Murata SMD TYPE IRS-D200ST00R1 is one of the world’s smallest PIR motion sensors at just...
Geniatech XPI-3576 is another Rockchip RK3576 SBC with up to 16GB RAM, up to 128GB...
DisruptorX V2 is an ESP32-based wireless security and penetration testing tool designed to analyze, jam,...
StarFive VisionFive 2 Lite is a low-cost, credit card-sized RISC-V SBC powered by a 1.25...
The XIAOML Kit is one of the devkits that complements Harvard University Professor Vijay Janapa...
There are already some consumer-grade WiFi 7 routers based on Qualcomm IPQ5322 SoC like Xiaomi...
High resolution images of the NuMaker-MG51FC boardNuvoton MG51 Series is a new family of 8-bit...
Works with grayscale and color E-Ink displaysModos Paper Dev Kit helps users create an open-hardware...
MSI MS-C926 is an Intel Alder Lake-N/Twin Lake fanless industrial box PC that’s ultra-slim at...
n-Fuse ZBC-M2-1630 is an M.2 1630 module based on Silicon Labs’ MGM260P module with an...
Supermicro is better known for its x86 servers, and they have already produced higher-end Arm-based...
Mcuzone’s CM5 5G Router expansion board is a carrier board for the Raspberry Pi CM5,...
The Maix4-HAT is a compact AI HAT for the Raspberry Pi 5 built around the...
Compulab EdgeAI-ORN industrial-grade Edge AI computer is based on NVIDIA Jetson Orin NX/Nano system-on-module and...
Debian 13 “Trixie” has just been released with Linux 6.12 LTS, GNOME 48 desktop environment...
The Banana Pi BPI-F4 is a compact industrial-grade Edge AI development board built around the...
Banana Pi BPI-R4 Lite is a mid-range 2.5GbE router board based on MediaTek Filogic 850...
If you found the Pironman 5 and Pironman 5 Max Tower PC cases for the...
Home Assistant Connect ZWA-2 is a new Z-Wave USB adapter with Long Range support, which...
Jetway’s MTX-TWL1 is a fanless industrial Mini-ITX motherboard built around the Intel Processor N250 or...
