IncubusCamd 0.89
Scuze, am uitat sa pun linkul:
IncubusCamd 0.89
This README is for CubeRevo HD model series.
This document was approved on 08/Aug/2009 by the DGSTATION.
DGS release r10336: ( 08/Aug/2009)
1. Add iCubeRevo function
: If you have the iPhone(or iPod), you can operate the STB via iPhone(or iPod).
More description is attached. The file name is "iCubeRevo_manual.pdf".
2. Add streaming player function
: Bi-directional stream transmission between STB and PC is possible.
Several protocols(UDP, RTP) are supported. And Multicast or unicast are supported.
More description is attached. The file name is "MultiRoom and Streaming manual.pdf".
3. Add multiroom service function
: Several STBs can access the Server STB and see the Server's file, mp3, video player and channels.
4. Add M3U Player function
: M3U is a format that stores multimedia playlists.
Our M3U player can play XVID(Without GMC and Qpel), MPEG1, MPEG2, H.264.
5. Improv Nordic subtitle (Canal Film HD, Silver HD, BBC HD and so on)
: For the meantime, we didn't display subtitle without PTS or with wrong PTS.
But, at present, we support these subtitle.
6. Improve the channel navigation
: You can see the faster movement at the channel, Fav, epg list and so on.
7. Fixed incorrect aspect ratio for 4:3 channels
: For the meantime, our STB displayed PillarBox, Zoom with a little distortion.
8. Fixed subtitle overlaping on Hotbird.
: Hotbird 13E 11766 V 27500 (channel name : Rai1, Rai2, Rai3)
9. Fixed ttxt subtitle page at the specific pages(775~777)
: Hotbird 13E 11919 V 27500 (channel name : Italia 1, Canale 5, Retequattro)
10. Update russian language file by uncle fedor.
11. Update german language file by Nils.
Note.
1. When multiroom service and streaming player is running, recording and pip doesn't support.
2. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
3. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
2. The timeshift function of multiroom will release on the next.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function
Pina la sfarsit de saptamina o sa apare si versiuna NLB pt r10336!Pt sifteam nu prea cunosc pt ca tot staff lui sifteam este in vacanta.In plus cu ultimul firmware de la DGS ipbox are si pe functia multiroom (mai jos dau pe manual ca sa stiti cum se seteze)In plus poate sa fie controlat si prin Iphone (dau pe manual mai jos)
iCubeRevo manual
release 0.5.5
Ok from this release you will get a nightly build image. (this means i will not support stupid options like: panels, plugins and so on)
Soon a sifteam image will be out with panel and many options enabled.
I choose this way because i want that cuberevo community increase more! Many teams are involved in E2 now, so
each one can do his choice, and sifteam images will be out with another image (obviously based on the same Nightly build image version)
I will publish also how to build your own flash image, so every team can do it.
- new bootlogo (thanks arken)
- added bulgarian language
- added autofs
- added openvpn
- added openssl library
- added 576i to AutoResolution plugin
- added ftpput
- added ftpget
- added netstat
- "fixed" signal level on tuners
- teletext exit with "exit" button on remote
- fixed aspect on screen when exiting from teletext. If watching 16:9 format, it is shrinked, so looks like 16:6 or something
- fixed positioner setup
- fixed teletext subtitles
- remapped few buttons
- fix for DVB subtitles wich were not shown on some skins
- fixed bootlogo view on SD television
- fix the issue with stopping playback while it is paused
- incorporated the new web interface version (04/06/2009)
- fixed fast forward for MP3 in MediaPlayer
- enabled forwarding the second transport stream to the decoder
- fix avi 23.976fps/24.976fps/29.976fps
- avi: fix audio track selection early support for redirecting in http streaming
- added .rec extension file support
- CI cam drivers handling should now be better
- lot of fixes on PicturePlayer
- lot of fixes on MediaPlayer
- modified epgCache load to allow the load on e2 starts (now crossEpg works perfectly)
- added estonian language
- allowed to record/stream multiple channels from the same transponder (FTA only)
- There were a bug when a freeze happen on HD and SD channels, that bug showed you a full green pixel screen or an image repeating loop,
well this is bug was really hard to find for me and i'm not sure i've found all the cases when it happens, so... let me know if it happens again.
Many people asked me to add smart card drivers made by pacco, but i've not did them, so i will not add them like part of my images.
They can be added manually by everyone and each team made the possibilty to download and install them, so i will not add them until
i will make my own version (wich i don't know when and how it will be ready, you can use the pacco's version wich is good enought)
Enjoy it! Tideglo
incubusCamd_0_93-teta
25/09/2009, V0.93-teta
- fixed (??) EMM for all known codifies (if there are any kind of problem report as usually)
- added chid value in the provid/caid section
- added logs for EMM so we can find what's and if something is wrong or not
This is a test version. Why is published? Simply because we can't test all codifies with EMM, so not so many
improvements are made, just test if you like, otherwise use at your own.
A new version will be out as soon as we discover if EMM are cause of new bugs.
• AB Enigma 2HD support software
• 2 x DVB-S2 P&P tuner embedded
• 2 x CI Slot
• 2 x Smart Card Reader (CONAX)
• 2 x USB 2.0 (1 x Front panel and 1 x Rear panel)
• 2 x Scart
• Possible installing Plugins
• PVR function with internal or external HDD
exclusiv la HDTV ROMANIA forum
Azi a aparut @mower si a confirmat ca lucreaza la mbox, care o sa are un nou source code.In plus a spus ca termina cu armata la 6 Noembrie si o sa are mai mult timp sa se ocupa cu mbox.In plus nici o data nu a renuntat la mbox.
Si de ce nu scrii la Mbox ca sa stim si noi ceilalti?:clap:
ca sa te supari.....
:gathering:
Excelenta veste ! :clap: Asteptam cu nerabdare.
AB Enigma1HD beta for AB IPBox HD/900HD
Changes:
Repaired/Added:
+ Added function of automatic HDD check after start Key Up button (from front panel).
+ Added card driver inside sw
+ Added Mgcamd with working configs to AIO panel
+ Added configs for 1 and 2 smartcard reader boxes to AIO panel
+ Edited setting with added Thor 1W and Astra 28.5E
+ Repaired Timer recording
+ Repaired signal indicators
+ Repaired displaying Nameserver and Gateway in network setup
+ Correct displaying CZ EPG when CZ or SK language of main menu selected
+ Added info bar "recording" on TV screen after start recording
+ Added wizard of video outputs after first booting, box automatic swithces between video outputs till one is confirmed.
+ Added TXT subtitles (turns on in audio track button) In 1080 mode you can change bigger font of displaying subtitles, but without diacritic (will be added in next version).
For change font, turn on teletext on any channel with TXT,
press MENU and mark "true type font", than exit menu.
+ Correct displaying time on front dislay after turning off (91HD)
+ Added button of quick restart by frozen box(for uni RCU 9000HD/910HD button "repeat"
under "RECORD" button, for RCU 91HD button "RECALL" between "MENU" and "EXIT")
+ Added welcome logo
Known Issues
- DVB-C tuner doesn´t work
- works upper CI slot only, after inserting CAM module you have to restart it in menu of box.
After every restarting of box you have to put out CAM from box and put in to box and reset CAM in menu of box.
- DVB subtitles are not working
- installed games don´t work in 720p and 1080i mode. (work in 576i and 576p mode)
- doesn´t work CIFS
- after start playback from HDD, picture breakdown - it is necessary start playback again
- When SHARP tuner is inside box - signal indicators don´t work
Next repairs, which will be solved:
- playback - ts, divx, mpeg
- dvb subtitles
- video scaling for 544x572 4:3
- other known issues
In 3-4 zile o sa avem pe noua versiuna PKT 6.1 care o sa are nou MediaCenter,nou mountmanager,nou Glass SKIN,noua lista cu canale.Si o sa fie rezolvat problema cu tuner Sharp (inca se face test-uri.Din weekend o sa avem o noua versiuna de mbox posibil pe versiuna 7.
FRIEND NEW VERSION WILL BE TO DOWNLOAD IN NEXT 4-5 DAYS I THINK; PLEASE WAIT MOVER WORK ON NEW VERSION !!!!!!
Asa in urmatoarele zile o sa avem pe nou mbox.Posibil o sa fie rezolvat si problema cu NDS (sky uk,italy).
Vineri sau Duminica o sa fie gata noua versiuna de mbox.Asa a spus @mower!!!
when? thanks friend, you look like the witch guess. :lol:Quote:
pai ar fi cazul sa rezolve si partea tunerului la 91hd ca de enigma 2 de la abcom nimic
De acuma 2-3 ore merge SKY uk si SKY ital la mbox.Probabil cineva a conectat pe mbox cu oscam....
:gathering:
SKY UK nu a trecut la noua metoda inca. Merge cu softurile vechi inca.
This document was approved on 24/Dec/2009 by the DGSTATION.
DGS release r11502: ( 24/Dec/2009) - Merry Christmas
1. Fixed updating channel name of subfeed problem in multifeed function
2. Adopted multifeed function in cable tuner
3. In order to avoid auto formatting of USB memory stick, Modified concept to prevent automatically achieving format under 32GB HDD or USB memory when start up
4. Upgrade version of web interface 1.4.05(thanks to Nils)
5. Fixed HE-AAC with MPEG 4 video for DVB-T tuner
6. Added ipkg function
7. Added Arabic language in menu, it will support to Arabic EPG, Subtitle, teletext as well(thanks to Yahya - ACT team )
8. Updated Lituania language(thanks to Raimundas)
9. Update bitrate plugin 0.0.7(thanks to Kneubi)
10. And other small bugs fixed
Note.
1. Prohobited to recording, and PIP function in Server box when Multiroom Service or Streaming Player is running.
and The boxes should have same FTP user ID/Password with server box and client box when you use Multiroom service function
2. Caution : When encoding the file, Playback via XVID player will be affected by condition of a kind of CODEC, FPS(frame per second) and the Resolution.
And XVID player doesn¡¯t support resolution higher than 720P
therefore, we recommend as below conditions.
1) resolution : equal or under 720p
3) A/V Codec
Video Codec : XVID(Without GMC or Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MPEG layer 1,2, MP3, AC3
if XVID file has GMC or Qpel option when encoding, it will not work properly.
if the file was encoded by MPEG 1 or MPEG 2, XVID player doesn¡¯t support Adjusting Sync function and Jump forward/backward function
If you will record two HD channels with ext3 at the same time, it may fail in record.
Caution.
release 0.7.5
- added possibility to search channels by channel name's first letter, just press the remote button with the letter in the channel list
- fixed a bug on input box for remote controller keys
- added nc
- fixed some new memory leak bugs on drivers side
- updated enigma2 cvs 15/12/2009 (don't ask me all the change log, it's too big)
- added working subtitles remote button on live tv
- second recording should now be fine when starting while playback and another recording are active
- timeshift (or record + playback) should be more stable
- VCR scart connector now supports input signal, so you can connect other devices to the box and see automatically the TV signal when cuberevo is in standby or in deep-standby
- fixed WSS over 4:3 Scart connector, do not forget to set it in the A/V Configuration menu (let me know if it works good with TVs)
- updated to python 2.6
- added possibility to set Fan by menu (check CuberevoVFD in the plugin menu)
- added possibility to set brightness by menu (check CuberevoVFD in the plugin menu)
- added possibility to set clock in standby by menu (check CuberevoVFD in the plugin menu)
- added possibility to set led by menu (check CuberevoVFD in the plugin menu)
- added possibility to set scroll mode for channels name in the VFD by menu (check CuberevoVFD in the plugin menu)
- updated dreamTV-HD skin (IMHO now is a little bit cooler)
- fixed some VFD icons showing bugs, more need to be added
- fixed DVB subtitles where they were not allowed over some channels (like Universal Channel with Romanian subtitles, TotalTV and so on: report if now it works good)
- fixed a bug were enigma2 doesn't decode teletext pids on some channels (like Mega, Star, ANT1 in package Netmed: report if now it works good)
- udpated webinterface to last 23/12/2009 cvs
- fixed seeking from current position in avi
- fixed user audio delay in seeking
- enable seeking in mp4 files
