Changeset #3904
Message: cccam: fixed small cardupdate bug
Changeset #3904
r3905 | schlocke | 2010-11-14 13:06:43 -0800 (Sun, 14 Nov 2010) | 2 lines
cccam: filtered duplicate cards
r3904 | schlocke | 2010-11-14 09:33:34 -0800 (Sun, 14 Nov 2010) | 2 lines
Changeset #3906
Message: cccam: Blocking user if cccam-backdoor commands detected
Changeset #3907
Message: cccam: fixed increasing hop on duplicate card filtering
cccam: fixed too many connects/running out of sockets: blocking
connections by time
Changeset #3908
Message: csctapi/ifd_sci.c : added a 80ms delay after card reset before we try to read the ATR.
r3912 | alno | 2010-11-16 16:03:51 -0800 (Tue, 16 Nov 2010) | 1 line
remove debug output
r3911 | alno | 2010-11-16 16:01:22 -0800 (Tue, 16 Nov 2010) | 1 line
fix typo
r3910 | alno | 2010-11-16 16:00:21 -0800 (Tue, 16 Nov 2010) | 1 line
WebIf: add re-read for 'oscam.dvbapi' on saving in FILES section of webIf. So after saving new filters are active. THX @ _network for preparation
r3909 | _network | 2010-11-16 15:02:53 -0800 (Tue, 16 Nov 2010) | 2 lines
dvbapi: prepare rereading of oscam.dvbapi
r3913 | rorothetroll | 2010-11-16 19:48:58 -0800 (Tue, 16 Nov 2010) | 1 line
csctapi/ifd_smartreader.c: small change to test T1 fixes. As T1 card don't work for now this shouldn't break anything. I made sure German S02 still init properly.
r3914 | schlocke | 2010-11-16 23:15:16 -0800 (Tue, 16 Nov 2010) | 2 lines
"cannot create pipe" error now does not exit oscam
r3913 | rorothetroll | 2010-11-16 19:48:58 -0800 (Tue, 16 Nov 2010) | 2 lines
te rog sa pastrezi modelul de postare pentru oscam fileQuote:
Changeset [3915] by schlocke
fixed resetting connection blocking time, max blocking time is now 1min
Changeset #3916
Message: cccam: new parameter "cc_keepconnected" [0|1] default=1. 1=clients are
not connected after maxidleclient, 0=clients disconnected afer
maxidleclient
Changeset #3917
Message: Documentation for new parameter 'keepconnected' in 'cccam' section.
Changeset #3918
Message: increase delay between reset and ATR read for PPC box
Changeset #3919
Message: Documentation for 'usrfileflag' parameter.
r3925 | schlocke | 2010-11-18 04:31:03 -0800 (Thu, 18 Nov 2010) | 2 lines
cccam: added 2.2.0 functionality, added webif support 2.2.0
r3924 | cogsi | 2010-11-18 02:58:41 -0800 (Thu, 18 Nov 2010) | 1 line
cccam: update good/bad sid lists on cmd0f
Changeset #3926
Message: Fix for #1244 (thanks to schwa226)
r3928 | schlocke | 2010-11-18 14:49:42 -0800 (Thu, 18 Nov 2010) | 2 lines
cccam: added ident filter from users-ident (before only reader-ident)
r3927 | schlocke | 2010-11-18 13:02:26 -0800 (Thu, 18 Nov 2010) | 3 lines
cccam: removed attacking information, CMD_0C/0D/0E are client fake
checks
oscam 1.00 -svn3928-full-Distribution ------------------------------------------------------------------------ r3928 | schlocke | 2010-11-18 14:49:42 -0800 (Thu, 18 Nov 2010) | 2 lines cccam: added ident filter from users-ident (before only reader-ident) ------------------------------------------------------------------------ r3927 | schlocke | 2010-11-18 13:02:26 -0800 (Thu, 18 Nov 2010) | 3 lines cccam: removed attacking information, CMD_0C/0D/0E are client fake checks ------------------------------------------------------------------------ r3926 | cogsi | 2010-11-18 07:57:10 -0800 (Thu, 18 Nov 2010) | 1 line Fix for #1244 (thanks to schwa226) ------------------------------------------------------------------------ [Only registered and activated users can see links. Click Here To Register...]
