Pune la sfarsit drop.
Eu am facut reguli de filtrare dns in felul acesta din exterior pe portu de sharing ca sa nu mai am probleme de atacuri.
pune br-lan eu doar am facut pe varianta netestata.
Nu vrea sa plece cardul de sky pe smartgo am setat device = /dev/usb/tts3
sau /dev/ttyUSB3 si degeaba nu vede cardul daca pun pe ubuntul totul ok
Am instalat kmod-usb-serial-ftdi 2.4.35.4-brcm-2.4-1 installed Kernel support for FTDI USB-to-Serial converters
hub.c: new USB device 01:02.0-2.2, assigned address 6
usbserial.c: FTDI FT232BM Compatible converter detected
usbserial.c: FTDI FT232BM Compatible converter now attached to ttyUSB3 (or usb/tts/3 for devfs)
deci il vede smartgo-ul.
Logo oscam
2009/05/31 11:34:03 1111 s reader started (pid=1117, device=/dev/usb/tts3, detect=cd, mhz=357, cardmhz=357)
2009/05/31 11:34:03 1111 s waiting for local card init
2009/05/31 11:34:03 1117 r02 ERROR opening device /dev/usb/tts3
2009/05/31 11:34:03 1117 r02 Cannot open device: /dev/usb/tts3
2009/05/31 11:34:03 1116 h HTTP Server listening on port 10000
2009/05/31 11:34:07 1111 s init for all local cards done
2009/05/31 11:34:07 1111 s anti cascading disabled
2009/05/31 11:56:38 1149 s reader started (pid=1155, device=/dev/ttsUSB3, detect=cd, mhz=357, cardmhz=357)
2009/05/31 11:56:38 1154 h HTTP Server listening on port 10000
2009/05/31 11:56:38 1155 r02 ERROR opening device /dev/ttsUSB3
2009/05/31 11:56:38 1155 r02 Cannot open device: /dev/ttsUSB3
2009/05/31 11:56:38 1149 s waiting for local card init
2009/05/31 11:56:42 1149 s init for all local cards done
2009/05/31 11:56:42 1149 s anti cascading disabled
Am reusit sa fac filtrarea dupa IP si MAC.
Am verificat atat varianta lui Resofty, cat si varianta propusa de mine.
Amandoua merg f bine, insa cu o mare Observatie: Literele folosite la adresele de MAC trebuie scrise cu litere mici si mai este o eroare ultimul "- j" trebuie modificat in "-j" (fara spatiu).
Totusi cred ca exista o problema cu conectarea la PPPOE (RDS).
NU am reusit conexiunea pana nu am pdezinstalat LUCI si am instalat X-WRT ca interfata grafica. Acolo este o zona unde exista buton de "Conect / Disconect" si o bifa la "Use default route". In cele din urma s-a conectat insa nu mergeau toate siteurile si nici update ddns nu facea. Am vazut ca era din cauza ca la conexiunea PPPOE primeam IP insa nu aloca acel IP la adresa de MAC si nici nu imi atribuia DNSuri pt WAN. Tot din interfata web XWRT am avut posibilitatea de a adauga manual DNS pt. WAN. Dupa toate aceste modificari a inceput sa mearga internetul, a facut update si la Dyndns si serverul de CCCam merge OK acum.
Multumesc inca o data Resofty.
am pus si eu cccam 2.14 pe dd-wrt cu kernel 2.6 si imi da segmentation fault la sfarsit
aveti careva niste librarii bune?
Buna dimineata,puteti sa imi spuneti va rog frumos,dac se poate face server CCcam si pe altfel de routere,nu ma pricep prea bine,si as vrea sa imi fac si eu serverul pe router de exemplu pe asta Router Asus RX3041,
multumesc
@panter uite documenteazate aici
@guru96
Foloseste librariile de kernel 2.6
si doar astea sa fie in folderul de librarii auxiliare.Si daca functioneaza cu SF il lasi asa.
In primul rand, un ferm multumesc pentru tutorialul excelent(manual de instalare), referitor la OpenWRT si CCcam, acum 2 zlie am luat un astfel de router(Topex) si l-am pus la teste, initial a venit instalatat cu kernel 2.4 si kamikaze, am trecut la optiunea de boot de pe USB , cu cccam 2.1.1. Totul a mers perfect la instralare, montare dev..etc.Comparativ cu CCcam214 instalat pe azbox, 2.1.1 de pe topex nu se conecteaza la toate serverele si nu isi i-a toate cardurile(cazul meu, posibile limitari la vers.).
Am decis sa fac trecerea la K 2.6, B 10.03, CCcam 2.1.4, instalarea a decurs bine,cat si a pachetelor necesare.Cum zicea cineva in posturile anterioare instalarea din LuCI se face greoi, fiecare separat, dar le-am realizat prin terminal, la pachet..,functia de mount point LuCI lipsea si a trebuit si ea instalata (block mount..parca)dar se pare ca nu e functionala la reboot,( am modificat scripturile conforme cu partitiile din K2.6-sda) smargo e recunoscut prin USB2(ttyUSB0). Inca nu am gasit un mipsel 2.1.4 functional pe topex.
se mai poate un tutorial modificat pentru aceasta configuratie:OpenWRT,Kernel2.6 Backfire10.03 cu CCcam 2.1.4 inclusiv fisierele necesare, eventual si script pentru mount dev. dupa reboot cu sau fara boot de pe stick?
Multumesc,
Salut... am cumparat un Asus rt-n16 si am decis sa fac un server oscam-cccam ca sa imi eliberez calculatorul ...dar:
pe DDwrt nu mi-a mers nimic ..asa ca am trecut pe oleg... pt asus N16...
Oscam... am reusit.. am gasit un ipk pe forumul lor si mi-a instalat oscamul perfect.. cu smargo si suport pt cardul meu ( e un card de n*d*s pe providerul de aici de la kanguri ).
Acum... am incercat orice solutie de pe forumul asta si nimic nu mi-a mers pt cccam... tot imi da unexpected symbol sau segmentation fault...
nu sint un profesionist in linux si chiar nu stiu cum sa rezolv problema lol.. asa ca apelez la voi baieti... are cineva vreu ipk care sa mearga pe oleg ( sa faca direct linkul la librari si configurarile necesare pt CCcam sa mearga ) ?
Daca vrei sa faci treaba tot o poti face uitate la librariile alea care sunt pt kernel2.6 si ia din pachetul original care sunt pentru kernel2.4 le selectezi doar pe alea le pui intrun folder gol si o sa mearga.
pe fonera+ cu openwrt-gargoyle o merge?
Salut,
Ma tot chinui sa bag cardul de la tvr prin newcs1.67/cccam2.1.1 pe Kamikaze si nu reusesc deloc....
si aici newcs.xml:Code:This is NewCS 1.67 RC1 [Build: 95] - the New CardServer by the Butter-team..
Compiled on Jul 14 2009 at 11:58:28
Reading Config file from /opt/var/etc/newcs.xml
TCP-log password is enabled, set to: NewCSpwd
level: internal
type: all
output: console,tcp
logger config: level 16777215 type 255 output 5
Console log options: level 16777215 type 255
TCP log options: level 1 type 255
[ 14:17:15 ] [ Box detect ] Box type 12 (OpenWRT Router)
[ 14:17:15 ] [ Config ] Pincode for device 0 (phoenix): 0000
[ 14:17:15 ] [ SID ] Adding SID FFF720 on Reader 0 (phoenix) - SO is: 0 [Allow]
[ 14:17:15 ] [ SID ] Adding SID 25900 on Reader 0 (phoenix) - SO is: 0 [Allow]
[ 14:17:15 ] [ SID ] Adding SID 25910 on Reader 0 (phoenix) - SO is: 0 [Allow]
[ 14:17:15 ] [ SID ] Adding SID 0000 on Reader 0 (phoenix) - SO is: 0 [Allow]
[ 14:17:15 ] [ Config ] /dev/usb/tts/0 ECM priority: round
[ 14:17:15 ] [ Newcamd ] Server name : newcs
[ 14:17:15 ] [ Newcamd ] Des key : 0102030405060708091011121314
[ 14:17:15 ] [ Config ] Option <readers> not present for User: topex, NO reader control enabled
[ 14:17:15 ] [ Newcamd ] User 2: topex, Pass: topex, Host 192.168.2.5, Port: 34000, Au: On, Spider allowed: No, Sidoverride: No, level: 0
[ 14:17:15 ] [ httpd ] httpd-user: newcs, password: newcs, accesslevel: admin
[ 14:17:15 ] [ EMM Cache ] Initialising dynamic Cache
[ 14:17:15 ] [ ECM Cache ] Initialising dynamic Cache
[ NewCS ] Process ID is: 2128
[ 14:17:15 ] Calibrating delay loops
[ 14:17:15 ] usleep(5) takes: 0 s 25 us
[ 14:17:15 ] usleep(10) takes: 0 s 29 us
[ 14:17:15 ] usleep(100) takes: 0 s 117 us
[ 14:17:15 ] usleep(500) takes: 0 s 516 us
[ 14:17:15 ] Allocation memory for 200 regular users
[ 14:17:15 ] [ Loader ] Starting Telnet on port 1001
[ 14:17:15 ] [ SockSrv ] Server thread started
[ 14:17:15 ] [ Loader ] Started HTTP-server on port: 8080
[ 14:17:15 ] [ Loader ] Reader type 2 on node /dev/usb/tts/0
[ 14:17:15 ] [ CardMan ] Reseting reader parameters
[ 14:17:15 ] [ Phoenix ] Opening device /dev/usb/tts/0
[ 14:17:16 ] [ Phoenix ] Setting Parity to: ODD
[ 14:17:16 ] [ Phoenix ] Setting 2 Stop bits on node /dev/usb/tts/0
[ 14:17:16 ] [ Phoenix ] Setting Baud to standard 9600
[ 14:17:16 ] [ Phoenix ] Normal RESET on node /dev/usb/tts/0
[ 14:17:18 ] [ Serial ] Read on fd 8 (len=12 timeout=5300ms)
[ 14:17:18 ] Phoenix_read:
0000: 03 11 e7 ff ff bc d7 ff 7c e9 f6 ff ........|...
[ 14:17:18 ] [ CardMan ] Atr header is 3F 77 [INVERSE]
[ 14:17:18 ] [ ATR ] Data:
0000: 3f 77 18 00 00 c2 14 00 c1 68 90 00 00 00 00 00 ?w.......h......
0010: 00 .
[ 14:17:18 ] [ ATR ] T=0 1etu=8.68us Guardtime:12etu WWT:115200etu
[ 14:17:18 ] [ ATR ] Historical bytes: [C2] [14] [00] [C1] h [90] [00]
[ 14:17:18 ] [ Loader ] Init Viaccess card
[ 14:17:18 ] Card reader locked for reader phoenix [/dev/usb/tts/0]
[ 14:17:18 ] [ Phoenix ] Setting Parity to: ODD
[ 14:17:18 ] [ Phoenix ] Setting 2 Stop bits on node /dev/usb/tts/0
[ 14:17:18 ] [ Phoenix ] Setting Baud to standard 9600
[ 14:17:18 ] [ Viaccess ] Sending to Card: CAA4000000
[ 14:17:18 ] Phoenix_write:
0000: ca a4 00 00 00 .....
[ 14:17:18 ] [ Serial ] Write on fd 8 (len=5)
[ 14:17:18 ] [ Serial ] Read on fd 8 (len=5 timeout=1500ms)
[ 14:17:18 ] [ Serial ] Read on fd 8 (len=1 timeout=1300ms)
0000: 14 .
[ 14:17:18 ] [ Serial ] Read on fd 8 (len=2 timeout=1300ms)
0000: 00 c1 ..
[ 14:17:18 ] [ Viaccess ] Status Word from Card: 00C1
[ 14:17:18 ] Card reader unlocked for reader phoenix [/dev/usb/tts/0]
[ 14:17:18 ] [ Loader ] Card 0500 on port /dev/usb/tts/0 failed
[ 14:17:18 ] [ Card queue /dev/usb/tts/0 ] Starting...
[ 14:17:18 ] [ Loader ] Starting Newcamd Server on port 34000
[ 14:17:18 ] [ Newcamd ] Newcamd thread Server started on port 34000
newcamd: main loop
[ 14:17:18 ] [ NewCS ] Ready to GO! :)
root@OpenWrt:~# [ 14:17:22 ] [ Newcamd ] new connection from 192.168.2.5 on socket 10
[ 14:17:22 ] [ Newcamd:34000 ] Connection from 192.168.2.5
[ 14:17:22 ] [ Newcamd:34000 ] User topex logged in, client: CCcam
[ 14:17:22 ] [ Newcamd:34000 ] Connection topex to not-ready server!
cu parity EVEN imi da cu unknow card, pe ODD imi vede cardul ca fiind Viacces dar doar atat, nu reusesc sa ma conectez cu cccam din router; mgcamd, multicas din receiver la newcs.Code:<newcsconfig>
<readers name="Standard Phoenix on PC">
<globals>
<listening-ip>127.0.0.1</listening-ip>
</globals>
<device>
<name>phoenix</name>
<type>phoenix</type>
<mhz>357</mhz>
<baud>9600</baud>
<node>/dev/usb/tts/0</node>
<parity>odd</parity>
<reset>normal</reset>
<export>yes</export>
<enabled>yes</enabled>
<blocksa>no</blocksa>
<blockua>no</blockua>
<blockga>no</blockga>
<blockc0>yes</blockc0>
<crypto-special>no</crypto-special>
<carddetect>yes</carddetect>
<newcamd_port>34000</newcamd_port>
<Seca-PPV>no</Seca-PPV>
<pincode>0000</pincode>
<protectedsid>
<id></id>
</protectedsid>
<priority>round</priority>
<autosid>yes</autosid>
<sid>
<allow>
<id>fff720</id>
<id>25900</id>
<id>25910</id>
</allow>
</sid>
</device>
</readers>
<radegastserver>
<enabled>No</enabled>
<port>0</port>
<allow>all</allow>
</radegastserver>
<cache>
<emm>20</emm>
<ecm>-1</ecm>
</cache>
<httpd>
<server>
<port>8080</port>
</server>
<user>
<name>newcs</name>
<password>newcs</password>
<accesslevel>admin</accesslevel>
</user>
</httpd>
<debug>
<password>NewCSpwd</password>
<mode>simple</mode>
<level>internal</level>
<type>all</type>
<output>console,tcp</output>
<tcp_host>192.168.2.5</tcp_host>
<tcp_port>1001</tcp_port>
<tcp_options>normal,init</tcp_options>
</debug>
<newcamdserver>
<enabled>Yes</enabled>
<name>newcs</name>
<user>
<status>access</status>
<name>topex</name>
<password>topex</password>
<hostname>127.0.0.1</hostname>
<port>34000</port>
<au>on</au>
<spider>off</spider>
<sidoverride>off</sidoverride>
<rate>3</rate>
</user>
</newcamdserver>
</newcsconfig>
am schimbat aproape toti parametrii, dar nimic....sa inteleg ca newcs nu citeste bine cart.tvr pe acest kernel?
pentru cartela tvr am mai multe sanse cu oscam?
Merci,
Qwess , libs pentru smargo si config acestuia sunt OK ? Log-ul newcs arata ca nu ....
Ruleaza newcs 1.67 in azbox si conecteaza routerul/cccam la el . La mine merge perfect aceasta config. cu 1 hub si 2 cartele ; o mica deosebire : routerul e fritzbox cu patch onestep .
Sunt chiar impresionat de Asus WL-500g Premium v2. Cred că a fost cea mai bună investiţie din ultimii 2 ani. Rulez in momentul ăsta pe el 24 h/7 zile un server cccam, un server mbox, client de torrent (rtorrent, cu un hard disc conectat la router pe USB şi cu screen ca să-l ţină in background) şi unrar (dezarhivez nişte filme luate cu rtorrent pt a le transfera pe IPBox, din nou cu screen), mă uit la S** Ci**ma 1 HD prin cccam şi iată ce zice top (am şters ceea ce nu trebuie să se vadă;)):
Swap utilization:Code:Mem: 27692K used, 616K free, 0K shrd, 1192K buff, 19452K cached
CPU: 20% usr 78% sys 0% nice 1% idle 0% io 0% irq 0% softirq
Load average: 4.25 4.12 3.66
PID PPID USER STAT VSZ %MEM %CPU COMMAND
3907 3906 root R 5876 21% 21% unrar x /mnt/data/**********
43 1 root RW 0 0% 5% [usb-storage-0]
1027 1014 root R 116m 422% 2% rtorrent -n -O import=/mnt/home/root/
1072 1067 root S 2964 10% 2% /opt/mbox/mbox-2.4.openwrt /opt/mbox/
1089 1045 root S 30680 108% 1% /opt/cccam/CCcam.mipsel -fnvq -C /opt
4296 4005 root R 1672 6% 1% top
10 1 root SW 0 0% 1% [mtdblockd]
4 1 root SW 0 0% 1% [kswapd]
660 1 root S 1512 5% 1% wland
136 1 root S 1512 5% 1% resetbutton
1086 1045 root S 30680 108% 0% /opt/cccam/CCcam.mipsel -fnvq -C /opt
1005 1 root SW 0 0% 0% [kjournald]
1096 1045 root S 30680 108% 0% /opt/cccam/CCcam.mipsel -fnvq -C /opt
4003 271 root S 1936 7% 0% dropbear -b /tmp/loginprompt -r /tmp/
23187 1 root S 1136 4% 0% dnsmasq --conf-file=/tmp/dnsmasq.conf
3 1 root RWN 0 0% 0% [ksoftirqd_CPU0]
1085 1045 root S 30680 108% 0% /opt/cccam/CCcam.mipsel -fnvq -C /opt
1044 1 root S 30680 108% 0% /opt/cccam/CCcam.mipsel -fnvq -C /opt
2104 1045 root S 30680 108% 0% /opt/cccam/CCcam.mipsel -fnvq -C /opt
1046 1045 root S 30680 108% 0% /opt/cccam/CCcam.mipsel -fnvq -C /opt
Chiar cu download la viteză maximă şi nu-mi afectează card sharingul! Am avut uptime peste 30 de zile cu el (acum vreo 10 zile a picat curentul, altfel era mai mult). Sunt impresionat! Şi am mai găsit un avantaj: dacă mi se blochează IPBox-ul (la cit il butonez, săracul, i se intimplă cam o dată la 2-3 zile), cccam şi mbox rămin online.Code:root@ASUS:~# cat /proc/swaps
Filename Type Size Used Priority
/dev/scsi/host0/bus0/target0/lun0/part2 partition 257032 13024 -1
Asa am rulat pana acum, newcs 1.6.13 in azbox(cititor intern) si cccam 2.1.1 in router, ieri am trecut pe 1.67 in azbox prin smargo, testand cu succes chameleon2 intre cele 2newcs(router-azbox).Quote:
Originally Posted by valerica [Only registered and activated users can see links. Click Here To Register...]
Vroiam sa trec atat ccc cat si readerul pe router.
:cheers:
Aceeasi problema pe un Netgear WNDR3700 cu OpenWrt Backfire 10.03. Stie cineva daca exista vreo solutie ?Quote:
Originally Posted by ibiza [Only registered and activated users can see links. Click Here To Register...]
