Tarun’s BUG is a USB stick with a small display described as an “AI-powered Ethical...
We have received a review sample of an energy metering device from SeeedStudio called the...
We’ve seen x86 mini PCs for under $100 a few times, but I don’t think...
CrowPi 3 is a Raspberry Pi 5-powered all-in-one portable AI learning and development platform with...
Jetway PIC-ASL1 is a low-power, fanless Pico-ITX SBC built around the Intel Atom x7213RE or...
Another day, another ESP32-P4 RISC-V MCU board with the ESP32-P4-MINI equipped with an ESP32-C6 wireless...
STMicro’s STM32WBA5MMG is a tiny (12.5 x 8 mm), ultra-low-power 2.4 GHz wireless module based...
Valetron Systems VALTRACK-V4-VTS-ESP32-C3 (or Valtrack V4 for short) is a 4G LTE GPS vehicle tracker...
MicroSui (Sui Embedded Framework) is a lightweight, modular, open-source C framework that brings the Sui...
GigaDevice GD32C231 entry-level microcontroller is built around a 48 MHz Arm Cortex-M23 core with up...
Renesas RA2L2 is the world’s first low-power MCU to support the USB-C Revision 2.4 standard...
The Allwinner H135 is a 64-bit RISC-V multimedia SoC officially designed for low-cost projectors. However,...
“LILYGO MySondy GO LoRa32” is a small ESP32-PICO-D4 board with a 433 MHz LoRa module...
Pinefeat has designed an EF/EF-S lens controller and adapter for the Raspberry Pi HQ Camera,...
Designed by MuseLab, the nanoCH57x is a WCH CH570/CH572 development board with a 2.4 GHz...
