Nu e de la skin
Trebuie sa cauti un dat.
si sal transferi in libraria taQuote:
libgcc_s.so1
Nu e de la skin
libgcc_s.so1
salut, eu folosesc imagine TeamRed din 17.02.2012 , cu skin HD GLASS 16 , apare ecm time pe infobar ...
succes .
salutare!
1. propunere: cred ca acestui receptor (sau familiei din care face parte), ar trebui sa aiba o sectiune dedicata pe forum. astfel informatiile/intrebarile/raspunsurile sunt structurate (ordonate) cu cap si coada si devin mai usor de gasit/studiat.
2. am un adaptor wifi de la BELKIN, model F6D4050 V.2 (chipset RA2870). am pornit modulul kernel aferent dar nu este activa optiunea de wi-fi la sectiunea networking. asta dupa ce am instalat e2-29-02-fix-wifi din blue panel -> addons -> Enigma2-updates. orice idee este binevenita!
root@Giga:~# iwconfig
lo no wireless extensions.
eth0 no wireless extensions.
root@Giga:/etc/Wireless/RT2870STA# lsusb
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 050d:935b Belkin Components F6D4050 N150 Enhanced Wireless Network Adapter v2000 [Ralink RT3070]
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
root@Giga:/etc/Wireless/RT2870STA# root@Giga:/etc/Wireless/RT2870STA#
succesuri! :drinks:
---------- Post added at 21:52 ---------- Previous post was at 20:40 ----------
cat /proc/bus/usb/device
T: Bus=01 Lev=01 Prnt=01 Port=00 Cnt=01 Dev#= 2 Spd=480 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS=64 #Cfgs= 1
P: Vendor=050d ProdID=935b Rev= 1.01
S: Manufacturer=Belkin
S: Product=Belkin Enhanced Wireless USB Adapter
C:* #Ifs= 1 Cfg#= 1 Atr=80 MxPwr=450mA
I:* If#= 0 Alt= 0 #EPs= 7 Cls=ff(vend.) Sub=ff Prot=ff Driver=(none)
E: Ad=81(I) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=01(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=02(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=03(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=04(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=05(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
E: Ad=06(O) Atr=02(Bulk) MxPS= 512 Ivl=0ms
se pare ca nu are driverul instalat. asta este o problema pentru ca nu stiu de unde sa-l iau.
succesuri! :drinks:
Salut, a pus cineva caidul 1880 pe pe acest receptor?... am incercat cu sbox+ccam 213 dar nu reusesc, il citesc numai cu sbox nu pot lega cccam de el , un script daca are cineva, momentan folosesc HDF v4 , apropo ce imagine e mai stabila pe el?..Multumesc!.
Am incercat eu sa pun cardul 1880 in receptor cu sbox + cccam si nu se poate. Am intrebat pe forumul oficial si nu mi-a raspuns nimeni in ultimele 3 saptamani desi am postat in mai multe sectiuni. Pe forumul sbox am primit ajutor si se pare ca problema sunt driverele gigablue. Ce se intampla ? Se pare ca sbox citeste cardul, preia controlul asupra cititorului de card dar la initializarea cccam acesta din urma preia el controlul asupra readerului . Ambele procese raman in rulare fara sa citeasca sbox cardul.
Asta se intampla cu cccam2.1.4 si mai jos + sbox . De la cccam2.2.1( parca asta e prima versiune) au introdus o noua optiune pentru cccam "SCIDEVICES :0" prin care se forteaza cccam sa nu incerce deloc sa foloseasca cititorul de card. Daca se pune optiunea asta merge in paralel sbox + cccam2.2.1 dar problema o stim cu totii : nu va aparea card local . N-am rezolvat nimic si tin cardul intr-un dm500s , dau linie N catre gigablue.
Nu am insistat prea mult dar mie mi-a facut aceeasi figura si pe oscam. Daca porneam oscam+cccam imi murea iar cardul , nu mai primeam ecm-uri si nu mai aparea activ in interfata web a oscamului. Nu am testat prea mult si oricum era cu o luna in urma. A mai testat cineva oscam+cccam pe gigablue ?
Revin cu unele completari.
Se pare ca au lansat noi drivere integrate in imaginea OpenMips. Cu noile drivere si versiunea de cccam2.0.9 de la ei merge sbox+cccam :) . Daca inlocuiesc cccam209 cu 2011 sau 213 nu mai merge am din nou aceeasi problema. Partea buna e ca acum e utilizabila combinatia.
Exista vreo lista de buguri pentru cccam2.0.9 ? Ma gandesc sa nu fie una din versiunile cu problema care au mai fost in trecut ( vezi cccam2.0.4). Ms
Stie cineva cum se configureaza afisarea frecventei si SR pe second bar la openmips de exemplu la Focus arata UPC Direct DVB-S 1444974 v 28000 7/8 QPSK 0,8 frecventa e aiurea nu stiu de au scos 1444974 apare la informatii tuner status si frecventa 12034 la muliplex deci ar trebui sa apara la skin 12034v 28000 ce ar trebui modificat? in rest skinul Pli-HD este perfect
Care e cea mai buna imagine pentru receptorul acesta?
cred ca openmips merge cu toate cccam 2.011 2.13 2.14 2.30 si imaginea mi se pare mai buna ca la teamred
Am intrat si eu de cateva zile in posesia acestui receptor, are imagine de la echipa SIF si am urmatoarea problema cu acest aparat: pe antena fixa am semnal f bun dar atunci cand pun receiveru pe antena cu montura H-H nu mai am semnal desi pe alt receiver semnalu este f bun...sa fie de la imagine? am setat la tuner in toate felurile si degeaba , o singura data am prins semnal dar dupa ce am schimbat canalu nu am mai avut semnal.
am pus un link mai jos cu problema pe care o intampin
Rog ajutor.
Pentru HH, la mod configurare trebuie sa pui simple nu avansat, urmatoarea optiunea pui pozitioner,
dupa care introduci latitudinea si longitudinea pentru locatia ta.
Brand New VIX Image HD800 UE
15/08/2012 - OpenViX 3.0.204
From VIX Team
GCC Version: 4.4.4
GB Kernel Version: 3.1.1
GB Drivers: 14-08-2012
Vix Team is proud to present
an all new full featured Vix image for the GigaBlue UE
BOOTLOADER UPGRADE REQUIRED FOR THIS IMAGE, USE LATEST BOOTLOADER
Features
VIX EPG
Graphics and Text mode available.
Video Playback
All EPG screens now available while watching a recording, for easy switching back to Live TV or setting timers.
Channel Selection
Support added to change font sizes and number of rows.
Support added to have a 3rd event showing (Skin Dependent)
Support added to display start time and end time for all events shown.
EPG Selection
Added help screen to all epg selection screens.
Added support to change font sizes and number of rows.
Language Selection
Added English (UK) to available languages.
Translations
Added support for English (UK).
Sorting
You may now sort Menus, Settings and Plugin Browser alphabetically.
Network Browser
Uses less memory during Scan.
Moved to new Setup Mounts screen.
Openwebif
New style webif now accessed using default port 80
Old style webif still available if required for use with certain PC signal meters and Fancontrol 2
About Screen
Added network info.
Plugins
As part of streamlining the image, removed NFS, AFP, Samba, OpenVPN, Inadyn, MiniDLNA & uShare from default image (can now be installed/de-installed through Network setup screen)
On Screen Hints
Now available as options are selected.
Instant Record
from channel list, EPG or current channel.
Enhanced Movie List Features
It is now optional to play next movie, when the a movie reaches end, setup in menu of movie selection screen.
Latest Drivers (14/08/2012).
Loads of under the hood changes made for a smoother user experience.
Button Mappings
Short Red** & *** - Show current channel EPG info (ViX Single EPG).
Long Red ** & *** - Sort single EPG info when in channel list.
Short Green** & *** - Timers.
Long Green*** - AutoTimer Timers.
Short Yellow*** - EPG Search.
Long Yellow*** - Instant IMDB Database search on the current programme.
Short Blue - Extensions.
Long Blue*** - Plugins Menu.
EPG - Opens ViX EPG.
Left/Right** - Opens ViX QuickEPG.
Up/Down** - Open Full Screen Channel List.
TV Button** - Open Full Screen Channel List.
Long TV Button - Open Bouquets List.
** Can be changed in ViX Menu
*** Can be turned off in ViX Menu
Special ThanksNote: Not all 3rd party plugins have been tested or are guaranteed to be compatable.
- rytec - for his continued support.
- zoka.cc for his Picon sets
- All developers for their plugins used in the feeds of this image.
- All of the ViX Beta team for their hours of testing and dedication on getting this image working.
- Rob van der Does, belierzz, rimas, Henkka, raivo, eesatfan, Zartmy, Trial & june8 for their translation work
- Huevos for his work on blindscan
- Gennart1 for dvb-as102 support
- Markus625 for skin ViXBMC
Requests
If anyone is interested in doing any translation work for the plugins and the image itself, please contact either Andy or Sicilian
Downloads
Stable release attached below
Download site for Latest Open Vix Builds (Beta's)
---------- Post added at 15:01 ---------- Previous post was at 15:00 ----------
Am setat cum mi-ai zis dar acum problema e cum gasesc un satelit, cum rotesc antena, daca poti da mai multe detalii ptr un incepator, nu am mai lucrat cu receivere cu pozitioner si USALS si nu ma prea pricep.Quote:
Originally Posted by SuperSonic [Only registered and activated users can see links. Click Here To Register...]
Multumesc anticipat.
a testat cineva aceasta imagine cum merge merita pus sau nu??
Cred ca problema nu este din setarile care trebuiesc facute la configurarea tunerului...am pus in toate felurile si cu long.si latitud. si degeaba, am observat ca nu mi se misca antena din acest receiver si nici semnal nu primeste cum ar trebui...oare sa fie motoru de vina? am acest model de motor [Only registered and activated users can see links. Click Here To Register...].Quote:
Originally Posted by iulian1986 [Only registered and activated users can see links. Click Here To Register...]
Mentionez ca antena a fost testata pe un alt receiver FTA, pe SS2 si pe tunerul Tv-ului si merge fara probleme, numai pe GigaBlue nu vrea.
Astept ajutor ca deja m-am saturat cat am butonat la receiver.
