Rutronik Adapter Board RAB7 is an open-source hardware Arduino shield designed for AI-powered Sensor Fusion...
IVMECH Mechatronics’ PitFusion is a thermal imager designed for the Raspberry Pi based on a...
Once entry-level Intel processors have been on the market for long enough, we often start...
We all know that Arm Cortex-A are application cores, Cortex-M microcontroller-class cores, and Cortex-R real-time...
FutureProofHomes’ Satellite1 Dev Kit is a DIY voice assistant comprised of an ESP32-S3 WiFi and...
Elron ELTAY SC is a credit card-sized SBC powered by an Elvees SKIF “Scythian” quad-core...
Adafruit has recently released the Adafruit Sparkle Motion Stick, a compact, WLED-friendly Neopixel USB controller...
STMicroelectronics P-NUCLEO-IOD5A1 is a new modular IO-Link development kit designed to simplify building actuators and...
VIA AI Transforma Model 1 is an edge AI platform powered by a MediaTek Genio...
Radxa NIO 5A is an upcoming Mediatek Genio 520 SBC in credit card/Raspberry Pi form...
I’ve just received a review sample of Chipsee PPC-CM5-156 15.6-inch industrial panel PC that was...
Huawei Matebook Pro (HAD-W24 / HAD-W32) resembles a typical laptop with a 14.2-inch display, 24GB...
Renesas RZ/A3M is an Arm Cortex-A55 microprocessor (MPU) clocked at up to 1.0 GHz with...
Waveshare RA4M1-Zero is a mini development board built around the Renesas RA4M1 32-bit Arm Cortex-M4...
Boardcon has just introduced the LGA3576 system-on-module with a 330-pad LGA design powered by Rockchip...
