salut, incearca la [Only registered and activated users can see links. Click Here To Register...] .
Gemini2 v3.8:
Technical Infos:
* Engima from: 26.09.2008
* Busybox 1.0.1
* Tuxtxt 1.95
Function Buttons:
* BLUE - Blue Panel (BP)
* long BLUE -> PiP (DM7025)
* 2x BLUE - BP -> Extras/Settings
* RED - Record
* GREEN - Quickbutton / Subservices
* Yellow - Timeshift
Addons:
* Own Addon-Server via internet.
* Download and installation of additional features via internet from Gemini server.
* Use your own Personal addon server (configure it in /etc/useraddon.xml).
* Create your own Satellites.xml which only includes the satellites you need.
Camd:
* Assign different Camds to Stations/Providers (AutoCam).
* Change of the name and different functions over own menu.
Daemon / Server / Clients:
* Dreambox can be used as printserver (BP->Device Settings->Printer (LPD), FAQs in the database).
* Dropbear (ssh) now switchable (BP->Extras->SSH).
* Upnp Server / Client
* automount, examples in /etc/automount.conf. Devices, NFS or CIFS get automatically mounted. Ideally for DVD- or Net- Drives (Editor can be found at BP->Extras->Automount).
* Inadyn (Daemon for various DYNDNS-Services).
* little Apache (HTTP-Server based on HTTPD).
* NFS-Server (based on the NFS-Kernel-Modul).
* Editor to configure Cron-Deamon
Infobar / OSD:
* Provider and Satellite will be shown in the Infobar (depending on the skin).
* EMM, ECM or "ExpertInfos" Display switchable.
* Picon (displays the station logo)
* Show Onlinestatus when the Box is connected to the Internet (has to be activated in the BP -> Extras/Settings/Online)
* Spinner (response time now adjustable, 0 is off)
* Picons can be changed between Gemini and DMM format
* the position of the infobar can be changed
* HDTV-Logo in the Infobar (DM80..)
Files / Devices:
* Device Manager (format, mount and other functions)
* Support for CDROM/DVD no matter if it is IDE ur USB
* HDD- temperature and performance visible in the menu.
* HDPARM values for harddisks disk can be changed by menu.
* SWAP setup and start automatically.
* Hotplug for USB-Devices (are shown in the OSD - Can be mounted using the Device-Manager)
EPG:
* EPG-autosave- Saves the EPG data at a defined time
* additional EPG-Infos (BP -> Info)
* Duration of current Event in the programm overview ( BP -> Info -> EPG)
* EPG-Serch. Search by Title, description or own text.
Extra:
* Dreamnetcast (shoutcast-player) with Streamripper (direct reco***ng from server and coding into mp3s).
* Weather Plugin with 10 days forecast.
* RSS/RDF reader with TOP list from RSS-scout.
* Webcam-Viewer with FullScreen mode.
* Alarm clock(plays mp3s at a fixed time)
* System Info: Many extra receiver infos like stream-rates, kernel-, memory- and processinfos.
* Own Scripts can be started via Blue Panel.
* Kernel modules can be reload separately.
* Password can be changed by menu.
* EPG Cache and EPG Refresh (updates the EPG at the night) adjustable over BP.
* flashing clock when reco***ng in standby.
* Calendar for the iCalendar format + Reminder (supported by MAC, KDE, Thunderbird, Google calendar, Rainlendar…) , Standard-folder is /etc/ical.
* eTorrent - a torrent client based on ctorrent. Can be managed completly over the OSD
* eMail-Checker (Overview of your POP3 or IMAP accounts + SSL)
* overview of the different Scrambling systems that the current station uses.
* Quickbutton
* Turning of pictures, also automatically by EXIF data.
* "The GP2 Controlr" Firefox Extension to access functions of the Box.
* ReZapp, Switch back to a channel on a fixed time (BP-> Extra-> ReZapp)
* Summary of the HDTV-Channels in the Channellist->Satellites (DM80..)
New:
* HD-Skin preinstalled
* Many (partly internal) changes,that make it possible, to skin all menus completely
Fix + Updates:
* RSS-Reader
* Weather Plugin
* Mount overview now with icons
* see CVS
This Images doesn't contain any keys nor softcams.
Backups or other modified Images are not from us
and won't be supported!
Download via Database
Thanks a lot and have fun
Your Gemini-Team
NewNigma² release version 2.20
Data:
Enigma2: October 04, 2008.
Enigma2-Plugins: October 04, 2008.
Newnigma2-Plugins: October 04, 2008.
Newnigma2-Skins: October 04, 2008.
DVB-Modules: August 26, 2008.
Driver Informations:
DM500+: August 22, 2008.
DM600: August 22, 2008.
DM7025: October 01, 2008.
DM800: October 03, 2008.
Changes:
DM800 Secondstage #62 (only when flashing new image, not updating).
New ECM-Info.
Skins for the new ECM-Info can be self defined.
You can restart EMU’s using NewNimgma2-Menu.
HD-Picons for all usual satellites and cable providers available.
MKV-Video support over HDD or Stream. (DTS does not run)!
Smargo cardreader support on board.
Standard skin 7025: newnigma2skin_new.
Standard Skin 800: Kerni-HD1.
Standard Emu: Cccamd 2.0.9
Emu Updates
NewCS 1.6.1
NewCS 1.6.2
Any questions or ideas please join us at
irc://irc.swissirc.net:6667/#newnigma2
Have fun
NewNigma² Team
DL:
misto ca merg MKV-urile. pacat ca srt-urile nu merg (le vede dar degeaba...)
probabil ca prin imaginile viitoare dm-ul va deveni un multimediacenter complet...
Noua img newnigma2-image-dm800-v2.2.1.nfi suporta subtitrarile la digi film
DM800 = [Only registered and activated users can see links. Click Here To Register...]
confirm. si merg si srt-urile la mkv fara pb. ;)Quote:
Originally Posted by rom3o [Only registered and activated users can see links. Click Here To Register...]
OoZooN-CVS-full-dm800-20081102.nfi
• here is my latest CVS Image.
• Enigma is of 02.11.2008
• The plugins are of 02.11.2008
• The drivers are of 03.10.2008
• New kernel 2.6.12.6-r9
• Secondstage is 67
• Changes at Enigma2 can be pursued HERE
•This Image is available in two versions: Lean and Full.
•the lean is about 26,5 mb, the full is 42,2 mb.
•everything what's stripped in the lean, can installed via plugin-download and also deinstalled!
•the full-version contains all listed plugins and needed libs and is intended for all, who have their box not online of course are plugins and libs deinstallable if not needed.
•my changes at oe:
•own bootlogo's, artwork by clumsy
•with satellites.xml - enigma² by Reinh@rd
•additional kernelstuff: cdfs, ntfs, usbseriell, ftdi-sio und pl2303
•changes of dccamd start
•dccamd not included in image, can be installed via plugin download
•systemplugins:
•configurationbackup
•frontprocessorupgrade
•positionersetup
•satelliteequipmentcontrol
•satfinder
•skinselector
•softwareupdate
•hotplug
•videotune
•networkwizzard
•defaultservicescanner
•plugins:
•cutlisteditor
•filemanager
•graphmultiepg
•ipkginstaller
•mediaplayer
•mediascanner
•pictureplayer
•socketmmi
•antiscrollbar
•autotimer
•dyndns
•emailclient
•epgrefresh
•fritzcall
•httpproxy
•imdb
•ofdb
•lastfm
•logomanager
•movietagger
•netcaster
•simplerss
•startuptostandby
•trafficinfo
•vlcplayer
•webcamviewer
•webinterface
•werbezapper
•wirelesslan
•nfsserver
•aioscreengrabber
•tuxcom
•userscripts
•hddtemp
•mountmanager
•nfsedit
•moviecut
•movieretitle
•tageditor
•cdinfo
•download only plugins
•DVDBurn
•dccamd
•barryallen
•merlin-browser
•cronmanager
•orwell
•pauli
•renamemovie
•screensaver
•skintransp
•timeshiftsave
•wastebasket
•permanenttimeshift
•lcd skin
•spinnerselector
•iprec
•Skins:
•KerniHD1
•KerniHD1.picon
•dreamTV
•black-box
•cromline
•cromline.cobolt
•glassline
•shadowline
•avalon
•beyonddreams
•beyonddreams.simple
•x2-line
•merlin-racer
•blueline
•blueline.extended
•blueline.single
•flatline
•flatline.blue
•flatline.picon.blue
•flatline.picon.lava
•greenline
•greenline.extended
•greenline.single
•greyline
•greyline.3d
•greyline.extended
•greyline.single
•my changes at enigma:
•MHW epg active
•.recordings patch
•this image is updateble via plugins -> softwareupdate over internet!
•OE Build Configuration:
•BB_VERSION = "1.6.8"
•OE_REVISION = "format_version "1"
•new_manifest [0000000000000000000000000000000000000006]
•old_revision [8384ee468ef9c285a8c9b35ef333e53be78b6445]
•TARGET_ARCH = "mipsel"
•TARGET_OS = "linux"
•MACHINE = "dm800"
•DISTRO = "opendreambox"
•DISTRO_VERSION = "1.5.0"
•TARGET_FPU = "soft"
Download [url="http://rapidshare.com/files/160231095/OoZooN-CVS-full-dm800-20081102.nfi"]HERE
Am instalat si eu newnigma2 v2.2.1 si pot sa spun ca DM 800 se misca mai repede decat cu gp 3.80 sau cel putin asta este impresia mea. Nu am vazut insa satfinder-ul in meniu la cautare servicii. De unde pot sa-l descarc? Nu am prea avut timp sa caut. MultumescQuote:
Regula 12.
Cred ca butonul albastru , trebuie apasat mai indelugat,si apare un meniu newnigma service.Parca acolo am gasit.
Cum pot face upgrade de la newnigma 2.2 la newnigma 2.2.1 fara a instala din nou imaginea? La software update nu pot,pt.ca am incercat.
Util -setari motor h-h la receptorul H-H :
If your using DiSEqC 1.2 you will have to set-up the dish positions manually. If your usuing USALS it should be automatic.
Here's the USALS procedure from memory (someone please jump in and correct me if I've made any mistakes)
First make sure the dish is correctly aligned on a satellite, eg Astra 19.2
Press Menu -> Set Up -> Service Searching -> Tuner Configuration
Choose Tuner
ALPS BSBE2 (DVB-S2) - Press OK
Configuration Mode: Advanced
Satellite : Choose the satellite you want, eg Astra 19.2e
Voltage Mode: Polarization
Tone Mode: band
LNB : LNB 1
DiSEqC Mode: 1.2
Use USALS for this Sat: Yes
bafta .
autorestart dm 800 :
You can use Suomipoeka plugin,with that plugin you can fix the time when the dream800 should be the reebot.
Put on tmp/and install from blue panel.
pt plugins : [Only registered and activated users can see links. Click Here To Register...]
boxman-image-dm800-20081119
OE_REVISION = "<unknown>"
TARGET_OS = "linux"
MACHINE = "dm800"
TARGET_FPU = "soft"
Treiber vom 15.11.2008[Only registered and activated users can see links. Click Here To Register...]
SecondStage-BootLoader-Ver: 67
satellites.xml - enigma² by Reinh@rd vom 16.11.2008
news : email primit de la IHAD
GEMINI 3.9
Hello xxxxxxxx ,
The waiting (finally) comes to an end. At the coming weekend we will release our new Gemini 3.9 for all Enigma2 Boxes.
YES - for all, DM8000 included!
New:
* customization for the 8000, partly internal
* Jukebox, Soundplayer supports MP3, OGG, FLAC and WAV. With Playlist-organizer and display of the cover. It's insignificant where the image is placed (Soundfile or in the same folder) It's still beta, same new functions will be added with the next image...
Fix + Updates:
* RSS reader with title images and new XML
* Webcam-Viewer cataloged in sub folders and new XML
* folder for Autofs changed. (customization at DMM's Autofs-System). New folder is "/autofs", config-file is "/etc/auto.hotplug". Editor in the BP can be used further on.
* Network Hardware added to the Devices Manager
* see CVS
Don't miss the release, have a look in the IHAD.
Your Gemini-Team
cccam.cfg ,gbox.cfg , cwshare , newcs.xml , mbox.cfg etc
UPDATE 29.11.2008
Quickedit 0.8a
- added more config files edit possibility
- add a save dialog, so yo can edit save adn then choose upload or save on own location
- added in profiles to configure every single location of implemented config files
- added restore
- backup still only for cccam
- fix some errors
Foloseste cineva combinatia dm800/8000 si cardul de nagra 3?
Am o problema legata de o clona dm800 am instalat demai multe ori image gp 4.3, gp 4.4 ,nabilo blackhole toate patch-uite dar am aceasi problema care ma inebuneste:telecomanda nu functioneaza normal,de ex cand apas tasta albastra nu-mi da blue panel ci intra in lista de canale care am avuto ultima oara pe ecran,deasemenea cand apas liniuta jos si apoi albastru nu-mi da lista de buchete ci sare in urmatoarea lista din ce am avut selectat mai devreme de xe daca eram in provedor RCS ma trimite direct in lista urmatorului provedoor,nu inteleg care e problema ,am cumparat 3 astfel de dm800 toate au venit cu gp 4.4 instalat ,cand am pus settings pe ele doar la doua a functionat comenzile ok,apoi dupa o butare si la al doilea a aparut aceasi probl,am in trat in meniu-setup-customize-setupmode expert-enable multiple bouquets yes salvat cu verde si degeaba,am spus ca orice image am scris pe el si ftp si cu serialul tot la fel merg,nu mai stiu ce sa le fac
