aaf board....
aaf board....
n-ash preash crede :)Quote:
Originally Posted by dan2000 [Only registered and activated users can see links. Click Here To Register...]
mai stai o mana...
mo eu nu pot sa intru acolo si nu inteleg de ce . am primit in schimb mail de la ei.Quote:
Originally Posted by whitesnake [Only registered and activated users can see links. Click Here To Register...]
aici:
care se baga? :)
e2-USF910 [Only registered and activated users can see links. Click Here To Register...]
<<team DuckTales proudly presents the first enigma2 alpha image for Kathrein UFS-910.>>
a incercat cineva mgcamd pe katy ca si client gbox pe router ( wrt54gl ) ?
Video cu en2 care ruleze pe kathrein e identic cu dm800
AAF2.0-EM-Edition2008
noutati, ceva?
ca-mi vine si mie un k910...
AAF2.0-EM-Endspiel-Edition2008 Image for the UFS 910
Barry Allen & KCC included, with documentation.
functioneaza perfect cel putin la mine . cred ca e cea mai stabila img de pana acum.
Se poate download AAF2.0a Flash, ceva imbunatatiri+animatieboot pe display...
INSTALARE DISEQC1.2 CARE MI-A FUNCTIONAT CU TOATE IMAGINILE INCEPAND CU FW1.4 PANA LA AAF2.0 SI RUDEBOX 1.05
ATENTIE : IMEDIAT DUPA INSTALARE RESTART SI APARE NUMELE SATELITULUI PE DISPLAY LA KATHI IAR ANTENA PLEACA DUPA 3 SECUNDE DE LA COMANDA.....FOARTE RAPID !!!!!
1. In /data/bin : " diseqcsend1.2 " si
"diseqc_mon " care are urmatorul script :
#!/bin/sh
# diseqc_mon - diseqc monitoring script
sleep 3
if [ -f /data/diseqc/diseqc.cfg ]; then
cp -p /config/PROPERTY_TABLE /tmp/property.tmp
satellite=`/data/bin/curchan -satname | /data/bin/awk '{print substr($0,6)}'`
/data/vfdctl -c "$satellite" &
while :
do
if [ /config/PROPERTY_TABLE -nt /tmp/property.tmp \
-o /config/PROPERTY_TABLE -ot /tmp/property.tmp ] ; then
newsat=`/data/bin/curchan -satname | /data/bin/awk '{print substr($0,6)}'`
if [ "$newsat" != "" -a "$newsat" != "$satellite" ] ; then
satellite=$newsat
satpos=`grep "$satellite" /data/diseqc/diseqc.cfg | /data/bin/awk '{print $1}'`
if [ "$satpos" != "" -a "$satpos" != "255" ] ; then
/data/bin/diseqcsend1.2 224 49 107 $satpos 1>/dev/null 2>&1
fi
fi
fi
sleep 1
done
else
/data/vfdctl -c "No diseqc.cfg!" &
fi
2. In /data/diseqc : diseqc_cfg
3. In config " init.sh " cu urmatorul script :
!/bin/sh
# universelles Startscript by AAF-Team
# Swapfile aktivieren
#[ -e '/tmp/usb/VIDEO_DISC (1)/swapfile' ] && /bin/mkswap '/tmp/usb/VIDEO_DISC (1)/swapfile'; swapon '/tmp/usb/VIDEO_DISC (1)/swapfile'
#[ -e '/tmp/usb/VOLUME (1)/swapfile' ] && /bin/mkswap '/tmp/usb/VOLUME (1)/swapfile'; swapon '/tmp/usb/VOLUME (1)/swapfile'
#[ -e '/tmp/usb/USB_DISK (1)/swapfile' ] && /bin/mkswap '/tmp/usb/USB_DISK (1)/swapfile'; swapon '/tmp/usb/USB_DISK (1)/swapfile'
# Cifs aktivieren
insmod /data/bin/cifs.ko
# NFS mounten
# mount -t nfs 192.168.0.20:/mnt/IDE1/nas /mnt/nfs -o rw,nolock,intr,soft,udp,rsize=4096,wsize=4096
# Cifs mounten
# mount -t cifs //192.168.0.20/video /mnt/nfs/ -o user=harry,passwort=hase
# EPG auslagern
if [ -e /config/epg_move ]; then
cp /data/epg.dat /tmp/epg.dat
rm -f /data/epg.dat
ln -s /tmp/epg.dat /data/epg.dat
/data/vfdctl "EPG ausgelagert"
sleep 1
fi
# fuer Snapshot verlinken
ln -s /tmp/ /data/www/
# Http-Daemon starten
/bin/busybox httpd -h /data/www &
# Radio Infos auf VFD
if [ -e /config/radio_on ]; then
/data/bin/radioinfo -o 1 -d /data/plugins/radioinfo &
/data/vfdctl "Radioinfo gestartet"
sleep 1
fi
# Clock on display
if [ -e /config/time_show ]; then
/data/plugins/addon-man/Stime.sh &
/data/vfdctl "Stime gestartet"
sleep 1
fi
# Symbole im VFD Display
if [ -e /config/symb_off ]; then
/data/plugins/addon-man/symboff.sh &
fi
#HDD Standby nach 1 Min Untaetigkeit
#/data/plugins/stbauto.sh &
# DiseqC 1.1/1.2 autoswitch
/data/bin/diseqc_mon &
# OSD Menue starten
/data/menue/make_dev.sh
/data/plugins/osd/osdsh.sh
Salut
Am si eu un UFS910 de cateva zile. Mi-am montat antena pe HB 13E si as vrea sa prind si eu macar 1 program HD. Nu stiu ce si cum se configureaza. Ma puteti ajuta cu niste sfaturi sau o documentatie?
Thanks
hello nimic nou de 2 saptamani pt. acest receiver, a "murit" pe acest forum pacat.
Nu Kathrein este problema. Problema se afla in firea noastra de romani: dorim sa ne rezolvam problema fara a ajuta si noi pe cineva.
Sfatul meu este sa postezi problema ta punctual pe un site "de afara".
