Seeed Studio has launched two new ePaper display DIY Kits: the XIAO ePaper DIY Kit-EN04...
Seeed Studio’s Amazing Hand is an open-source, 3D-printable robotic hand kit with eight degrees of...
Advantech SOM-6820 is a COM Express Type 6 Compact Computer-on-Module powered by a Qualcomm Snapdragon...
Cesanta Software introduced Mongoose Wizard – a no-code visual tool that enables embedded developers to...
Last October, Raspberry Pi had to increase the price of its CM4/CM5 Compute Modules due...
NetCube Systems Nagami is a small Allwinner T113-S3 system-on-module that I just saw added to...
Developed by Hungary-based AQEX, qUPS-P-BC-2.0 is a Raspberry Pi-compatible UPS HAT that supports multi-chemistry batteries,...
Olimex ESP32-C6-DevKit-Lipo board is a small open-source hardware board based on the ESP32-C6 WiFi 6,...
When 3D printing, users will always waste filament one way or the other, either due...
Rikomagic DS08 is a Rockchip RK3588-powered Android 13 digital signage player with 8K and 4K...
Edgi-Talk is a machine learning platform/development kit powered by an Infineon PSOC Edge E84 Arm...
I’ve just received a review sample of the JOYROOM PODIX 140W 5-port USB GaN charger,...
Olimex MIPI-HDMI adapter board is built around Lontium Semiconductors’ LT8912B MIPI DSI to HDMI bridge...
Jetway B420UADN1 is a compact Intel N97 fanless mini PC designed for kiosks and digital...
Four pairs of 18650 batteriesThe 52Pi UPS Gen 6 is another UPS solution for the...
Beacon EmbeddedWorks has announced a compact (38x28mm) System-on-Module (SoM) based on the recently introduced low-power...
Waveshare RPi-Zero-PhotoPainter-ACCE is a 7.3-inch color e-paper photo frame designed for the Raspberry Pi Zero...
FlashESP is a web-based tool allowing the development of Arduino sketches and firmware flashing for...
The Radxa C200 is a compact developer kit built around the NVIDIA Jetson Orin NX...
Youyeetoo NestDisk in an Intel N150 mini PC that can be used as a mini...
