multumesc, functioneaza
cum se introduce in oscam.server o linie N?
eu am incercat si imi apare ca si UNKNOWN.
[reader]
enable = 1
label = newcamd-reader1
protocol = newcamd
device = host,port
user = user
password = pass
group = 1
emmcache = 1,1,2
se schimba cu ce primesc linia N?
Exista plugin filmon pentru Enigma 2 (SH4) ?
N-am schimbat nimic, dar SuperIptv nu mai funcţionează , apare "Illegal URL". La voi?Quote:
Originally Posted by satcodx [Only registered and activated users can see links. Click Here To Register...]
Aţi reuşit careva să vedeţi (prin oricare din metode, inclusiv [Only registered and activated users can see links. Click Here To Register...]) ceva posturi romaneşti prin internet (exceptand West Tv Arad şi Alfa şi omega, m-ar interesa Digi-urile locale , de ex.)?
Da exista ... integrat in pluginul Mediaportal si functioneaza bine pe AlienQuote:
Originally Posted by tempuser [Only registered and activated users can see links. Click Here To Register...]
am pusQuote:
Originally Posted by costy [Only registered and activated users can see links. Click Here To Register...]
[newcamd]
port = 12000@0B02:000000
keepalive = 1
in oscam.conf
si ce mi-ai dat tu, dar totii userii au fost OFF
ma poati ajuta cu configurarea?
[global]
logfile = stdout
disablelog = 1
disableuserfile = 1
preferlocalcards = 1
saveinithistory = 1
lb_mode = 1
lb_save = 100
lb_nfb_readers = 3
[newcamd]
port = 34000@0B02:000000
keepalive = 1
[cccam]
port = 12000
reshare = 1
version = 2.1.3
stealth = 1
reshare_mode = 0
[dvbapi]
enabled = 1
boxtype = dreambox
user = alien
pmt_mode = 1
request_mode = 0
[webif]
httpport = 84
httpuser = user
httppwd = pass
httprefresh = 10
httpallowed = 127.0.0.1,192.168.0.1-192.168.254.254
asa merge sigur
poti imi dai exemplu de linie N
reader
si
user
Ti-am dat configuratia ,editezi in oscam.server
[reader]
enable = 1
protocol = newcamd
device = host,port
user = user
password = pass
group = 1
emmcache = 1,1,2
[reader]
enable = 1
label = newcamd-reader2
protocol = newcamd
device = host,port
user = user
password = pass
group = 1
emmcache = 1,1,2
etc ...
Daca tot nu functioneaza linia N mai verifica si portul, este deschis sau nu... altfel poti sa-l editez fisierele de configurare pana la moarte fara succes.
Dacă primeşti linie N nu trebuie să setezi Newcamd in oscam.conf şi nici să deschizi port in router; dacă dai atunci DA, ambele.
---------- Post added at 11:07 ---------- Previous post was at 11:05 ----------
@ costy, nu i-ai dat şi exemplu de user.
eu am gresit ca am folosit portul pentru N cel de la C
acum am pus port separat pentru N
daca se poate un exemplu pentru USER
multumesc
As of 22. May 2013, the Data Source (Yahoo! Weather) for the Amiko Alien / Alien 2 Weather Forecaster service has started send
ing corrupted data to the Amiko Alien models. This data is automatically stored inside the Set-Top Boxes’ memory, and is loaded
during startup, causing certain receivers to fail to start or fail to respond to Remote Control commands. If your Spark receiver
is still functioning correctly, You do not need to do anything to avoid the issue, since the Weather Forecast function has been
disabled globally until the issue has been resolved. If your Set-Top Box has been affected by this issue and therefor can not start
up, please follow this guide to recover the Set-Top Box.
