Re: kHow to Transform H/W 12.03.A5 into H/W 12.01.A5
How to Transform H/W_12.03.A5 into H/W_12.01.A5 so you can have TPS AU working on you Kaon (H/W_12.03.A5)
Please follow these instructions very carefully:
1 / Write your HW 12.03.A5 with a streamsystem tps AU 12.01.A5 Firm.
2 / Turn OFF your receiver.Take the cover of your receiver of.
3 / Deconnect very carefully the connector cable of the CAM Card.
4 / Create the strapes on the connector cable as shown on the pictures below.
5 / Turn your Receiver back ON. Once all these steps are completed correctly go to the installation menu and make a chanel search.
To turn it back to original 12.03.A5:
1 / Turn OFF your Receiver.
2 / Deconnect carefully the straps.
3/ Reconnect the connector cable back into the CAM Card Reader
4/ Write a firmware H/W 12.C3.A5 to your receiver (use a 9/10 cable to have a good contact in the plug)
5/ Scan for Channels
**Note: PLEASE ITS RECOMMENDED YOU TURN OFF YOUR RECEIVER BY PULLING THE 220V CABLE BEFORE YOU OPEN AND TAKE OF THE COVER OF YOUR RECEIVER.
