Am o mare rugaminte la tine:am un echosmart 771SHQ si as avea nevoie de niste adrese pt key sau bin.Multam frumos si PASTE FERICIT!Quote:
super-sat.info la sectiunea ecosmart
Please tell me what software to put on Echosmart791 to have subtitles on TV1000, VIASAT HISTORY, EXPLORER. EUTELSAT W2.
1. Menu / Preferences / System Options / Subtitles Language (select <...>) / Exit (button)
2. Pres Green button and select Subtitle Standard.
Only these 3 programs have subtitles for about 5 seconds and then nothing.Problem May is in Cyrillic.
can you put an older software
2.92 for 791 for example
geen button and select ....
subtitle you explain what exactly
that the channel can not you desired subtitle language
subtitles are only in the provider wants
Maybe is that the problem. You must try more version to see if someone have solved that problem. I don't have total TV card to try. You start with 2.92 and go upper to the end (3.71).Quote:
Originally Posted by krisdioman [Only registered and activated users can see links. Click Here To Register...]
Verovatno je to problem (cirilicna slova). Moras probati vise verzija softwera da bi mozda resio problem. Na zalost nemam Total TV karticu da testiram. Pocni sa softverom 2.92 pa na gore, redom, do kraja, mislim da je 3.71 zadnji za ovaj risiver.
Im looking sw nova+bulsat support.
Hi guys,
I'm looking for the soft for 791 that supports irdeto 2 (canal digitaal 19 E).
Is this existing? Please help!
I believe that support of sd echosmart will continue...
nu cred ca dureaza mult sa avem suport i2 pe receptoare, cred ca e o problema de cateva zile, poate maxim cateva saptamani
google translate:
I do not think it takes a lot to have support i2 on receivers, I think a problem solve a few days, maybe within a few weeks
Thanks! I realy hope so.
Dupa cum am pomenit acum 2 posturi a si aparut noul software pentru receptoarele echosmart !
Se poate descarca de pe uploaduri, a aparut pentru toate modelele seriei, sint magic "release" si poarta numarul de versiune 3.75.
Bafta !
P.S.
Deocamdata este o versiune de test, cel putin asa apare in numele fisierelor.
Primele zvonuri sint ca 3.75 ar fi un fake, ramane sa ne confirme sau infirme cineva care are acest receptor.
Inseamna ca trebuie asteptat 3.76 ca au mai fost asemenea cazuri la echosmart si mai de mult.
yes this is fake
what's going on with the new software? we are steel waiting for it.
Please do something ....
A aparut 3.77 pentru versiuniile 792 si 7x1.
Cei care au testat pentru 792 afirma ca ar fi mai stabil pe retea in cccam, nu pot sa dau informatii concrete deocamdata.
Dau doar numele fisierului pentru a putea fi gasit mai usor:
v3.77_Final_SW_792.zip
si
v3.77_Final_SW7x1.zip
Atentie se va testa pe proprie raspundere, este un software ca si precedentul, care nu a aparut pe uploadurile cu care sintem obisnuiti pentru acest model de receptor.
Poate e bun, poate nu !
Bafta !
am testat 3.76,merge pe 771.
merge? i-ai pus picioare?
ideea era daca deschide canalele pachetului nova ( hotbird13 est ), bultsatcom ( helas 39 est)si cel olandez de pe astra 19 est
care sunt in irdeto
deci poti confirma ca " merge " sa deschida aceste pachete?
Anybody know if it is possible sharing between ECHOSMART 791 and Echolite cdvb5668.
