Image ID verification script is included receiver ... with a little trick works flawlessly on Alien. It is a shame to come here to customize images ... but are solutions to avoid obstacles.
How do you change that?
Ciudata treaba .... acum vad ca se restarteaza imaginea cand accesez Panelul , se vede treaba ca s-au gandit baietii si la alte masuri de protectie . Voi mai sapa un pic sa vad ce si cum si apoi back to RSP .
ps... deja am inceput instalarea RSP ca devine enervanta treaba .
This pkt is great image best img on alien:clap:
Rsp is old and many things dont work....
Good for you, you find the right image for your receiver. I hope you will be satisfied.
One month ago, when you entered this forum, you had a rude and accusing voice, perhaps you won't be so angry, now.
That because many people try to steal something from somebody as an enigma and then issue a new version but the problems remain the same.
It is inconceivable that the enigma can not work with 1080i res.Many e2 versions have this problem.Why are based on the scart that does not provide the perfect atmosphere?These were just some reasons but when he started writing all that would not stop for long...
How do i change the Keys for Amiko Alien.
Please help.
Thanks.
New version [Only registered and activated users can see links. Click Here To Register...]
Enigma2 OpenSource SH4 Duckbox Project GIT-3052 PKT SVN-1266 HAARP
- fix remote control detect
- fix restarting on some receiver after first reboot with unexplained reasons
Recommended update to v3a version for all users !
Working on Amiko Alien and GM 990
Mersi de info.
Azi dupa F1 o bag la teste.
In this image works the CD+ NL card
Am testat putin această imagine.Este bună, oarecare stabilitate,telecomanda este rezolvată.Din păcate marea mea dezamăgire vine de la cititorul de card care nu recunoaște pocuss.M-ai așteptăm la versiunile următoare de la cei care se străduiesc cu adevărat să-și bată capul cu imagini pentru noi.
Am testat si eu imaginea pe GM990. Booteaza cam incet, telecomanda functioneaza bine, o gramada de pluginuri. Ce mi-a placut, se pot programa butoanele colorate pentru short/long press. Problema cu IP manual la configurarea initiala persista, vrea numai DHCP, dar se rezolva totul dupa instalare. Pluginul YT nu functioneaza/nu este disponibil.
Singurul lucru care ma atrage este functionalitatea 100% a telecomenzii de GM, dar asta se poate "tuna" cat de cat si la versiunea RSP.
Cam atat ar fi de spus, acum back to RSP.
Ultima imagine PKT contine fisiere si pentru telecomanda Alien , nu trebuiesc facute alte modificari .
La mine e invers, eu nu am Alien ci GM, iar RSP nu contine fisierele pentru telecomanda GM :)
Inca nu am repus rsp si acum observ ca nu am probleme pe 1080p. nu tu macroblocuri, nu tu sacadari. poate confirma cineva care a mai testat aceasta imagine?
Sent from my GT-I9001 using Tapatalk
Pe 1080p nu sunt probleme nici pe alte imagini , problema este pe 1080i unde nu s-a rezolvat in totalitate bug-ul ( sunt canale HD unde se mai manifesta dar destul de rar ) dar fenomenul este cu mult imbunatatit .
