r3842 | alno | 2010-11-06 06:00:41 -0700 (Sat, 06 Nov 2010) | 1 line
Log: add readerlabel on thread startmessage
r3841 | alno | 2010-11-06 05:12:05 -0700 (Sat, 06 Nov 2010) | 1 line
WebIf: reset oscam version on non cccam-ext clients (mouseover status)
r3843 | alno | 2010-11-06 12:12:05 -0700 (Sat, 06 Nov 2010) | 1 line
WebIf: fix multiple DES key in newcamd config
Changeset #3844
Message: cccam: card updates optimized, duplicate cards (same cards from
different servers) removed, showing dropped dup count in log
cccam: fixed a big ecm-queue-bug, also fixed fallback requests not
resend to the same server (caused some timeout problems)
Oscam-1.00-svn3845
Changeset #3845
Message: Monitor: fix crash on send 'log' w/o arg
Oscam-1.00-svn3846
Changeset #3846
Message: cccam: fixed missing ecm processings
---------- Post added at 21:57 ---------- Previous post was at 20:57 ----------
Changeset #3847
Message: cccam: fixed: ecm processing
Changeset #3848
Message: Monitor: fix log w/o arg
Oscam-1.00-svn3849
Changeset #3849
Message: changed pending ecmtask table behaviour
Oscam-1.00-svn3850
Changeset #3850
Message: fix cccam reader restart segfault #1218 #1224 #1225
Oscam-1.00-svn3851
Changeset #3851
Message: WebIf: group reader stats 'not found'/ all other rc
Oscam-1.00-svn3852
Changeset #3852
Message: WebIf: add oscam.dvbapi to files section, disable reader from overview save to conf directly
r3853 | schlocke | 2010-11-08 08:00:28 -0800 (Mon, 08 Nov 2010) | 2 lines
cccam: fixed cmd05 handling
r3852 | alno | 2010-11-08 06:54:21 -0800 (Mon, 08 Nov 2010) | 1 line
Oscam-1.00-svn3854
Changeset #3854
Message: Minor cleanup and possible improvement of timing for AdTeknik MP3.x readers. If still not working perfect try changing the delays defined on the top of ifd_mp35.c
r3855 | lattjo | 2010-11-08 11:56:14 -0800 (Mon, 08 Nov 2010) | 1 line
rv should be LONG, not ULONG according to the documentation. Changed so the log does not confuse the reader by printing 512 bytes received when transaction fails.
r3854 | lattjo | 2010-11-08 11:13:22 -0800 (Mon, 08 Nov 2010) | 1 line
Oscam-1.00-svn3856
Changeset #3856
Message: cccam: reverted cmd05 changes from #3756
cccam: added client-timeout based on reader reconnect timeout
r3857 | _network | 2010-11-08 15:21:17 -0800 (Mon, 08 Nov 2010) | 2 lines
dvbapi: change type of event_handler mutex and add some emm filter log messages
r3856 | schlocke | 2010-11-08 12:53:18 -0800 (Mon, 08 Nov 2010) | 3 lines
