Noua versiune de Firmware 1.09.20
!!! aceasta versiune de FW se instaleaza numai dupa ce ati facut upgrade BootLoader
la versiunea 2.54 !!! gasiti loaderul pe sat-support ...se incarca ca orice loader ... pe serial !!!
Versiunea 1.09.20 aduce numeroase inbunatatiri asa cum rezulta din release.note
- Upgrades & Improvements :
--> Plugin is capable to download from one's web server
--> Menu - Utilities - Plugin : Blue Button - Download
--> Server URL : Menu - Installation - Network Setting : Firmware upgrade Server
--> Multipicture mosaic function bug : Amended (Blue Button)
--> Blind Scan search wrong : solved
--> Duplicated channel or other bugs in Blind scan : Solved
--> Sky portal CH problem : Solved
--> Hang-up when make 10 min pause during playback rec file : Solved
--> EPG Daily Recording Bug : Solved
--> Working Screen saver during Radio service playback : Solved
--> Can not delete specific Rec file Bug(file name include / or special character) : Solve
--> Unstable Signal Quality : Solved
--> Background black issue in the info Banner's event name : Solved
--> Recording name saved as previous event name in event scheduled recording : Solved
--> Hang-up issue after Factory reset : Solved
--> Hang-up by Data Transfer Menu : Solved
--> When changing service up/down, loop supported in one tuner : Supported
--> Logical channel number (LCN) function off : Amended
--> Audio click noise : Solved
--> Lost descramble in Recording of the specific channel : Solved
--> Can not Recording in Service nemed in Turkish : Solved
--> Service find option in Service list manager : Added (Yellow Button)
--> Menu display spilit or broken : Solved
--> Screen Turns into Black&White in Resolution change mode : Solved
--> Flickering and spot in the screen with Scart in Resolution change mode : Solved
Versiunea disponibila curand pe sat-support !!!
Pentru a face upgrade Bootloader folositi acest loader RS232 !!! [Only registered and activated users can see links. Click Here To Register...]
@coco - pluginurile pe care noi le sustinem sint : Oscam , MgCamd , Mcas ... restul sint functionale dar ... istorie !
