(PR) G.SKILL Reveals World's First Large Capacity 256 GB (64 GB x4) DD
G.SKILL International Enterprise Co., Ltd., the world's leading brand of performance overclock memory and PC components, is thrilled to unveil DDR5 memory with an ultra-high kit capacity of 256 GB (64 GB x4), overclocked to DDR5-6000 CL32. Built with high-performance SK hynix DDR5 ICs, this overclock memory speed and timing pushes the boundaries of memory overclocking by fully loading 4 modules of high-capacity DDR5 64 GB U-DIMM modules on a single system; marking a new milestone for high-performance computing, content creation, AI applications, and advanced workstation workloads.
Overclocked, Ultra-Capacity 256 GB (64 GB x4) at DDR5-6000 CL32 In content creation and recent advancements in AI, the need for higher DRAM capacity is essential. Whether calculating large language models or working with complex or high-resolution video content, high-speed memory of high-density 64 GB modules would help to provide a smoother and more efficient workflow. Loaded with AMD EXPO memory overclock profiles, see the DDR5-6000 CL32 256 GB (64 GB x4) kit being stress-tested in the screenshots below on the ASUS ROG CROSSHAIR X870E HERO motherboard with the AMD Ryzen 7 9800X3D desktop processor, as well as on the MSI MPG X870E CARBON WIFI motherboard with the AMD Ryzen 9 9900X desktop processor.[Only registered and activated users can see links. Click Here To Register...]
(PR) ASUS Republic of Gamers Unveils Crosshair X870E Extreme, Apex Mot
ASUS Republic of Gamers today announced the ROG Crosshair X870E Extreme and ROG Crosshair X870E Apex, which join the previously-released ROG Crosshair X870E Hero to triple the number of premium ASUS motherboard options for high-end AMD Ryzen systems. Equipped with premium components, heavy-duty power solutions, and offering next-level connectivity options, these motherboards cater to those who dare to build a PC that shatters boundaries. ASUS AI Advisor, available within the ASUS DriverHub app, can help users learn all about this new hardware and get performance tips.
The ROG Crosshair X870E Extreme carries forward the AMD Ryzen 9000 Series of ROG motherboards with a no-holds-barred feature set and an all-new design that exudes luxury. Its massive power solution unleashes the full potential of new CPUs. 20+2+2 power stages effortlessly slake the thirst of the top-end AMD Ryzen 9 9950X3D, even when firing on all cylinders. Thick-and-tall VRM heatsinks keep the power circuitry operating comfortably, while 8+8 ProCool II power connectors with solid pins give the CPU a direct line to the power supply.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Huawei Prepares 6 nm Ascend 920C Accelerator: 900 TeraFLOPS, 4000 GB/s
Huawei recently revealed that its [Only registered and activated users can see links. Click Here To Register...] cluster can outperform NVIDIA's GB200 NVL72 in standard benchmarks, even though it consumes more power per performance unit. That system relies on Huawei's current Ascend 910C accelerators, which deliver strong raw compute performance but lag behind in efficiency metrics. To address this gap, Huawei is preparing the Ascend 920 family, with the training‑focused Ascend 920C built on SMIC's 6 nm process. According to DigiTimes, each 920C card will deliver more than 900 TeraFLOPS of BF16 half-precision performance. It also upgrades memory to HBM3 modules, providing 4,000 GB/s of bandwidth, which is up from the Ascend 910C's eight HBM2E stacks and 3,200 GB/s.
The existing Ascend 910C peaks at 780 TeraFLOPS in BF16 operations and uses a chip‑to‑chip interconnect bandwidth of 400 GB/s. Its packaging limits that bandwidth, but it still supports high‑speed communication between nodes in ultra‑dense AI clusters. Huawei will retain the chiplet‑based design in the 920C and refine the tensor acceleration engines for Transformer and Mixture‑of‑Experts models. Internal projections estimate that overall training efficiency on the 920C will improve by 30-40 percent compared to the 910C. This should narrow the performance‑per‑watt difference against competitors' solutions. In terms of system integration, the Ascend 920C will support PCIe 5.0 and next‑generation high‑throughput interconnect protocols. These features aim to improve resource scheduling and reduce latency in super node deployments, where tight node‑to‑node synchronization is critical. Huawei has not announced a firm release date for the Ascend 920C, but DigiTimes sources claim that it will enter mass production in the second half of 2025, which could mean just a few months from now.[Only registered and activated users can see links. Click Here To Register...]
Intel Job Listing Suggests Company Implementing GDDR7 with Future GPU
A recent job listing at Intel for a memory sub-system validation engineer—a person that tests and validates memory with new types with prototype silicon, suggests that Intel is implementing the contemporary GDDR7 memory standard with an upcoming GPU. The position calls for drive-and-deliver pre- and post-silicon validation and characterization of GDDR6 and GDDR7 memory types on Intel's Arc GPU products. Given that Intel is putting this listing out now, in Q2-2025, an actual product that implements GDDR7 could be rather far out, considering typical GPU silicon development timelines. We predict such a chip could be taped out only by 2026, if not later.
A possible-2026 tapeout of a GPU silicon implementing GDDR7 points to the likelihood of this being a 3rd Gen Arc GPU based on the Xe3 "Celestial" graphics architecture. Given Intel's initial success with the Arc B580 and B570, the company could look to ramp up production of the two through 2025, and continue to press home its advantage of selling well-priced 1080p-class GPUs. Intel could stay away from vanity projects such as trying to create enthusiast-class GPUs, sticking to what works, and what it could sell in good volumes to grab market share. This is a business decision even AMD seems to have taken with its Radeon RX RDNA 4 generation.[Only registered and activated users can see links. Click Here To Register...]
Intel "Nova Lake-S" CPUs to use LGA 1954 Socket, 24 x 25 mm Chipset
Based on recent shipping manifests that point to custom test hardware for its next "Nova Lake‑S" processors, Intel seems to be gearing up for a big desktop platform update. According to documents obtained by NBD.ltd, Intel isn't moving full motherboards yet. Instead, it's sending out mechanical interposers and re-balling jigs for an 888‑ball BGA chip. Those tools, likely meant for the upcoming 900‑series PCH, aren't finished products but specialized fixtures used to check voltage regulation during assembly. Right now, desktop builders are tied to the LGA‑1700 socket, but Nova Lake‑S is expected to adopt LGA 1954, which offers 1,954 active lands (and possibly more than 2,000 total pads when you count debug pins). That boost in pin count could allow Intel to expand power delivery and I/O without compromise. Still, anyone holding out for Nova Lake‑S will have to wait. Intel plans to roll out "Arrow Lake Refresh" later this year, with Nova Lake‑S not arriving until 2026.
Under the "NVL‑S" codename, Nova Lake is said to combine two clusters of eight high‑performance "Coyote Cove" P‑cores with 16 "Arctic Wolf" E-cores, plus four ultra‑low‑power LPE cores in a separate SoC tile. That layout would create a 52‑core hybrid chip, though Intel engineers are reportedly still fine‑tuning the exact mix before tape‑out. The new south‑bridge package measures about 25 × 24 mm (around 600 mm²), slightly smaller than the 650 mm² footprint used by today's 800‑series chipsets. Shipping lists reveal jig sizes from roughly 38 × 28 × 6.97 mm up to 50 × 50 × 6.32 mm, which tells us multiple fixture types are being used in test labs around the world. Additionally, moving from LGA‑1851 to LGA‑1954 could hint at a longer‑lived socket, but Intel's history suggests most desktop platforms span just two generations. Whether Nova Lake‑S or any future "Razer Lake" follow‑up will fully exploit this new interface remains to be seen. We are watching closely as more concrete specs emerge ahead of that 2026 launch.[Only registered and activated users can see links. Click Here To Register...]
AMD Readies Radeon PRO W9000 Series Powered by RDNA 4
AMD is readying a new line of professional graphics cards based on its latest RDNA 4 graphics architecture. The company has assigned the silicon variant "Navi 48 XTW" to power its next flagship pro-vis product, which will likely be branded under the Radeon PRO W9000 series. According to the source of this leak, the card comes with 32 GB of memory, which is probably ECC GDDR6, across the chip's 256-bit wide memory bus. The product should offer the same core-configuration as the Radeon RX 9070 XT gaming GPU, with 64 compute units worth 4,096 stream processors, 128 AI accelerators, 64 RT accelerators, 256 TMUs, and 128 ROPs.
Besides professional visualization, AMD could target the AI acceleration crowd. The company is hosting the "Advancing AI" press event in June, where it is widely expected to announce its next-generation AI GPUs and updates to ROCm. It could also use the occasion to unveil the Radeon PRO W9000 series product, promoting them to the AI acceleration crowd.[Only registered and activated users can see links. Click Here To Register...]
This Week in Gaming (Week 16)
Welcome to the last full week of April and this week we have a packed week of new games, especially if you're into various types of RPG games. This week's major release is a RPG that takes place in a Belle Époque inspired world. This is followed by a more traditional RPG game with swords and dragons, a horror survival game, a futuristic RPG with mechs, some classic RTS action with a familiar vibe and finally a Lovecraft inspired horror adventure. There are loads of other games launching this week as well, so check them out at the bottom of the list.
[Only registered and activated users can see links. Click Here To Register...] / This week's major release / Thursday 24 April
Explore an enchanting realm populated by surreal adversaries. Wander through breathtaking landscapes, from the Island of Visages to the Forgotten Battlefield, discovering secrets and hidden quests along the way. Find allies of fortune in creatures of legend. Recruit special companions to access new travel methods and discover secret areas in the World Map. [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) EA & Lucasfilm Games Announce Star Wars Zero Company, a Turn-Base
At Star Wars Celebration Japan, Electronic Arts Inc. revealed Star Wars Zero Company, a single-player turn-based tactics game developed by Bit Reactor in collaboration with Respawn Entertainment and Lucasfilm Games. In Star Wars Zero Company, players will step into the shoes of Hawks, a former Republic officer, to command an elite squad of cunning operatives through a gritty and authentic story set in the twilight of the Clone Wars. As an unconventional outfit of professionals for hire hailing from across the galaxy, Zero Company must set aside their differences to overcome nearly impossible odds and take on an emerging threat that will consume the galaxy if left unchecked.
"Our vision for Star Wars Zero Company is grounded in gameplay design pillars that weave in the immersive Star Wars galaxy with engaging turn-based tactics gameplay," said Greg Foertsch, CEO and Creative Director at Bit Reactor. "It's our aim to deliver a game with an original Star Wars story from the Clone Wars era that has meaningful outcomes from player choices, and deep turn-based tactical combat with an approachable and cinematic presentation."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) FSP Group Partners with Intel to Launch Energy-efficient and Back
Facing global challenges of energy conservation, carbon reduction, and sustainable development, Intel has been committed to pushing the industry toward higher performance and lower energy consumption product standards, actively leading the PC ecosystem toward a dual track of environmental protection and innovation. FSP Group, as Intel's long-term strategic development partner, shares the same philosophy and has continuously invested in power supply technology innovation with Intel's support, particularly focusing on 12VO architecture design that complies with the latest energy efficiency regulations.
At the Intel Client Ecosystem Symposium, FSP showcased its latest V3 version of TFX 12VO PSU, which not only helps brand customers build compliant PC systems but also contributes to carbon reduction and environmental protection with a design that balances high performance and energy efficiency.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Productivity Meets Gaming with Razer's New Ergonomic Pro Click V2
Razer, the leading global lifestyle brand for gamers, today announced the launch of its new line of productivity focused wireless mice, Razer Pro Click V2 Vertical Edition, and Razer Pro Click V2. Designed for users who want to integrate gaming products into their work setup, the new Razer Pro Click V2 mice emphasize ergonomic comfort, offering all-day support with gaming precision.
Ergonomic excellence for all-day comfort
Built with ergonomics in mind, Razer Pro Click V2 Vertical Edition is the brand's first wireless vertical ergonomic mouse. It features a 71.7º angle that mimics a natural handshake grip, reducing strain during prolonged use. The extended thumb rest keeps the hand relaxed as the base support elevates the wrist for smoother movements.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Block Ads on YouTube and the Web With This $16 Lifetime App
Online chaos doesn't just come from pop-up ads or autoplay videos—it's in hidden trackers, shady websites, and data leaks that turn a simple scroll into a security risk. If you're managing devices for the whole family, things can get out of hand fast. That's where [Only registered and activated users can see links. Click Here To Register...] steps in. Right now, you can grab lifetime access for just $15.97 using code FAMPLAN at checkout at StackSocial through April 27 (reg. $169.99).
This all-in-one [Only registered and activated users can see links. Click Here To Register...] blocks ads, filters out malicious websites, and protects up to nine devices from prying eyes. Whether you're trying to stream without interruptions, game without lag, or ensure your kids aren't falling into sketchy internet rabbit holes, AdGuard's got it covered.
Get lifetime protection for your whole household with this [Only registered and activated users can see links. Click Here To Register...]. AdGuard's Family Plan is $15.97 with code FAMPLAN at checkout until April 27 at 11:59 p.m. PT (reg. $169.99).[Only registered and activated users can see links. Click Here To Register...]
(PR) Green Hawk Platoon Debuts Animated Short: "Meet the Rifleman"
RetroPixel Digital and MicroProse are excited to unveil the first animated short in the Green Hawk Platoon character spotlight series: "Meet the Rifleman". This humorous introduction brings to life the game's most disciplined (and perhaps overly enthusiastic) class—the Rifleman.
In this animated feature, viewers get an up-close look at the Rifleman's personality, gameplay style, and unique abilities. Armed with classic toy-inspired weaponry and an unwavering commitment to the rulebook, the Rifleman is the dependable all-rounder every squad needs—even if his teammates didn't ask for it.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Lexar Launches New Line of PCIe 4.0 and PCIe 5.0 SSDs Designed to
Lexar, a leading global brand of flash memory solutions, is excited to announce the NQ780 M.2 2280 PCIe 4.0 NVMe SSD and the Professional NM1090 PRO PCIe 5.0 SSD, designed to provide the peak performance needed to keep every game running smoothly.
The Professional NM1090 PRO PCIe 5.0 SSD delivers speeds up to 14,000 MB/s read and 13,000 MB/s write to provide superior performance for professional-grade systems. Its 6 nm controller optimizes heat control for more efficient performance and customers can pair it with an AMD Ryzen or Intel i9 processor for a next-level game experience. The drive features DRAM Cache and SLC dynamic cache to greatly enhance data transfer speeds to reduce wait times and improve system responsiveness.[Only registered and activated users can see links. Click Here To Register...]
Intel's Software-Defined Vehicle Strategy: "Frisco Lake" and "Grizzly
At the 2025 Shanghai Auto Show, Intel revealed its next-generation automotive system-on-chip lineup, unveiling two ambitious platforms, "Frisco Lake" and "Grizzly Lake". The company described these new designs as key steps toward fully software-driven vehicles, where much of the intelligence is handled by high-performance processors instead of dedicated hardware circuits. Intel said these chips would support advanced driver assistance and richer multimedia features. Intel's second generation Software Defined Vehicle, or SDV, Frisco Lake, is built on the upcoming "Panther Lake" architecture. The first volumes are expected in the first half of 2026, and TDP options will be among 20-65 W to meet different use cases. Intel says Frisco Lake will deliver ten times more AI performance and sixty-one percent better energy efficiency compared to the current Raptor Lake-based platform.
The new graphics block is based on the third-generation Xe architecture, known as "Celestial", replacing the older Battlemage design. Frisco Lake also supports twelve simultaneous camera inputs and up to two hundred and eighty audio channels. Linux kernel patch analysis also shows Frisco Lake cores are based on Panther Lake, confirming Intel's adaptation of its client CPUs for automotive use. Looking further ahead, Intel shared an early roadmap for its third-generation SDV platform, Grizzly Lake, which should arrive in the first half of 2027. Codenamed Monument Peak, these chips will use "Nova Lake" cores and may offer up to 32 efficiency-optimized cores along with an integrated Xe GPU capable of about seven TeraFLOPS. Additional features include support for six independent displays, twelve camera interfaces, and compliance with automotive safety standards.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
How Do HKMLC Smart Boards Help in Teaching?
Chalkboards are an old-school thing now. About 67% of global classrooms now have adopted interactive technology, such as smart boards, to keep up with the times (UNESCO 2023 report). But how exactly do smart boards improve teaching? Let's dive into it, using [Only registered and activated users can see links. Click Here To Register...] as a real-world example—and answer some of the most common questions teachers ask.[Only registered and activated users can see links. Click Here To Register...]
How HKMLC Smart Boards Solve Real Classroom Challenges
1. Boosting Student Engagement
Static whiteboards hardly keep students focused, especially those K-12 education learners. HKMLC interactive whiteboards change the game with dynamic and interactive lessons. Teachers can easily explain abstract concepts with videos, images, and 3D models. With the [Only registered and activated users can see links. Click Here To Register...] smart board, educators can launch quizzes and include Kahoot! Learning games to increase participation. Multiple students can draw on the screen as if using a tablet—all thanks to its 20-point multitouch display and ultra-precise 2 mm positioning.
For more information and to purchase, [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
PowerColor Radeon RX 9070 GRE Red Devil & Reaper Models Leaked
Industry insiders have [Only registered and activated users can see links. Click Here To Register...] about AMD delaying the launch of [Only registered and activated users can see links. Click Here To Register...] graphics cards into the fourth quarter of 2025. Earlier leaks suggested a potential surprise arrival at some point in May (early next month), ahead of rumored wallet-friendly Radeon RX 9060 XT 16 GB and 8 GB models. In another bizarre turn of pre-release events, VideoCardz has acquired promotional shots of two—alleged—PowerColor Radeon RX 9070 GRE 12 GB custom designs. The online news outlet seems to have a [Only registered and activated users can see links. Click Here To Register...] to a source familiar with goings-on—within or adjacent to—the Taiwanese company.
Familiar images of flagship and entry level cards have emerged from an unnamed figure—reportedly, the manufacturer has reused its existing portfolio of RDNA 4 generation shroud and backplate designs. Curiously, a mid-tier Hellhound GRE card was not included in a recent NDA-busting exchange. VideoCardz believes that the exact same Red Devil enclosure—present on Radeon RX 9070 XT and RX 9070 siblings—is up for repeat business. A significant difference seems to be the reported utilization of two 8-pin power connectors (versus three on the flagship), and a minimum requirement of a 650 W-rated PSU. March-time whispers suggested a forthcoming mass production of board partner Radeon RX 9070 GRE cards; so the sudden appearance of two PowerColor SKUs seems to semi-verify older online claims. VideoCardz posits that AMD is deliberately seeding "incorrect information" within insider knowledge channels.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Report: Global PC Shipments Up 6.7% YoY in Q1 2025 Amid US Tariff
Global PC shipments grew 6.7% YoY in Q1 2025 to reach 61.4 million units, according to Counterpoint Research's preliminary data. The growth was mainly driven by PC vendors accelerating shipments ahead of US tariffs and the increasing adoption of AI-enabled PCs amid the end of Windows 10 support. However, this surge may be short-lived, as inventory levels are likely to stabilize in the next few weeks. The impact of the US tariffs is expected to dampen the growth momentum in 2025.
Apple and Lenovo delivered strong performances in the quarter, largely due to new product launches and market dynamics. Apple experienced 17% YoY growth in shipments, driven by its AI-capable M4-based MacBook series. Lenovo's 11% growth reflected its expansion into AI-enabled PCs and its diversified product portfolio. Lenovo remained the brand with the largest market share during the quarter. HP and Dell, on the other hand, benefited from the US market pull-ins during the quarter, with 6% and 4% YoY growth respectively, and maintained their second and third places in Q1. We also found that the pull-ins happened for other major brands too ahead of the tariff uncertainty, leading to the market share further consolidating around major brands.[Only registered and activated users can see links. Click Here To Register...]
(PR) Discord Co-founder/CEO Announces Successor
Hi everyone—I have some big news to share, so I'll cut right to the chase: we have hired a new CEO to lead Discord through our next chapter of growth and someday becoming a public company. I am thrilled to share that Humam Sakhnini will take on this role, and I will continue as a member of our Board of Directors and Advisor to the CEO. Read on for the details. Building Discord has been one of the most rewarding experiences of my life. From the very beginning, our mission has been about bringing people together around games. It's a mission I've dedicated my career to, and seeing it come to life through all of you and the impact we've made together has been nothing short of extraordinary. I've learned more than I ever imagined I would, and I'm deeply grateful for so many friendships, challenges, and achievements along the way.
As we enter our next phase, I've been reflecting on how I can best contribute to Discord's long-term success. The job of a CEO is constantly evolving, and over the years I have continuously "hired myself out of a job." Usually that means delegating work and then taking on different leadership challenges. However, as I look at what is needed of Discord's CEO over the next few years, I realize that it's time for me to literally "hire myself out of a job." One thing I know for sure: our company is bigger than any one person. Its future depends not just on me, but on a strong leadership team, a clear vision for what comes next, and all of your incredible talent, care, and hard work. Today's Discord has all of that. It's by far the best version of the company we've ever had. We have a clear strategy, new business lines to grow into, love and passion from our users, and an incredible team of people working tirelessly to deliver for them.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
COLORFUL Launches iGame GeForce RTX 5080 Vulcan W Quad-fan Flagship Mo
COLORFUL [Only registered and activated users can see links. Click Here To Register...] its premium [Only registered and activated users can see links. Click Here To Register...] SKU earlier this year; complete with a mounted angle-adjustable 5th generation iGame Smart LCD screen. As of this week, the already launched standard black model is accompanied by a pale sibling—the manufacturer describes this new entry as sporting "snow-white armor." This spin-off is advertised as redefining the "visual language of high-end graphics cards." Unlike [Only registered and activated users can see links. Click Here To Register...] lower end custom "Blackwell" gaming graphics cards, the quad-fan Vulcan W model gets special PR treatment—as demonstrated by COLORFUL's slick photo shoot and high-minded marketing blurb.
The Chinese AIB announced a retail launch—as of yesterday, their iGame GeForce RTX 5080 Vulcan W design headed to retail. Their own webstore and other regional platforms (JD, Tmall, Douyin, etc.) have started selling this SKU—the official starter price is 12,999 yuan (~$1784 USD). TechPowerUp's W1zzard [Only registered and activated users can see links. Click Here To Register...] a related (black) GeForce RTX 5080 Vulcan OC model; this triple-fan card was awarded with a "but expensive" badge—thanks to a potential $1300+ price point. COLORFUL's freshly introduced "pure white" flagship seemingly borrows cooling solution design inspiration from a key rival; the [Only registered and activated users can see links. Click Here To Register...]. A fourth 107 mm "sickle blade" fan is mounted on the Vulcan W's backplate.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) MSI Presenting AI's Next Leap at Japan IT Week Spring 2025
MSI, a leading global provider of high-performance server solutions, is bringing AI-driven innovation to Japan IT Week Spring 2025 at Booth #21-2 with high-performance server platforms built for next-generation AI and cloud computing workloads. MSI's NVIDIA MGX AI Servers deliver modular GPU-accelerated computing to optimize AI training and inference, while the Core Compute line of Multi-Node Servers maximize compute density and efficiency for AI inference and cloud service provider workloads. MSI's Open Compute line of ORv3 Servers enhance scalability and thermal efficiency in hyperscale AI deployments. MSI's Enterprise Servers provide balanced compute, storage, and networking for seamless AI workloads across cloud and edge. With deep expertise in system integration and AI-driven infrastructure, MSI is advancing the next generation of intelligent computing solutions to power AI's next leap.
"AI's advancement hinges on performance efficiency, compute density, and workload scalability. MSI's server platforms are engineered to accelerate model training, optimize inference, and maximize resource utilization—ensuring enterprises have the processing power to turn AI potential into real-world impact," said Danny Hsu, General Manager of [Only registered and activated users can see links. Click Here To Register...].[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
