M5Stack’s Unit Gateway H2 is a small Thread/Zigbee gateway powered by the ESP32-H2-MINI-1 module with...
Waveshare has just released the CM5-NANO-B, a compact Raspberry Pi CM5 carrier board, with the...
Jetway F35-ASL1 3.5-inch subcompact SBC is built around the Intel Atom x7433RE (Amston Lake) processor...
“M5Stamp PLC Controller with M5StampS3” or just “M5Stack StamPLC” is a programmable logic controller (PLC)...
Axiomtek GMB850 is a mini-ITX motherboard powered by up to 14th Gen Intel Raptor Lake-Refresh...
We’ve been writing about some low-cost KVM over IP solutions like the Sipeed NanoKVM Cube...
Most uninterruptible power supplies (UPS) require AC voltage and use specific batteries that must be...
Forlinx FET3506J-S system-on-module (SoM) is based on a Rockchip RK3506J SoC, the industrial version of...
Microchip AVR SD family of low-cost 8-bit microcontrollers (MCUs) feature built-in functional safety (FuSa) mechanisms...
The NVIDIA JetPack SDK has been based on Ubuntu ever since it was created (although...
u-blox has recently announced the world’s smallest L1, L5 dual-band GNSS module with an integrated...
We’ve just received the LaserPecker LP5 20W Fiber Laser + Diode Laser engraver for review...
SOMDEVICES µSMARC RZ/V2N is a system-on-module powered by the Renesas RZ/V2N AI MPU and offered...
Linus Torvalds has just announced the release of Linux 6.14 on LKML: So it’s early...
Shelly Group has just launched its Gen4 multi-protocol smart switch family supporting Wi-Fi, Bluetooth, Zigbee,...
SparkFun has just launched the “IoT RedBoard – RP2350” and “IoT RedBoard – ESP32” boards...
EDATEC ED-IPC3630 is an industrial PC (IPC) built around the Raspberry Pi Compute Module 5...
Developed by Rootkit Labs in Switzerland, the Flipper Blackhat is an open-source Allwinner A33-based Flipper...
Raspberry Pi has just released the rpi-image-gen build system to generate custom Raspberry Pi images...
8086 Consultancy has designed a simple board called the Pico Indicator to add LEDs to...
