttle board is a...
Waveshare has recently introduced the L76K GPS HAT, a Raspberry Pi-compatible HAT that supports multiple...
Arduino has shrunk the UNO R4 with the Arduino Nano R4 board equipped with the...
The CDEBYTE EWD22S series is a set of LoRa-based remote control switches designed for long-range industrial...
The Raspberry Pi CM4-powered ALPON X4 was introduced last April, but SixFab has now upped...
The ESC3B04 is a compact DIN rail-compatible relay board built around the ESP32-C3 Super Mini...
The Unitree R1 is a cost-effective, ultra-lightweight, and customizable humanoid robot that stands 1.21m tall...
