Eu ti-am spus cum functioneaza e2, probabil ca ai 2 file diferite in imagine !
Mai invatza despre e2 si apoi o sa rezolvi.
am incercat toate img posibile,cea mai stabila este pkt nebula,cred ca este facuta ptru spark reloaded dar merge perfect pe alien 8900!
am mers mult timp pe rsp dar ma dispera green scren!
ProtoLux v.5 vom NF-EOS-Dev-Team fur GM 990 und reloaded
- EOS panel to Protolux V4 greatly expanded and improved
- WebIf ver 1.7.1
- Videowizzard on V.Format
(Tested drivers: rt3070, rt2870, rt5370, rtl8187, 8712u) wireless support -
- RC selection: Pingu RC1, RC2 Pingu, Pingu RC1 +2, GM Triplex, Amiko Alien (untested), Pingulux Plus, Standard
- Receiver switchable display
- Audio-eleven to for switching from normal DTS
- Overclocking
- Red LED set for Deepstandby
- Direct switching to Spark Soft
- Backup out of the Spark software from E2
- Faster backup
- Boot volume adjustable
- Samba
- PEARL USB Display support (pre-configured)
- All screenshots on WebIF are supported (except in HD channels, only possible OSD)
- Webif Bouquet Editor in NF-Design
- DLNA media server (experimental)
Note: Settings via minidlna menu under System> Preferences> minidlna, start by PPanel
- 2nd WebIF
- Pingulux Plus display support
- Pluginnavibar
- Select Boot Logo or Video
- Various backup options
- Teletext Speedup
- NT mounts mount only Ppanel for Lasting
- Sleep timer fixed
- Full language support (as far as we can tell, dehalb is not entitled to correct is what da)
Keys:
V-format = Video Wizard
Time = Time and Channel Display (with Time again be switched off)
Find = tuning
Tms = Record Set Path
USB = Dream Explorer
Blue = PPanel
F1 + Blue = Display Switching (clock, transmitter, and from standby clock out)
F1 + Red = Reboot
F1 +1 = Mcas start
F1 +2 = Oscam start
F1 +3 = Mgcamd start
F1 +4 = Camd3 start
F1 +5 = start Incubus
F1 +6 = Vizcam start
F1 +7 = NewCS and Camd3 start
F1 +8 = Oscam and Mgcamd start
F1 +0 = All Stop Emus
Known Bugs:
- HD recordings on sticks can cause problems on ext3 HDD No problems found.
- Set the First Boot no wifi then skip better network settings
- Are DLNA stop before Guirestart or format e otherwise it tuner problems and it needs to be rebooted
Se misca un pic cam greoi prin meniuri , nu recunoaste telecomanda de Alien ( la mine nu a mers ) dar se poate face sa mearga ... imaginea merita testata pentru ca are o groaza de noutati .
---------- Post added at 22:02 ---------- Previous post was at 21:18 ----------
Am modificat un pic keymap.xml sa se potriveasca cat de cat si telecomanda de Alien ... mai este mult de munca sa se potriveasca 100% dar este un inceput pentru cine doreste sa testeze .
Fisierul keymap.xml il gasim in
se descarca arhiva de mai sus se dezarhiveaza ... se face backup la keymap.xml existent si apoi se inlocuieste cu cel din arhiva de mai sus apoi se inlocuieste si fisierul evremote2 pe care il gasim in /bin cu fisierul din arhiva evremote2 de mai sus si se da un reboot .Code:/usr/local/share/enigma2
bafta
---------- Post added at 22:48 ---------- Previous post was at 22:02 ----------
Nu sunt sigur , sper sa nu fi setat eu din greseala , dar am impresia ca imaginea vine cu procesorul setat la 600 MHz ... este o frecventa cam mare . Cine instaleaza va rog sa dati din telnet comanda cat /proc/cpuinfo si sa postati aici rezultatul .
---------- Post added at 23:45 ---------- Previous post was at 22:48 ----------
In urma unei setari imaginea s-a blocat si a trebuit sa reinstalez deci imaginea vine default cu frecventa la procesor setata la 600 mhz iar fara o racire fortata exista posibilitatea sa se prajeasca procesorul. Daca nu vreti sa riscati va recomand sa accesati web-panelul la adresa ip_alien:8080 si de acolo din meniul Overclocking la CPU Frequency setati 450(default) si apoi dati Senden
Din pacate si aceasta imagine prezinta acel tremur pe anumite canale HD , incep sa cred ca atata poate receptorul iar cine doreste mai mult trebuie sa se orienteze catre alte receptoare care au un suport software mai diversificat. Zapping-ul este un pic cam lent dar la cat de incarcata este imagine este scuzabil in rest este o imagine care arata bine si plina de noutati care abia asteapta sa fie descoperite si testate.
root@spark:~# cat /proc/cpu
machine : STx7111 M
processor : 0
cpu family : sh4
cpu type : STx7111
cut : 3.x
cpu flags : fpu icbi
cache type : split (ha
icache size : 32KiB (2-
dcache size : 32KiB (2-
address sizes : 32 bits p
bogomips : 447.00
root@spark:~#
PPanel-Spezialfutionen-Overclocking-Menu .......450MHz
Problema mare este ca imaginea vine default cu procesorul tractat la 600mhz iar fara o racire adecvata un user neinitiat poate praji foarte usor procesorul .
NU e din procesor problema tremuratului, e din player 191, ar cam fi cazul sa apara o versiune mai noua (asta e din 2010).
Canalele pe care se manifesta tremuratul nu sunt interesante pentru cei ce sapa la baza imaginii si ca atare nu exista interes pentru rezolvarea problemei , daca problema se manifesta pe canalele SKY DE cu siguranta se rezolva extrem de rapid .
Singura care nu are problema tremuratului e aia de la croaţi HRnigma 1.4 aia final edition numită şi HRnigma 2 parcă.
Adică asta 1.0.4. 2012-HR-14
E pe stm23.
Zildan dacă găseşti care e player-ul şi il putem extrage din asta am scăpat de stuttering. Da-mi te rog un pm dacă reusesti să faci o imag de test fără prob asta, pană scoti imag finală, bineinţeles dacă mai faci imagini.
Sent from my HTC Desire S using Tapatalk 2
Toate imaginile au tremuratul pentru ca toate provin din acelasi GIT si mostenesc aceleasi probleme ... diferenta este facuta de floricele.
Atunci fa-ma sa inteleg la mine dece nu tremura....
E singura care nu face treaba asta si cred ca nu face asta numai la mine si numai asta....
Incearca si zi-mi dupaia....
Serios vorbesc ca e singura fara stuttering si merge deja de un an si ceva pe orice canale cu SR mare, si crede-ma ca pe Discovery sau History ma uit mult....
Nu putem sa ne intoarcem la stm23 pentru ca dezvoltarea pe DUCKBOX GIT e concentrata pe stm24 209 --- 211.
Imaginile de test noi (pe care multi dintre voi le-atzi primit) sunt pe stm24 211.
Eram aproape gata in finalul lui decembrie sa publicam una da ne-am luat cu febra sarbatorilor.
Am rezolvat intre timp aproape 100% blocarea pe italieni (era cam singurul operator pe care mai erau probleme) si partial si problema tremuratului.
Poate mai "inghesuie" astia canalele pe 1W si se rezolva pe alta cale si tremuratul. Doar un transponder mai are probleme la ora asta.
Daca ar fi mai multi voluntari in dezvoltarea imaginilor s-ar misca mai iute treaba.
Zildan io stiu ca ar fi un pas in spate dar macar ar fi una care merge, ca aia e de acum veche si suportul de download skin, plugin..... nu mai este. Pare a fi un ARP modificat de ei.
Poate aflam si dece la aia merge (cumva), poate poate...
Sent from my Nexus 7 using Tapatalk 2
Salut,
Se poate rezolva problema cu sunetul AAC-HE ? Sau exista vreo imagine enigma 2 care poate reda sunetul AAC-HE ?
Folosesc HDMU pentru Alien 1 si pe SKY NEWS HD (28.5E) sunetul nu merge, formatul fiind AAC-HE.
Sau poate vreun plugin/driver de instalat.
Multumesc.
Am pus imaginea HDMU (ultima versiune) pe un Alien2.
Stiind ca se munceste mult la elaborarea ei am fost total neplacut sa constat ca e are foarte mult addons dar per total, din punct de vedere al pasionatului de sateliti e departe de ce ma asteptam.
Eu nu am mai folosit Spark sau alte imagini de 2 ani pe Alien1. Azi am constatat ca ultimele beta de la RSP sunt cu mult mai bune decat "concurenta" si m-a surprins placut imaginea Spark. Apropo de cei care ziceau ca nu merge oscamu RSP pe Spark, dati un reboot si va merge!
Ce nu mi-a placut la HDMU e varza!
Multe lucruri adunate (unele utile alte complet afara) .
Ce mi-a placut e ca au muncit mult. Au ajutat si ei la pasul inainte la e2 pe SH40.
Spark e la ora asta cu cateva clase inaintea E2.
Ce ii lipseste:
- Alt mod de gestionare canele (preferate)
- Un plugins de ECM info.
- Stabilitatea
- Player de filme din retea !!!!! Asta e cea mai mare buba!
Spark2 nu e mai iute decat Spark1, daca va trebuie PIP si tunner de cablu sau terestru e insa o solutie.
E un mare pas inainte al celor de la FULAN.
