Elron ELTAY SC is a credit card-sized SBC powered by an Elvees SKIF “Scythian” quad-core...
Adafruit has recently released the Adafruit Sparkle Motion Stick, a compact, WLED-friendly Neopixel USB controller...
STMicroelectronics P-NUCLEO-IOD5A1 is a new modular IO-Link development kit designed to simplify building actuators and...
VIA AI Transforma Model 1 is an edge AI platform powered by a MediaTek Genio...
Radxa NIO 5A is an upcoming Mediatek Genio 520 SBC in credit card/Raspberry Pi form...
I’ve just received a review sample of Chipsee PPC-CM5-156 15.6-inch industrial panel PC that was...
Huawei Matebook Pro (HAD-W24 / HAD-W32) resembles a typical laptop with a 14.2-inch display, 24GB...
Renesas RZ/A3M is an Arm Cortex-A55 microprocessor (MPU) clocked at up to 1.0 GHz with...
Waveshare RA4M1-Zero is a mini development board built around the Renesas RA4M1 32-bit Arm Cortex-M4...
Boardcon has just introduced the LGA3576 system-on-module with a 330-pad LGA design powered by Rockchip...
The FlippenHeimer is a compact Geiger counter add-on module designed to work with the Flipper...
Shuttle showcased a wide range of devices at Computex 2025, including the FTL1 IoT Edge...
Graperain GR3576_CV2 is a 260-pin SO-DIMM system-on-module (SoM) powered by a Rockchip RK3576 octa-core Cortex-A72/A53...
Infineon PSoC 4100T Plus is a new low-power Arm Cortex-M0+ MCU designed for battery-powered or...
Apacer PT25R-Pi HAT SSD is an upcoming HAT for the Raspberry Pi 5 or compatible...
The Arduino Nano Connector Carrier is a compact add-on board designed for the Arduino Nano...
Silicon Labs has just introduced the first 22nm Series 3 SoCs with the SiXG301 and...
Realtek showcased RTL8126, RTL8157, and RTL8251B 5 Gbps Ethernet solutions at Computex 2023, and the...
The PocketBeagle 2 was first introduced with a 1.0 GHz Texas Instruments Sitara AM6232 dual-core...
The Protectli Vault Pro VP2430 is a compact, Intel Processor N150-based fanless network appliance designed...
