Seeed Studio XIAO Debug Mate is an inexpensive ESP32-S3-based multi-tool designed for the company’s XIAO...
The UltraBar X is a modular desktop command center/smart-hub built around an ultra-wide “CoreBar” touch display...
Banana Pi BPI-CM6 fitted to the CM6-IO carrier boardBanana Pi BPI-CM6 system-on-module (SoM) is powered...
While searching AliExpress, I found the WiFi LoRa 32 (V4) shell set, another ESP32-S3-based off-grid...
The FORTEC Group’s SBCPRO-X51 is a 3.5-inch industrial, fanless SBC powered by Intel Atom x7211RE...
AMD’s SCU35 Evaluation Kit is an affordable ($229) development board powered by the AMD Spartan...
ST ST25DA-C is an NFC chip with built-in support for the latest Matter 1.5 protocol,...
Earlier this month, we checked the specifications and did an unboxing of the Sermoon S1...
Waveshare has launched a low-cost LG290P breakout board priced at about half the competing options....
Linus Torvalds has just announced the release of Linux 6.18 on the Linux Kernel Mailing...
Waveshare PCIe TO 2.5G ETH Board (C) low-cost PCIe x1 adapter adds a 2.5GbE port...
SMLight’s SMHUB Nano Mg24 may look like the company’s earlier SLZB-06p Zigbee to Ethernet/WiFi/USB coordinators, but...
The DFRobot LoRaWAN Control Terminal is a compact, DIN-rail mountable industrial IIoT terminal that features...
Chen Liang (陳亮) has found an interesting use case for the Espressif ESP32-C5: a dual-band...
AAEON COM-ARHC6 is a COM Express Type 6 Compact module powered by a choice of...
MetaComputing, a Switzerland-based company founded in 2024, has announced the “MetaComputing AI PC with Framework...
Silicognition ManT1S is an ESP32 board with a 4-pole terminal block for T1S single-pair Ethernet...
Nordic Semi has unveiled a new member of the nRF54L series: the nRF54LV10A ultra-low-power, low-voltage...
One interesting addition to the just-released Linux 6.18 kernel is the Tyr Rust GPU driver...
As the holiday season approaches, PCBWay is thrilled to announce their Christmas Promotions! If you’ve...
