STMicroelectronics’ STM32MP21 microprocessor family combines a 1.5 GHz 64-bit Arm Cortex-A35 application core with a...
Espressif Systems is showcasing its products at CES 2026, including two interesting upcoming parts: the...
After announcing the high-end Snapdragon X2 Elite Extreme and X2 Elite processors last year, Qualcomm...
Broadcom has just announced the launch of its next-generation chips for Wi-Fi 8 access points...
Waveshare ESP32-S3-RLCD-4.2 is a 4.2-inch Reflective LCD (RLCD) development board built around ESP32-S3 wireless SoC...
We first noted the UltraRISC UR-DP1000-powered Milk-V Titan mini-ITX motherboard when we wrote an article...
Xibo digital signage solution is now compatible with the Raspberry Pi 5 thanks to Axeribo,...
The LILYGO T-Beam-1W is an ESP32-S3-based high-power LoRa development board featuring an SX1262 RF transceiver,...
At CES 2026, Sapphire Technology introduced the EDGE+VPR-7P132, an “AMD Embedded+” Mini-ITX motherboard built around...
Seeed Studio’s XIAO ePaper DIY Kit EE02 is an ESP32-S3 WiFi and Bluetooth board designed...
The Energy Meter for Home Assistant is an ESP32-S3-based single-phase energy monitoring and control module...
The Raspberry Pi AI HAT+ 2 is an add-on board based on the 40 TOPS...
The reComputer AI Industrial R2135-12. Hello, today I am going to review the reComputer AI...
WeAct CAN485 is a low-cost ESP32 board with CAN Bus and RS485 interfaces implemented through...
Jointly developed by Espressif Systems and Bosch Sensortec, the ESP-SensairShuttle kit comprises an ESP32-C5 development...
All SONOFF WiFi and Zigbee home automation devices can now work with the Matter protocol....
StackChan is an open-source AI desktop robot based on the M5Stack CoreS3 ESP32-S3 IoT controller...
Designed in collaboration with Morse Micro, GL.iNet’s HalowLink 2 is a Wi-Fi HaLow (802.11ah) access...
Compex Wi-Fi 7 Dual-Band Dual-Concurrent Modules are powered by Qualcomm ‘Waikiki’ series chipsets, delivering high...
Radxa NX4 is a 260-pin SO-DIMM SoM built around the Rockchip RK3576(J) octa-core Cortex-A72/A53 industrial...
