GeForce RTX 5090 Power Excursions Tested: Can Spike to 901W Under 1ms
Igor's Lab conducted an in-depth analysis of the power management system of the new NVIDIA GeForce RTX 5090 graphics card, including the way the card draws peak power within the tolerances of the ATX 3.1 specification. This analysis should prove particularly useful for those still on older ATX v2.51 PSUs, and plan to use the included power adapter that converts four 8-pin PCIe power connectors to a 12V2x6. Igor's peak power analysis shows that the RTX 5090 is capable of excursions as high as 627.5 W for 10 ms to 20 ms durations; as high as 738.2 W in 5 ms to 10 ms durations, as high as 823.6 W in the 1 ms to 5 ms category, and as high as 901.1 W in spikes under 1 ms in duration.
An excursion is a brief increase in power draw beyond the continuous power delivery limit of the connector (600 W in case of the RTX 5090's single 12V2x6 input and adapter that converts four 150 W 8-pin PCIe inputs). There is nothing particularly alarming about these numbers, and the excursions part of Igor's analysis fall within the specification of the ATX 3.1 standard, which calls for excursions of up to 200% (1200 W) up to 1 ms. Any PSU meeting the ATX 3.1 specs that even has a continuous power output of less than 1200 W will be capable of handling these spikes. It's only with the much older generations of PSUs, such as ATX v2.51 (mid-2010s) that excursions can trigger OCP. Find other great insights in the Igor's Lab review linked below.[Only registered and activated users can see links. Click Here To Register...]
(PR) DOOM: The Dark Ages Requires RT. Release Date, PC System Requirem
The time draws near to Reign in Hell when DOOM: The Dark Ages releases May 15, 2025, on Game Pass, Xbox Series X|S, PlayStation 5 and PC. Preorder your copy today! For PC players, check that your setup is battle-ready by consulting our PC Requirements below, including listings for Minimum, Recommended and even Ultra 4K settings.
A NEW GENERATION OF IDTECH
id Software's most ambitious title yet, DOOM: The Dark Ages pushes new standards in visual fidelity and performance with the power of idTech8. Taking full advantage of modern hardware on all platforms, idTech8 ushers in a new era of gameplay performance and visual fidelity featuring all-new dynamic interactive ray-traced lighting and shadows, higher-fidelity image quality, increased gore and destruction and so much more. With the largest environments ever in a DOOM game, DOOM: The Dark Ages delivers an epic experience full of worlds to explore, hordes of demons to destroy and an action story worthy of the Slayer's legend. Whether soaring through the air with his dragon or smashing giant Titan-sized demons using his Atlan mech, the Slayer is taking on his biggest battles yet - all beautifully rendered and running at a buttery-smooth 60 frames per second on all platforms.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Cyberpunk 2077 Gets DLSS 4 Support With Patch 2.21. All RTX Users Can
CD Projekt RED has released the latest Patch 2.21 for Cyberpunk 2077, which is available for PC, PlayStation 5, and Xbox Series X/S. The new patch brings various fixes on all platforms, but also adds support for DLSS 4 with Multi Frame Generation for the NVIDIA GeForce RTX 50 Series graphics cards.
According to details provided in the release notes, the feature "boosts FPS by using AI to generate up to three times per traditionally rendered frame." It also introduces faster single Frame Generation which should bring reduced memory usage on RTX 50 and RTX 40 Series graphics cards. The patch also adds an option to choose between the CNN model or the new Transformer model for DLSS Ray Reconstruction, DLSS Super Resolution, and DLAA on all NVIDIA GeForce RTX graphics cards. According to CD Projekt RED, the new Transformer model should enhance stability, lighting, and detail in motion.[Only registered and activated users can see links. Click Here To Register...]
AMD Software Adrenalin Edition 25.1.1 Radeon Beta Driver Released
AMD has released its latest Adrenalin Edition 25.1.1 Radeon beta driver today, supporting additional gaming titles, improvements, and bug fixes. In this release, AMD has brought driver game support for the newly released FINAL FANTASY VII REBIRTH, released today, and Marvel's Spider-Man 2, which is finally coming to PCs after being console-exclusive for years. AMD has brought day-one support and has managed to fix some software issues along the way. First in line is the improvement in performance while playing Apex Legends with DirectX 12 API, which has been a pain point for AMD's drivers. Previously, some AI enthusiasts experienced lower-than-expected performance while using LM Studio on AMD Ryzen AI and Radeon products, which is now also fixed.
However, some issues persist. Users can experience a partial black screen problem in Marvel's Spider-Man 2 when using Radeon Anti-Lag 2 and Ray Tracing on AMD Ryzen 7000 series processors, intermittent crashes in FINAL FANTASY VII REBIRTH, driver timeouts in Warhammer 40,000: Space Marine 2, and performance stuttering in Marvel Rivals with AMD FidelityFX Super Resolution 3 frame generation. Additionally, users may encounter an intermittent AMD Bug Report Tool appearance after using the AMD Cleanup Utility and potential HEVC encoding issues with OBS Studio's Twitch-enhanced broadcasting, which will hopefully be fixed soon.
DOWNLOAD: [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
North American Retailer Leaks "March 23" Pre-order for AMD Radeon RX 9
B&H Photo Video—a Manhattan, NY-based electronics retailer—has leaked out a possible late March launch date for AMD's opening salvo of [Only registered and activated users can see links. Click Here To Register...] graphics cards. Four ASUS Radeon RX 9070 series SKUs are currently visible (via a search) on the shop's webstore—all listings sport a tag stating: "pre-order starts at 09:00 a.m ET, Sunday Mar 23." VideoCardz reckons that the product pages have been freshly updated—changing the previously listed date: January 23. [Only registered and activated users can see links. Click Here To Register...], Team Red has moved its [Only registered and activated users can see links. Click Here To Register...] and [Only registered and activated users can see links. Click Here To Register...] (non-XT) launch windows into March, but a specific date was not set.
B&H's listings could contain placeholder information—product launches and opening of pre-orders do not (under normal circumstances) occur over weekends. In this case, potentially on a Sunday. The New York City retailer has prepared very basic product pages for two TUF Gaming cards and two PRIME models—names and SKU codes appear to correspond with previous leaks. Artline, a Ukrainian PC hardware store, [Only registered and activated users can see links. Click Here To Register...] an [Only registered and activated users can see links. Click Here To Register...] package. MyGear took similar steps with a PRIME Radeon RX 9070 model.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Ubisoft Unveils Assassin's Creed Shadows Recommended PC Specs
Hi everyone, [Only registered and activated users can see links. Click Here To Register...] is launching March 20, inviting you to experience the intertwined stories of Naoe, an adept shinobi Assassin, and Yasuke, a powerful African samurai. Today, you can [Only registered and activated users can see links. Click Here To Register...] the game on console and PC, and [Only registered and activated users can see links. Click Here To Register...] on Shadows' upcoming expansion, Claws of Awaji, which brings 10 hours of additional content free with your pre-order.
For those of you playing on PC, we've got all of Assassin's Creed Shadows' recommended PC specs listed in [Only registered and activated users can see links. Click Here To Register...]. Assassin's Creed Shadows will support raytraced global illumination and reflections, and will feature an in-game benchmark tool for performance analysis, ultra-wide resolutions, an uncapped framerate, and more. Check out all the specs chart below.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Lost Records: Bloom & Rage Launch Info Revealed, Tape 2 Delayed
[Only registered and activated users can see links. Click Here To Register...] happy to give you a bit more info about the launch of [Only registered and activated users can see links. Click Here To Register...]! First, the price of the game will be 39,99€/$39.99/£35.89 when Tape 1 "Bloom" launches on February 18, 2025. This price includes both Tapes, so when Tape 2 launches on April 15 it will simply become an update that you can download which will allow you to play through the rest of the girls' story at your convenience. The game will also be launching with a limited-time discount of 10% until March 4!
You also might have noticed we've changed the date of Tape 2's launch - while Tape 1 is still on schedule, we're postponing the release of Tape 2 by four weeks, from March 18 to April 15, 2025. This game is very special to us, and we want to ensure that you get the experience you deserve while playing, with the extra time going towards additional optimization for a truly immersive continuation of the journey.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
UK Retailer to Limit GeForce RTX 5090 Pre-orders, Current Inventory in
Yesterday evening (GMT), Overclockers UK's product purchasing manager set expectations for his store's day one inventory of GeForce RTX 5090 and 5080 graphics cards. Taking to the [Only registered and activated users can see links. Click Here To Register...], Gibbo (aka Andrew Gibson) revealed that the flagship stock count was in: "single digits at present, maybe double for launch." His "TDLR" also pointed to the store having a "few hundred" RTX 5080 models ready for launch day, with pre-orders starting on January 30 (for both Blackwell GPU product tiers). Gibbo warned potential customers about anticipated tight conditions: "we are expecting greater demand than (the RTX) 40 series, but with the launch just prior to CNY and lots of [Only registered and activated users can see links. Click Here To Register...] initial waves of supply are poor and will probably take some time to build up. So the stock we have will be made available from the launch via the webshop, but I know what we have is likely to last only seconds, minutes at most."
Similar (predicted) circumstances have been reported across Europe and the Far East—certain outlets believe that GeForce RTX 50 series shortages will last up to [Only registered and activated users can see links. Click Here To Register...]. Potential "Blackwell" GPU customers are very likely dreading a forthcoming buying experience riddled with scalper bots, price gouging and all sorts of shady shenanigans. OCUK's product manager recommends taking a pragmatic approach when faced with a chaotic state of affairs: "to put it simply patience and expectations need to be realistic if the UK has—say 10,000 cards, and 500,000 people want one—well it is going to take time so plan ahead and also act like adults. I shall try and keep these forums updated with stock drops with heads up on the site etc. Do not call Sales or Customer service for any info or try to place orders, it shall be strictly [Only registered and activated users can see links. Click Here To Register...] and all information will be posted on forums and on product display pages for the products as and when we have it."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Geometric Future Launches Model 0: A Compact, Foldable PC Case Series
Geometric Future launched its Model 0 Flamingo "folding box" chassis series, half a year after it was showcased at the Computex 2024 Taipei Computer Show. The Model 0 Flamingo is a Mini-ITX chassis with a unique feature: it wraps around your system like a cardboard box. The chassis has a compact format measuring 81 × 206 × 208 mm with a volume of 3.47L. It is built from 1.2 mm thick steel plates coated with anti-static, fire-proof, and mildew-proof fabric in black color with touches of gold-like elements. For cooling, it relies on a giant mesh top circle and numerous ventilation holes. There is no room for additional fans, except it can host a 60 mm height CPU cooler. The chassis comes equipped with a compact custom Guitarra 200 W power supply manufactured by Quanhan that measures 70 × 35 × 170 mm.
As we said, the Geometric Future Model 0 unique feature is the ability to be folded without the need for any tools, with magnets included in the material of the case itself keeping it together. Additionally, detachable magnetic feet allow users to orient the case in both vertical and horizontal modes. However, as interesting as it looks, the Model 0 has some drawbacks: it is only compatible with ITX motherboards and does not support PCIe expansion (no graphics card can be added). Currently, there is no information about pricing. However, it should be around $100 if Geometric Future would like to attract SFF/HTPC users.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Sony to Stop Manufacturing Blu-ray Media, Effective February 2025
Sony Japan's Recording Media department has announced the retirement of several physical media formats—most notably Blu-Ray Disc—in a very [Only registered and activated users can see links. Click Here To Register...] addressed to "valued customers." Mid-last year, the Japanese multinational conglomerate revealed that it would [Only registered and activated users can see links. Click Here To Register...] (BD-RE and BD-R)—citing a decline in demand and the format's inability to meet "business goals." As pointed out by Tom's Hardware, today's announcement indicates (via machine translation) that both "regular and recorded" product lines are affected—the publication has reached out to Sony for comment/clarification.
Optical media enthusiasts/preservationists will, undoubtedly, be angered by this news—manufacturing activities will cease at some point next month. The corporation's message contains a lot of finality: "thank you for your continued patronage of Sony products. We will end production of all models of Blu-ray Disc media, MiniDiscs for recording, MD data for recording, and MiniDV cassettes as of February 2025. There will be no successor models. We would like to express our sincere gratitude to our many customers for their patronage to date."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) EXOK Games Cancels Earthblade Project
Hey everyone, I've got some sad news today to ring in 2025. Late last month, Noel and I made the difficult decision to cancel [Only registered and activated users can see links. Click Here To Register...]. Yes, we are opening the year with a huge, heartbreaking, and yet relieving failure. I want to outline in this post what lead to this decision, and what it means for the future of [Only registered and activated users can see links. Click Here To Register...].
Before I get into it however, I want to acknowledge that this news will likely come as a shock to fans who have been eagerly anticipating the game. We made this decision in December and felt it best to wait until now to announce it. For us on the inside we've had some time to process, grieve, and work toward accepting this, although that process is nonlinear and still ongoing. For those only reading this now who might be emotionally invested in this project, we're sorry to disappoint you.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Radeon RX 9070 Series Available Now According to Out-of-date Adver
PC hardware enthusiasts located in Germany, Poland and the United Kingdom have stumbled upon amusingly out-of-date AMD Radeon RX 9070 series GPU advertising. Earlier today, examples were [Only registered and activated users can see links. Click Here To Register...]—the social media-sourced announcements provide another look at Team Red's new reference design (Made-By-AMD/MBA) for the RDNA 4 generation, but the accompanying text (translated to English) implies that gamers can "play now" on not-yet-released [Only registered and activated users can see links. Click Here To Register...] GPU-based hardware. AMD has [Only registered and activated users can see links. Click Here To Register...] its launch of [Only registered and activated users can see links. Click Here To Register...] and [Only registered and activated users can see links. Click Here To Register...] (non-XT) cards into March, but older leaked information pointed to a possible January 23 (today) rollout.
This marketing campaign has seemingly kicked off prematurely—perhaps initiated by mistake. VideoCardz reached out to retail sources for comment—their report indicates that promotional material was ready to go, but embargoes are reportedly still in place. They reckon that a basic specification teaser could emerge online in the near future. Board partners have already distributed products across retail networks, and [Only registered and activated users can see links. Click Here To Register...] have been unboxed—today's advertised claim of "immediate availability" is no longer valid, but many folks hoped for a pre-January 30 kick-off. NVIDIA will be launching its GeForce RTX 50 series at the end of this month, but [Only registered and activated users can see links. Click Here To Register...] that things will not go smoothly.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Lenovo Unveils Affordable 2-in-1 Windows Tablet With 13.3-inch Display
We have witnessed quite a few affordable laptops hit shelves in the past few weeks, including offerings from Acer and ASUS. For those who are more interested in tablets but prefer a full-fledged Desktop OS will likely find the newly launched Lenovo S130 2-in-1 quite enticing, but there exists a major hurdle - the Lenovo S130 is China-only, for now at least. However, an international launch is not entirely out of the question.
At its core, the Lenovo S130 is powered by the Intel N100 processor. With four cores, four threads, and a maximum boost clock of 3.4 GHz, the 6-watt N100 is far from a powerhouse chip. That said, it should likely be enough for casual web-browsing and media consumption, but expecting anything more from the chip would be futile. The S130 does feature an impressive 13.3-inch display, with a resolution of 3000 x 2000 with a maximum brightness of 420 nits, making the S130 quite ideal for content consumption indeed.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Fuga: Melodies of Steel 3 Release Date Announced: May 29
⚙️Fuga: Melodies of Steel 3 coming May 29th, 2025! The new journey reaches for the sky! Fuga: Melodies of Steel 3 offers a new and exhilarating strategy-based battle system for its epic conclusion! Unveil the Source of the World's Despair! Check out the [Only registered and activated users can see links. Click Here To Register...] for details and future updates! Also, the game's [Only registered and activated users can see links. Click Here To Register...] is open! Add to your wishlist and follow for the latest info!
The Fuga: Melodies of Steel series has reached its epic conclusion! Dive into this dramatic RPG featuring a brand-new, strategic battle system, enhanced Taranis training during intermission, and tactical route progression and event battles! Unveil the Source of the World's Despair![Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Around 20,000 TSMC Wafers Reported Damaged by Earthquake
Earlier this week, Taiwan experienced a magnitude 6.4 earthquake—this seismic event [Only registered and activated users can see links. Click Here To Register...] at several TSMC chip-making facilities. As a precaution, foundry employees in both Central and Southern Taiwan were evacuated. Production resumed fairly quickly following inspections of crucial infrastructure—no major damage to facilities or equipment was noted. The latest reports suggest that a relatively minor number of TSMC wafers have been affected by the recent quake, while some recalibration of instrumentation is required to get things back on track.
Inside sources reckon that up to 20,000 wafers (possibly 10,000 at a minimum) could be scrapped—assessments are reportedly still underway, but a small proportion of client shipments could be disrupted. News articles point to this total being spread across three affected locations. Fab 18 is a key 3 nm production hub—situated in Taiwan's Southern Science Park, Tainan's Fab 14 specializes in 4 nm and 5 nm processes, and Fab 8 (Hsinchu) takes care of 200 nm. Industry experts believe that TSMC will bounce back quickly, and that the damaged wafer count represents a minor dent in the proverbial armor—on a good day, manufacturing output can reach up to 37,000 units.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
