Ma lasa sa fac schimbul acum, nu-mi mai da eroare, dar in rest...aceeasi chestie, tot nu merge...
Am ramas in pana de idei, sorry. :sorry:
Multumesc oricum...:cheers:
Sunt insa sigur ca mai sunt si altii cu idei pe-aici, numai ca le tin ascunse...:lol:
Sorry a trebuit sa plec aseara,am fost grabit un pic,pt mbox 0.6 trebuie sa schimbi linia B asaSau mai bine uite configul meu pe care il folosesc pe ipbox cu imaginile DGS ,functional 100%Quote:
B: { 0 0 0 }
//mbox.cfg EXPLANATION and EXAMPLES
A: { 0 } // for QBoxHD receivers or for any receivers if needed it
//A: { x }
//Choose adapter path
//x=0 -> /dev/dvb/adapter0/
//x=1 -> /dev/dvb/adapter1/
//x=2 -> /dev/dvb/adapter2/
//x=.. -> .......
//default x=0
D: { 2 }
//D: { x }
//x=0 -> disable
//x=1 -> enable dbox2 cw writing
//x=2 -> enable STAPI for IPBOX
//x=3 -> enable STAPI for Kathrein
//x=4 -> enable Linux DVB API for Kathrein
//x=5 -> enable triple dragon
//x=6 -> enable Qbox HD
//x=7 -> enable STAPI for Kathrein ufs922 -> dont work CSA decoding :(
//default disabled
B: { 0 0 0 }
//B: { 1 127.0.0.1 127.0.0.1 } // for local watching over DVB
//B: { x IP_listen IP_send }
//x=0 -> disable local UDP ports 8004-80xx ,this ports are used with DVB cards and gbox plugin (Windows and Linux)
//x=1 -> enable
//IP_listen -> on what IP to wait for PMT and ECMs
//IP_send -> on what IP to send DCW
//default disabled
Z: { 11 01 } { 192.168.1.64 8002 }
// Z option -> control sending/writing current informations
// Z: { xy 0z } { IP port }
// x=0 -> don't print time stamp (in console screen and in debug file)
// x=1 -> print time stamp ( .... )
// y=0 -> no writing/sending informations to debug file/destination IP
// y=1 -> send informations to destination IP but not in debug file
// y=2 -> write informations to debug file but don't send to destination IP
// y=3 -> write/send informations to debug file/destination IP
// z=0 -> dont write debug text in console window
// z=1 -> write debug text in console windows
// IP port -> destination IP and UDP port where to send informations
// no default
#C: { 127.0.0.1 7999 }
// C option -> control receiving some command messages localy or from another IP
// C: { IP port }
// IP-> your local IP or you DNS
// port -> on what port you will be waiting command messages
// no default
L: { 1 }
// L option -> how mbox to menage virtual card(s) with level 0
// ( only for peer(s) who have and can reshare virtual cards but don't want to use LEVEL 0 card(s) for them self)
// L: { x }
// x=0 -> don't load any virtual cards with LEVEL 0, you can't use them for your self
// x=1 -> load all virtual cards with LEVEL 0 ,you will be using them for your self
// default 1
#G: { /hdd/ }
//G option -> redirect writing ONLY debug.txt file to internal or external HDD in receivers or for any other reason.
//Remove #, ONLY if you want to use this option !!!!!!!
T: { /tmp/ }
// T option -> where to store temp files ... (share.info,debug.txt ,etc.)
// T: { folder_path_to_files, example: T: { /tmp/ } }
K: { /var/keys/ }
// K option -> where is cwshare.cfg,mbox.prio file
// K: { folder_path_to_files, example: K: { /var/keys/ } }
M: { 1 }
// M option -> Mode option
// M: { x }
// x=0 -> local mode no NET
// x=1 -> NET mode
// default 0
P: { /tmp/pmt.tmp }
// P option -> PMT location (Dont used with linux and windows)
// you must be tuned to channel so image can generate this file
// { /tmp/pmt.tmp } for receivers and images that create this file <- use this if you can
// { /tmp/pmtX.tmp } X-> number -> pmt1.tmp ......
// { 1/tmp/camd.socket } for enigma 1
// { 2/tmp/camd.socket } for enigma 2
W: { 0 }
// W option -> write raw ECM to ecm.raw file
// W: { x }
// x=0 -> disabled
// x=1 -> enabled
// default disabled
Q: { 300 }
//Q option -> newcamd connect retry in sec.
//Q: { x }
// default 300 sec.
F: { 500 }
//F option -> reset writing debug.txt from begining if file size is higher then (x)(KB)
//F { x } -> decimal in KBytes
//default 500 KB
//V: { card_type | device number | clock | inverse_Reset | inverse_CD_Line | detect card over CTS | DM800/8000 | dbox }
#V: { 3 1 3571200 0 0 0 0 0 } // external reader example -> Seca card, com1 port, clock 3.57 Mhz,
#V: { 3 2 3571200 1 0 0 0 0 }
#V: { 3 3 1 0 0 0 0 0 } // dreambox example -> Seca card,sci0 slot,3.33 Mhz
// [card_type]:
// Seca 3
// Irdeto 4
// Conax 5
// Cryptoworks 6
// Viaccess 7
// NDS 8
// Nagravision 9
// [device number]:
// COM1/ttyS0 1
// COM2/ttyS1 2
// /dev/sci0 3
// /dev/sci1 4
// /dev/usb/tts/0 5
// /dev/usb/tts/1 6
// /dev/tts/0 7
// /dev/tts/1 8
// /dev/ttyUSB0 9
// /dev/ttyUSB1 10
// /dev/scard0 11 //azbox
// /dev/scard1 12 //azbox
//[clocks]
//for COM ports and external card readers in Hz!!!
//for SCI DreamBox slots use this values
// 1 - 3.33 Mhz
// 2 - 3.63 Mhz
// 3 - 4 Mhz
// 4 - 4.44 Mhz
// 5 - 5Mhz
// 6 - 5.71 Mhz
// 7 - 6.66 Mhz
// 8 - 8 Mhz
//[Inverse Reset]
// 1 -yes
// 0 -no
//for GPIO
//2-gpio1
//3-gpio2
//4-gpio3
//5-gpio4
//6-gpio5
//7-gpio6
//8-gpio7
//[Inverse CD Line Detection]
//1 - yes
//0 - no
//[Detect card over CTS signal]
//1 - yes
//0 - no
//[DM800/8000 box]
//1 - yes
//0 - no
//[dbox serial/multicam]
//1 - yes
//0 - no
#J: { 1 }
// J option -> enable adding betacrypt header to N3 ECM for Premier
// J { x }
// x = 0 -> disabled
// x = 1 -> enabled
#S: { COM1 115200 }
//S option -> enable sssp protocol
//S: { x baud }
//x=COM1
//x=COM2
//x=/dev/ttyS0
//x=/dev/ttyS1
//x= serial device ...
//valids baud -> 115200,57600,38400,19200,9600
Confirm ca mergeeeee! :band::cheers:
Totusi imi poate da careva pe PM o linie de test, sa vad daca se inverzeste? Mentionez ca am card local Dolce si mbox 06 build 0010 :clap:
Am facut rost si de cateva linii deja, dar vad ca in versiunea asta mai noua de MCC imi apar si linii portocalii... Ce semnfica asta, mai precis - "LC on diff. box" ?
Are cardul in alt receptor aflat in reteaua locala,adica nu are localul in receptorul din care ti-a dat linia.
Salut! I-mi spune si mie cineva la o imagine Sifteam pt. Ipbox910 in ce directoare se pun mbox cfg.mbox.sh40, cwshare,newcs? Multumesc!
Ti-am mai raspuns odata ,ce nu ai inteles [Only registered and activated users can see links. Click Here To Register...] executabilul in cazul tau e mbox.sh40 il pui in var/bin ,iar mbox.cfg,cwshare.cfg,ident info,ignore.list,port.list le pui in var/keys.
Am adaugat deja peste 30-40 de peersi, dar la fiecare din ei nu imi vede decat foarte putine carduri, uneori nici macar o treime din ele. Care ar fi explicatia?
Cu cat adaugi mai multi peeri cu atat o sa ia mai putine carduri de la fiecare, mbox le filtreaza in functie de provider, daca vin prea multe carduri identice de la peeri pe unele le ignora.
Hmm...la mbox 04 nu era asa... In cazul asta, o sa mai sterg din liniile albastre si galbene... :D
Mai ales alea albastre :)
Salutari tuturor!
Si eu sunt posesor de un receiwer ip box hd 910,am folosit mai inainte numai cu emu,iar acuma a disparut N2 si am ramas pe intuneric:agresiv:Acuma as-i vrea sa o folosesc acest box la sharring,adica sa ma uit la posturi prin share,dar eu nu sunt posesor de card.Nu am cum sunt departe.Deja de o saptamana tot citesc forumuri,tot caut solutii dar nimeni nu vrea sa ma ajuta.Incerc si aici.Am pe box Nlb 11992 image ,MgCamd,Mbox,Scam,IncubusCamd.Nu pot intelege ce trebe completet si cum,am ajus sa pot edita mg_cfg si newcamd.list.Dar nu merge nici cum Daca vrea cineva sa m-ajuta si sa-mi explice cat decat ca sa inteleg si eu,as-i fi multumit.Sunt foarte suparat ca am dat atatia ban pe un box ca asta si nu pot sa ma descurc.Rog foarte mult daca vrea cineva ,si pote, sa ma ajuta.
Multumesc,si cer scuze daca nu m-am exprimat corect.
calea simpla ?! pentru share cu cccam
daca ai mgcamd 1.35 atunci editezi in fisierul cccamd.list si adaugi linii de forma
C: server.dyn.dns 12000 user1 pass1
server.dyn.dns - adresa serverului cccam
12000 - portul pe care este vizibil serverul ( poate sa fie diferit de 12000 )
user1 - numele contului in server
pass1 - parola pentru contul user1
aceste date ti le comunica detinatorul serverului
in mg_cfg modifici
G: { 32 }
P: { 02 }
acum ramine sa gasesti un server cccam - lucru in general greu fara sa ai card local pentru schimb
