LILYGO T-Connect Pro is a DIN rail-mountable, ESP32-S3-based industrial IoT controller with Ethernet, WiFi 4,...
Makerfabs has recently introduced Matouch 1.28-inch ToolSet_AC Dimmer an open-source ESP32-based AC voltage controller for dimming...
NextPCB has started offering free PCBA prototypes for PCB designs based on the ESP32-S3 wireless...
Security is hard. Just as Espressif Systems announced PSA Level 2 for the ESP32-C6 microcontroller,...
ASRock has recently released the iEP-7040E series which are Arrow Lake-H industrial IoT controllers powered...
The Adafruit Metro RP2350 is a Raspberry Pi RP2350 development board that closely follows the...
I’ve already checked out the hardware of the UP Squared 7100 fanless SBC in the...
While the Orange Pi RV RISC-V SBC introduced at the Orange Pi Developer Conference 2024...
Renesas has recently introduced the RZ/V2N low-power Arm Cortex-A55/M33 microprocessor designed for machine learning (ML)...
Variscite VAR-SOM-AM62P is a system-on-module powered by Texas Instruments Sitara AM62P5 quad-core Cortex-A53 + Cortex-R5F...
Unveiled at Embedded World 2025, Thundercomm’s TurboX C6690 is a SoM (System-on-Module) powered by a...
Semtech LR2021, the first chip in the LoRa Plus family, supports LoRa Gen 4 technology...
Yesterday, we wrote about the world’s smallest microcontroller (TI MSPM0C1104), which measures just 1.38mm2 in...
Microchip Technology PIC32A is a new family of 32-bit microcontrollers clocked at up to 200...
Geehy Semiconductor has introduced the G32R501 Cortex-M52 industrial AI MCU, the industry’s first real-time MCU...
AMD has just introduced the 5th Gen AMD EPYC Embedded 9005 Series “Zen 5” processors...
Texas Instruments (TI) has expanded the MSPM0 Arm Cortex-M0+ MCU family with the MSPM0C1104 which...
Synaptics unveiled an extension to its Astra Native AI platform with the new SR series...
Consumer-grade heat pipe cooling solutions typically rely on water as a working fluid. This works...
I’ve just reviewed the SunFounder 10.1-inch touchscreen display with Raspberry Pi 5 running Raspberry Pi...
