Windows 11 Revives DreamScene With Live Video Wallpapers Returning
Windows OS is bringing back live wallpapers, reminiscent of the Windows Vista era. Originally known as [Only registered and activated users can see links. Click Here To Register...], this feature enabled video files, such as MP4 or MKV, to be used as live wallpapers on Windows desktop PCs. Microsoft is currently testing this feature again, as noted by @[Only registered and activated users can see links. Click Here To Register...]ofearth on X. In the latest Windows 11 Dev/Beta build 26x20.6690, there is a hidden option that lets you use video files as live wallpapers. Microsoft is also testing support for external files, which means we might see the company include a selection of customized live wallpapers in the next Windows 11 update.
To enable this feature, you need to be a part of the Windows Insider program. Once you become a part of this feature-preview program, you need to enable feature ID 57645315 and restart your explorer.exe, so Windows can apply it. However, the timeline for this feature is uncertain, and it might be part of next year's major updates. As of now, no significant features have been added this year. Microsoft isn't aiming for more under-the-hood changes for the 25H2 update, nor a visual makeover that prior updates were usually known for. Instead, the updates are primarily focused on security and are [Only registered and activated users can see links. Click Here To Register...]. For changes like this, we assume Microsoft needs more bug testing before rolling out the feature to stable channels.[Only registered and activated users can see links. Click Here To Register...]
Intel Splits iGPU Drivers: 11th-14th Gen Core Processors Now on Separa
Intel has reportedly split its driver branches for its older processors, with the 11th-14th Gen Core processors now on a separate iGPU driver branch compared to the newer CPU models. According to the latest driver release dated September 19th, Intel supplies Intel Graphics Driver 32.0.101.7076 for 11th-14th Gen Intel Core processor graphics, separating the support for integrated graphics into "Arc"-based and non-Arc-based models. The 11th Gen Intel "Rocket Lake" Core processors feature UHD Graphics 750, while the 12th Gen "Alder Lake", 13th Gen "Raptor Lake", and 14th Gen "Raptor Lake Refresh" Core processors feature UHD Graphics 770 GPU, all based on Intel's older "Iris" architecture. Hence, Intel decided to separate these older "Iris" variations from its newest "Arc" driver support branch, possibly assigning different support teams to the iGPU driver support.
The current cross-architecture package, v32.0.101.7029, continues to support Intel "Arc" as well as "Iris Xe" integrated designs while listing compatibility with 11th-Gen CPUs and newer. Separately, Intel published a slightly newer iGPU-focused release, v32.0.101.7076, that targets the non-Arc integrated graphics used on 11th-14th-Gen Core processors (the Iris/UHD variants). The existence of a dedicated v7076 branch implies Intel consolidated a set of iGPU-specific tweaks—performance and power/frequency profiles, accumulated bug fixes and platform adjustments—into a parallel maintenance stream before rolling broader Arc/Iris Xe updates through the v7029 line.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
FSR 4 on Older Radeon GPUs Tested: Improves Image Quality With Minor P
After AMD recently [Only registered and activated users can see links. Click Here To Register...], replete with libraries that support older hardware, it was only a matter of time before enterprising modders started demonstrating how those libraries could be used to port FSR to older RDNA GPUs. An enterprising [Only registered and activated users can see links. Click Here To Register...] and modder recently posted a how-to guide explaining how to get FSR 4 implemented in games on RDNA 2 GPUs, and the results reveal improved image quality at the cost of performance. There are other caveats, as well, like having to use a very outdated driver or dive deep into configuration files to rename DLL files to get the upscaler working.
According to both the results posted in the Reddit thread and testing done by [Only registered and activated users can see links. Click Here To Register...], FSR 4 seems to offer a balance between native image quality and FSR 3.1 performance on both RDNA 3 and RDNA 2 hardware. Computerbase tested Cyberpunk 2077 in 4K on the Ultra settings preset using the AMD Radeon RX 7900 XTX, and FSR 4 delivered 11% faster performance than native, but fell short of FSR 3.1 frame rates by 16%. The Reddit user who posted the how-to guide tested an [Only registered and activated users can see links. Click Here To Register...] across a range of FSR 4 quality presets, and found that even when set to "Quality," the RDNA 2 GPU gained around 10% performance compared to native rendering in The Last of Us Part 2 at 1440p. Both sources comment that the image quality is a noticeable improvement over FSR 3, and it was more stable than XeSS, which, to its credit, beat out FSR 4 on RDNA 2 in The Last of Us Part 2 by up to 10%, depending on the quality preset. Curiously, similar performance deltas were observed when comparing the unofficial INT8 FSR 4 libraries on RDNA 4 to the officially supported FP8 libraries, and the performance difference between FSR 3.1 and FSR 4 is almost identical, as well.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Montech Announces HyperFlow Digital AIO CPU Cooler and E28 Fans
MONTECH, a leading innovator in PC cases and cooling solutions, proudly announces the HyperFlow Digital Series, available in both 240 mm and 360 mm configurations. Designed to deliver enhanced clarity and control, the HyperFlow Digital features an integrated digital display that provides real-time CPU and GPU temperature monitoring at a glance. Paired with a high-density 27 mm radiator and MONTECH's newly engineered E28 ARGB performance fans, the HyperFlow Digital ensures exceptional thermal efficiency with striking ARGB lighting. The E28 fans, included with the cooler, will also be available as a standalone product, giving users the flexibility to upgrade their builds with precision-engineered airflow and static pressure performance.
At the core of the HyperFlow Digital is a 3100 RPM high-efficiency pump, paired with a bold 7-segment digital display that puts real-time CPU or GPU temperatures front and center. Supporting this hardware is MONTECH's streamlined software—lightweight, intuitive, and effortless to use—enabling quick toggles between sensor sources and °C/°F readouts. With near-zero footprint and instant responsiveness, it empowers users to stay in control of their system thermals without distraction.
[Editor's note: Our [Only registered and activated users can see links. Click Here To Register...] is now live][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Biwin Introduces Amber CB500 CFexpress Type B Card
Biwin announces that its Amber CB500 CFexpress Type B card has become the world's first CFexpress Type B card to receive VPG800 certification from the CompactFlash Association. With sustained write speeds of 800 MB/s guaranteed, the CB500 empowers filmmakers, cinematographers, and content creators to capture 8K RAW, high frame rate, and uncompressed video with stability. When every frame matters, the Biwin Amber CB500 CFexpress 4.0 Type B memory card is built to keep up, offering the reliability and performance pros need to stay focused on the shot. Crafted for creators, it flows seamlessly with their workflow.
- Enhanced Speed & Performance: Up to 3750 MB/s read and 3500 MB/s write speeds, supporting 4K, 6K, 8K and 12K RAW high-bitrate video recording. Up to 40 Gb/s transfer speed when paired with the Biwin Amber RB510 high-speed card reader, enabling fast, seamless data offloading and accelerating the post-production process.
- Guaranteed Stability with VPG800: Certified for a sustained 800 MB/s write speed for consistent performance during long takes.
- Optimized for Professional Workflows: Reduces transfer times during file offloading, streamlining entire workflows to move faster from shooting to editing.
(PR) MSI Unveils Next-Gen AI Products at TGS 2025
As a global leader in gaming and high-performance computing, MSI will showcase its latest AI-powered product lineup at Tokyo Game Show (TGS) 2025. The portfolio spans gaming laptops, desktops, monitors, graphics cards, motherboards, components, and peripherals—delivering breakthroughs in performance, design, and cross-cultural innovation. Since its inception in 1996, Tokyo Game Show has become one of the world's most influential gaming events, serving as a vital stage for MSI to demonstrate its technological strength and brand value to a global audience. In 2025, MSI will highlight not only top-tier performance but also the fusion of technology and culture, exemplified by the Prestige 13 AI+ Ukiyo-e Edition and the MLG Series, showcasing the brand's innovative drive.
Sam Chern, Vice President of Marketing at MSI, stated: "As a leader in gaming and high-performance computing, MSI is dedicated to delivering cutting-edge technology to gamers. At this year's Tokyo Game Show, we are unveiling our new generation of AI-powered products while also paying tribute to Japanese culture—from the timeless artistry of Ukiyo-e to the MLG character universe. We want gamers to experience not just performance and design, but also the cultural connections that make each product unique. Every product showcased at TGS represents a chapter co-created with our global gaming community."[Only registered and activated users can see links. Click Here To Register...]
(PR) EK by LM TEK Announces Availability of CryoFuel Space Black Coola
EK by LM TEK, the leader in high-performance liquid cooling solutions, proudly presents the new EK-CryoFuel Space Black (Premix 1000ml) Clear Coolant. Based on our award-winning formula, EK CryoFuel Space Black is developed with vivid black color for maximum light absorption, ensuring an ultra-premium Space Black finish to your custom-loop.
This coolant contains everything a high-end liquid cooling system requires for efficient thermal performance and providing the necessary protection for your water blocks. Now available to order at EK Shop and authorized EK distributors such as TITANRIG (US) & AQUATUNING (Germany, Austria, Switzerland).[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Biostar Introduces EdgeComp MU-N150 Embedded IPC
BIOSTAR, a leading manufacturer of edge computing solutions, industrial motherboards, graphics cards, and storage devices, today introduces the EdgeComp MU-N150, a compact, fanless industrial PC designed to meet the versatile demands of modern industrial applications. Engineered for system integrators, automation systems, edge computing, HMI terminals, and digital signage, the MU-N150 delivers powerful performance, silent operation, and broad connectivity in a rugged, space-saving form factor.
Designed for seamless integration into a wide range of industrial and commercial environments, the EdgeComp MU-N150 is ideal for system integrators managing customer data and business workflows, automation engineers developing real-time control systems, and edge computing solutions that demand high-speed local processing. With its dual Intel 2.5GbE LAN, robust I/O options, and fanless reliability, the MU-N150 also excels in HMI applications and kiosk systems, supporting essential peripherals like barcode scanners, receipt printers, and card readers. For digital signage deployments, its triple 4K display support enables crisp, multiscreen output in a compact, low-maintenance form factor.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ASUS Announces Turbo Radeon AI Pro R9700 32GB Graphics Card
ASUS today announced the Turbo Radeon AI Pro R9700 32 GB graphics card, designed for AI developers and other professionals who seek efficient cooling, compact design, and reliability for their high-performance workstations. It empowers users to run large memory-intensive AI models locally, and its two-slot profile—cooled by a blower-style system—makes it ideal for multi-GPU setups and space-constrained cases.
Advanced cooling system
The blower-style fan generates high static pressure and is paired with a diecast metal shroud and backplate to help ensure efficient heat dissipation. This design expels most heat directly out of the case, which helps to keep system temperatures stable so consistently high performance can be maintained even under the most demanding AI workloads. The diecast backplate also features unique wave patterns and folds that can reduce memory temperature by up to 16%—a significant improvement over traditional designs. Meanwhile, the phase-change GPU thermal pad liquifies to fill in any gaps between the die and the heatsink, providing excellent heat transfer and more durable material than regular thermal paste.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Samsung Reportedly Raises DRAM and NAND Contract Prices up to 30%
According to Korean media outlet News Daily, Samsung Electronics has confirmed that it has raised contract prices for DRAM by as much as 15-30% and mobile NAND flash by roughly 5-10%, in response to a noticeably tighter supply/demand balance. Samsung reportedly notified major customers ahead of fourth-quarter contracting, following a market shift, where older-generation parts are being phased down while demand from hyperscale cloud operators and device makers racing to ship AI-enabled PCs and flagship phones has surged. Additionally, Samsung's rivals such as SK Hynix and Micron have signaled similar adjustments, with several suppliers notifying clients of double-digit increases and temporary limits on new quotes. For buyers, the result is immediate price pressure across server and mobile storage purchases, while for vendors, it is a tactical reprioritization of wafer capacity toward higher-margin, next-generation product lines.
Samsung's DRAM LPDDR4X, LPDDR5, and LPDDR5X families, as well as embedded NAND formats such as eMMC and UFS, are among those experiencing contract uplifts. Meanwhile, shortages in commodity DDR4 briefly pushed spot quotes sharply higher. Memory makers have redirected capacity to DDR5 and HBM, prioritizing HBM orders used by AI accelerators, tightening the supply of consumer-focused DRAM. Samsung, which retains roughly a third of global DRAM and NAND market share, is accelerating development of next-generation LPDDR6 even as it tweaks production schedules for legacy nodes. The pricing reset is expected to materially improve semiconductor division margins in the near term, cushioning against earlier cyclical weakness. For customers, it will force revisions to inventory planning and, likely, a renewed focus on design choices for price/performance.[Only registered and activated users can see links. Click Here To Register...]
(PR) MediaTek Dimensity 9500 Unleashes Best-in-Class Performance, AI E
MediaTek, the world's leading innovator of smartphone SoCs, today announced the launch of its most advanced mobile platform yet: The MediaTek Dimensity 9500. Setting new standards in on-device AI, console-class gaming, and power efficiency, the MediaTek Dimensity 9500 is engineered to super-charge the next wave of flagship 5G smartphones.
The MediaTek Dimensity 9500 adopts a third-generation All Big Core CPU design, combining a 4.21GHz ultra core, three premium cores, and four performance cores, with four-lane UFS 4.1 storage. This design delivers up to 32% higher single-core and 17% higher multi-core performance compared to the previous generation, while the ultra core achieves up to 55% lower power consumption at peak performance, giving users longer battery life and greater productivity. The 9500 is also up to 30% more power efficient while multitasking in games and social audio call apps.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Windows 11 24H2 September Patch Breaks HDCP/DRM Video Playback
Microsoft recently rolled out its September 2025 Patch update with a KB5065426 code for Windows 11 24H2. However, the patch reportedly produces a very specific bug that prevents some Digital TV and BluRay/DVD applications from playing video. As these applications utilize Enhanced Video Renderer (EVR) with HDCP enforcement or Digital Rights Management (DRM) for digital audio, they may experience various errors, including copyright protection issues, frequent playback interruptions, freezing or black screens, or no video playback at all. Microsoft confirmed the issue on September 19 and is actively working on the fix, which it will roll out in future Windows updates. Microsoft claims that this issue doesn't impact streaming services.
The Enhanced Video Renderer, although still used by some players, has largely been superseded by newer renderers, such as the Simple Video Renderer. Its job in protected playback is to work with Media Foundation and older DirectShow components so decoded frames remain within a trusted rendering path. EVR ensures video is composited only onto Direct3D surfaces that the system treats as secure, preventing decrypted frames from being written to ordinary memory or captured by other software. That coordinated handoff between the media framework, drivers, and the GPU is what lets Windows meet the licensing and output restrictions required for BluRay, broadcast TV, and other DRM-protected formats.[Only registered and activated users can see links. Click Here To Register...]
TSMC Reportedly Secures 15+ Customers for its "N2" 2 nm Node
TSMC is reportedly handling a significant volume of orders, with 15 or more customers designing on its latest "N2" 2 nm node. According to KLA's Ahmad Khan and Bren Higgins, this N2 node is attracting considerable interest, with 10 of these customers focused on high-performance computing (HPC) designs. Potential clients could include Intel, NVIDIA, AMD, and various startups, while the rest may be developing mobile-optimized designs from companies like Apple, Qualcomm, and MediaTek. "As we're seeing today, the N2 node has about 15 customers working on designs, with around 10 focused on high-performance computing. This is driving rigorous performance requirements," noted KLA's team at a Goldman Sachs conference.
TSMC's N2 node is noted for its high power efficiency and a transistor density of 236.17 million transistors per mm², making it an excellent choice for both HPC/AI and mobile designs. Although TSMC initially planned to implement a backside power delivery network with this node, this feature has been shifted to the A16 node. The N2 will remain a Gate All Around (GAA) FET design to better control transistor gate leakage, moving away from the older FinFET design that has reached its limits with further miniaturization. TSMC has scheduled the commercial launch of the N2 semiconductor node for the second half of 2026, indicating that major technology companies may start adopting this advanced chip technology by early 2027.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel Arc Pro B60 Workstation GPU Spotted at $599, Suggests Non-OEM Av
US retailer Central Computers listed the ASRock-branded Intel Arc Pro B60 "Battlemage" GPU with 24 GB of GDDR6 memory at a surprisingly low $599, cancelling previous rumors of a four-figure price and OEM-only availability. This retail sighting matters because it frames the B60 as a rare workstation GPU that pairs high memory capacity with an approachable street price, a combination attractive to creatives and engineers working with large models, complex renders, and memory-heavy data sets. The listing also confirms the B60's rumored OEM-only approach is not true, and that we will see broader retail availability, although Intel has not confirmed MSRP or distribution plans publicly. A single retailer listing can be an early indicator rather than proof of wide release. Still, seeing a Battlemage-based card with 24 GB at this price reshapes expectations and invites fresh conversations about how Intel positions the Arc Pro line.
The ASRock Arc Pro B60 Creator features a blower-style cooler, a quoted boost clock of around 2,400 MHz, a 192-bit memory interface that feeds 24 GB of GDDR6 at a bandwidth of 456 GB/s, and a reported 160 XMX AI engines that enhance its INT8 and FP32 capabilities. Compared with the Arc Pro B50, which attracts attention for bringing 16 GB VRAM to a sub-$400 bracket, the B60 expands the viable options for users who need larger frame buffers for complex scenes, high-resolution texture sets, large language model inference, and memory-intensive simulation tasks. If the $599 listing reflects reality and availability broadens, the B60 could become the most accessible 24 GB workstation card, making Intel's entry into the workstation space worthwhile.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Hades II Officially Launches 1.0 With Achievements, Updated Visuals, a
[Only registered and activated users can see links. Click Here To Register...] has been available as an Early Access Steam game for a while already, and during that time, it has proven its popularity, reaching a peak player count of over 100,000 players. However, on September 25, nearly a full year after the Early Access launch, Hades II has officially launched, with the 1.0 update bringing a host of new features and renewed interest in the hack-n-slash roguelike. As of the time of writing, a mere three hours after the official v1.0 update launched, Hades II has peaked at 84,232 concurrent players, according to SteamDB. Although this is still a fair bit away from its all-time peak of 103,567 players, the game launched on a Thursday morning and evening in the biggest gaming markets, so player counts are expected to increase over the weekend. Hades II already had an Overwhelmingly Positive (97% positive) Steam, but after the release, the game has seen a spike in reviews, with over 900 new positive reviews published just three hours after launch.
Among other things, the Hades II v1.0 update adds a true ending to the story of Melinoë's rebellion against the underworld. Players who played the beta version of the game will also now have access to 50 achievements, unlockable Familiar customizations, updated in-game visuals, new music, and new decorations and collectible Keepsakes. More details about tweaks to gameplay, visuals, sound effects, and customization options are available in the [Only registered and activated users can see links. Click Here To Register...]. In the v1.0 [Only registered and activated users can see links. Click Here To Register...], Supergiant says that "it's too early to say what's next for our team," and that, following the launch of Hades II, the development team will take a much-needed break, aside from the usual post-launch hotfixes. Thus, it seems unlikely that any new content will be added to Hades II for at least a short while. Hades II is currently available for [Only registered and activated users can see links. Click Here To Register...], and it is also available for the Nintendo Switch and Switch 2 and Epic Games.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) IonQ Achieves Record Breaking Quantum Performance Milestone of #A
IonQ, the leader in the quantum computing and networking industries, today announced it has achieved a record algorithmic qubit score of #AQ 64. This milestone was achieved on an IonQ Tempo system, three months ahead of schedule, establishing IonQ as the only company to reach #AQ 64 setting a new standard for quantum systems.
#AQ benchmarks measure a quantum system's ability to run quantum algorithms of increasing complexity and size while maintaining high fidelity. Achieving #AQ 64 indicates that IonQ's quantum systems can address a set of increasingly complex real-world applications such as energy grid distribution improvements, computational drug discovery, engineering simulation modeling, supply chain optimization, and enhanced fraud and anomaly detection.[Only registered and activated users can see links. Click Here To Register...]
Buy Genuine Windows & Office Keys at Rock-Bottom Prices! Instant Deliv
Instant 1-3 second automated delivery! WDKeys provides you with 100% genuine Windows and Office keys. Permanent activation, no restrictions. Full refund if activation fails. Stop enduring the risks of pirated software and the headaches of activation! This promotion is only to open the market and will end soon. If you miss it, it will be hard to encounter again.
Office Keys: Fully unlock Word, Excel, PowerPoint & beyond.
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
Windows operating system keys
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
The Ultimate Value Deal: Windows & Office Bundles
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...]
Unlock exclusive discounts when you buy in bulk
[Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...] | [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) MagStor Reveals LTO-Powered Data Storage Systems Targeting Survei
MagStor, a recognized leader in tape storage solutions, today announced a new line of video surveillance appliances to deliver best-in-class data storage solutions to the Video Surveillance markets.
As video surveillance data requirements explode due to increased retention times and higher resolution video, integrators and end users are struggling with ways to tame the costs. For example, a 50 camera setup at a retail location can generate nearly 500 TB of data over 12 months, forcing users to spend massive amounts on traditional spinning disk or cloud storage. MagStor's new video surveillance appliances provides relief to users seeking more reliable and lower cost storage:[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Early Benchmarks Reveal Impressive Snapdragon 8 Elite Gen 5 Gaming Per
Qualcomm only just [Only registered and activated users can see links. Click Here To Register...] as its latest flagship mobile SoC, and although there were early Geekbench results presented at the Snapdragon Summit event, the first real-world performance figures are starting to emerge, courtesy of the as-yet unreleased OnePlus 15. These tests, carried out by [Only registered and activated users can see links. Click Here To Register...] mostly center around the Adreno 840 GPU in the Snapdragon 8 Elite Gen 5, which is meant to deliver marked performance improvements, thanks to the inclusion of Snapdragon HPM (High Performance Memory) cache and updated GPU architecture. It's also important to note that these performance results won't necessarily be representative of results on other smartphones, since thermal management is a big determining factor for smartphone performance, especially when it comes to gaming and sustained workloads. The OnePlus device in question is also running pre-release drivers and firmware, so it's possible that more optimizations and performance gains are coming.
The YouTuber tested the Snapdragon 8 Elite Gen 5 across five different games (Honkai: Impact 3rd, Wuthering Waves, Honor of Kings, and Delta Force) and compared it to an iPhone 17 Pro Max and a MediaTek Dimensity 9500. The results are rather impressive, as the new Snapdragon SoC manages to keep up with the Apple A19 Pro in the iPhone 17 Pro Max for the most part. He also performed his own Geekbench 6 tests and found that the results presented on Qualcomm's test devices at the Snapdragon Summit were representative of retail devices, with the OnePlus 15 scoring 12,352 points in the multicore benchmark and 3,836 in single-core tests.[Only registered and activated users can see links. Click Here To Register...]
(PR) Yunzii Launches QL108 Retro Typewriter-Style Mechanical Gaming Ke
The YUNZII QL108 brings the nostalgic feel of a classic typewriter into today's world of performance-driven mechanical keyboards. With its retro electroplated round keycaps and solid metal shell, this full-size keyboard blends timeless aesthetics with the latest features for work, gaming, and everyday creativity.
Retro Typewriter Design with Full-Size Layout
The QL108 features a 104-key layout with a dedicated numpad, making it an efficient choice for both office tasks and gaming. Its electroplated round keycaps perfectly capture the retro typewriter look, while the metal shell ensures a premium feel and lasting durability.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
