Gata , am reusit sa il scot pe net , sa vedem cum fac cu gbox ul , e pe undeva un tutorial ptr incepatori ? Sau macar niste indicatii .
Cine ma ajuta si pe mine cu sharingul ?
Pentru a obtine o linie trebuie sa poti oferi si tu ceva la schimb,un card local,sau poti apela la un amic sa-ti ofere o linie,eu inca nu am nevoie de sharing doar am testat sa vad cam ce deschide in plus fata de keyle clasice dar se merita din plin!Quote:
A incercat cineva aceasta imagine? daca da,ce are bun fata de geminii 4? ca tot e laudata pe diverse forumuri din afara dar vreau sa aud o parere de la unul de ai nostri;
Nabilosat DM500 V. 0.8 MAXVAR
Technical Infos:
* Enigma: 10.05.2007
* Graphics additions by Nabilosat team
* Graphics Develop Consulting by Vali, Matrix, Army and Porto
* GCC Original CVS
* Web Interface: Nabilosat edition by Army
you can download languages from Nabilo addon panels and install in DM500 V 0.8
Great News for all Nabilosat Members
Here is the Nabilosat Image V. 0.8 for your Dm500
The main new of this version is that the skin system have been entirely recoded.
The new skin system is a singificative improvement in Nabilosat Images story.
This 0.8 version is MORE AND MORE STABLE AND FAST.
Many graphics objects have been added (Nabilosat Image v 0.8 is the first image in the world to have an Analogic Clock in the OSD).
There is a new way to manage extra/light skin.
In this 0.8 version, when OSD is shown you can press the button OK to have INSTANTLY the extra skin information on OSD.
You can set an option too to have a persistent clock on the television screen.
The new skin Validation 8 used all the new graphic improvments of the 0.8 versions with a very high quality style effect.
Warning: You can use only Skins for V. 0.8++ on this image
salut , eu am avut o cateva luni , merge fara probleme , acum am pus gemini 4.0.0. si zilele acestea cand voi avea timp mai mult voi reveni la nabilo 0.8 . noroc.Quote:
ps: din punctul meu de vedere , atuul acestei imagini e stabilitatea .
Intrebare -intrebatoare : pe Optibox merg toate subtitrarile in limba romana in special la GIGI ?(AXN, HBO Comedy, Digi 1&2 , TV1000, etc.)
Multumesc
Merg fara probleme,acolo unde nu iti apare subtitrarea apesi audio si selectezi romana si e ok,multumesc pentru raspunsul anterior la nabilo!
Am trecut si eu pe NABILO!! este super,e un pic diferit fata de geminii4 dar te obisnuiesti repede cu meniurile,orcum este mult mai avantajos nabilo dupa parerea mea,merita incercat!
As dori informatii despre Optibox in ce priveste blocajul ?
Cat de des si in ce conditii se blocheaza?
Cumpara-l linistit ca nu se blocheaza.Quote:
Originally Posted by don Pedro [Only registered and activated users can see links. Click Here To Register...]
Daca vrei sa-l blochezi pui imagini nefinisate sau il pui sa faca lucruri absurde ( eu am reusit cu MAC 00-00-00-00-00-00 :D ) .
Daca se blocheaza , il repornesti cu scoatere din priza .
Daca nici atunci => repui o imagine stabila prin serial .
Singurul blocaj care la avut a fost cu noua versiune geminii 4.1 cu restul de imagini merge impecabil,no problem!
Se blocheaza daca stergi skin in use sau ceva ce este folosit in setari , sau daca instalezi ceva si ai full memoria . Am patit chestia cu blocarea ptr ca l-am tot bip sa vad exact ce face fiecare chestie. Blocarile au fost doar din cauza mea , aparatul a rezistat , incerc tot ca doar e in garantie .
In sfarsit ma pot uita lejer la SHOWTIME 7W,dupa indelungi incercari am reusit sa deschid acest pachet SUPERRR! cu MgCamd-1.25 NewCS-130 si cu key luate de aici;
Vizionare placuta!
Dar niste pluginuri interesante cine ne recomanda ? Mie imi place deocamdata dreamcast_v02 ,DreamboxRSS_NewsRoom_2.0 ,TDZ-KODZ-Keybundle-Update. Oare ce imi scapa ? Ce e mai bine sa am ptr update on-line? Gbox se lasa asteptat , cred ca setarile la routerul Trendnet nu sant cele corecte si nici linie D nu am gasit la nimeni.
Am rezolvat si problema gbox-ului , dar ... cred ca am degeaba Optibox. Daca nu am card in receptor nu ma accepta nimeni in sharing , cardul pe care il am e in receptorul dedicat , si e cam riscant cu cititul datelor din el. Acum ce naiba sa fac ? Daca eram cu bani imi luam Dream original si mai faceam un abo.
