The FlippenHeimer is a compact Geiger counter add-on module designed to work with the Flipper...
Shuttle showcased a wide range of devices at Computex 2025, including the FTL1 IoT Edge...
Graperain GR3576_CV2 is a 260-pin SO-DIMM system-on-module (SoM) powered by a Rockchip RK3576 octa-core Cortex-A72/A53...
Infineon PSoC 4100T Plus is a new low-power Arm Cortex-M0+ MCU designed for battery-powered or...
Apacer PT25R-Pi HAT SSD is an upcoming HAT for the Raspberry Pi 5 or compatible...
The Arduino Nano Connector Carrier is a compact add-on board designed for the Arduino Nano...
Silicon Labs has just introduced the first 22nm Series 3 SoCs with the SiXG301 and...
Realtek showcased RTL8126, RTL8157, and RTL8251B 5 Gbps Ethernet solutions at Computex 2023, and the...
The PocketBeagle 2 was first introduced with a 1.0 GHz Texas Instruments Sitara AM6232 dual-core...
The Protectli Vault Pro VP2430 is a compact, Intel Processor N150-based fanless network appliance designed...
We’ve already had a look at the hardware of Chipsee’s 15.6-inch industrial touch panel PC...
Sipeed Tang Console is an FPGA development based on GOWIN GW5AST SoC FPGA with 138K...
The UV Meter is a Flipper Zero application designed to measure ultraviolet (UV) radiation using...
Forlinx FCU3501 is a fanless embedded computer powered by the Rockchip RK3588 SoC, or the...
It feels like everybody is now launching hardware based on the Rockchip RK3576 SoC, the...
