r3882 | rorothetroll | 2010-11-11 09:36:55 -0800 (Thu, 11 Nov 2010) | 3 lines
reader-viaccess.c : added some extra test in case we don't get an ecm number form the card but still get long ecm.
r3881 | alno | 2010-11-11 06:47:24 -0800 (Thu, 11 Nov 2010) | 1 line
WebIf: remove 'cccam ext' from form parameters - not valid
Oscam-1.00-svn3884
Changeset #3883
Message: reader-viaccess.c : fix problem with last_geo ecm number. Thanks GoodSat.
Changeset #3884
Message: reader-viaccess.c : make sure we don't use memset to reset the last_geo as this would clean ecm_number and break the ecm processing.
Oscam-1.00-svn3885
Changeset #3885
Message: cccam: fix segfault in set_au_data()
Oscam-1.00-svn3887
Changeset #3886
Message: cccam: optimized card exchange "more CCCam-like", fixed a exchanging bug
**PLEASE TEST WITH "O" CCCAM**
Changeset #3887
Message: WebIf: add basic template structure for new cccam entitlement
Oscam-1.00-svn3888
Changeset #3888
Message: videoguard: filter shared emm by serial
r3889 | alno | 2010-11-12 10:11:19 -0800 (Fri, 12 Nov 2010) | 1 line
WebIf: temporarly re-enabled entitlements
r3888 | _network | 2010-11-12 05:57:18 -0800 (Fri, 12 Nov 2010) | 2 lines
Oscam-1.00-svn3891
Changeset #3890
Message: cccam/webif: entitlements more "O" CCcam like - UNFINISHED DO NOT USE !!
Changeset #3891
Message: cccam: card filtered by ident definitions in cccam readers
r3892 | alno | 2010-11-12 14:21:50 -0800 (Fri, 12 Nov 2010) | 1 line
WebIf: Teamwork
r3891 | schlocke | 2010-11-12 14:12:10 -0800 (Fri, 12 Nov 2010) | 2 lines
Oscam-1.00-svn3894
Changeset #3893
Message: webinf/Entitlements cccam: OK
Changeset #3894
Message: webif/cccam-entitlements: added readername/card count
r3896 | alno | 2010-11-12 15:28:21 -0800 (Fri, 12 Nov 2010) | 1 line
WebIf: add CSS class for totals in cccam entitlements
r3895 | alno | 2010-11-12 15:25:43 -0800 (Fri, 12 Nov 2010) | 1 line
WebIf: some cleanup for cccam entitlement. THX @ Schlocke for implementing and teamwork ;-)
r3894 | schlocke | 2010-11-12 15:15:33 -0800 (Fri, 12 Nov 2010) | 2 lines
Oscam-1.00-svn3897
Changeset #3897
Message: cccam: added card movement if card is too slow
r3898 | alno | 2010-11-13 11:05:15 -0800 (Sat, 13 Nov 2010) | 1 line
WebIf: try fix dyndns issue (untested)
r3897 | schlocke | 2010-11-13 06:28:30 -0800 (Sat, 13 Nov 2010) | 2 lines
Oscam-1.00-svn3899
Changeset #3899
Message: add some log messages in io_serial
---------- Post added at 02:20 ---------- Previous post was at 02:06 ----------
Changeset #3900
Message: io_serial: log timeout only as debug
Oscam-1.00-svn3902
Changeset #3901
Message: cccam: fixed card-removing issue
Changeset #3902
Message: Fixed build errors; but i'm not sure this cccam code is portable (specifically in reference to direct memory copies that don't take into account endianess)?
r3903 | schlocke | 2010-11-14 02:44:30 -0800 (Sun, 14 Nov 2010) | 2 lines
cccam: fixed compile error from #3901
r3902 | cogsi | 2010-11-14 01:51:39 -0800 (Sun, 14 Nov 2010) | 1 line
