Asa da!A functionat din prima!Mersi mult!
SAPRO Image 1.7 for OCTAGON SF8008 + SF8008mini
Use distro: OpenATV 6.4 - 8.12.2020
Enigma version: 05-12-2020
Kernel version: 4.4.35
DVB version: 19-11-2020
GStreamer version: 1.17.0
Python version: 2.7.16
Resolution mode: 1080p
OSCam: r11678 - port 8888 - ICE 0624
Default language: Czech
Pre-installed plugins:
- ArchivCZSK with SCC - 1.3.7 - 2.1.18
- Chocholousek picon - 3.1.201103
- CSFD - 12-50-20180505
- CoolTVGuide - 7.7.0
- HBBTV - 2.0-r0-34
- Netflix - 2.2 + 20201119-r0
- MediaPortal - 2020060105
- SubsSupport - 1.5.8-20201004
- webradioFS - 19.13
- XStreamity - 2.67.20201207
- Youtube - git608
- Code 18.9
- under Kodi Skylink Live TV - 1.7.1
- under Kodi Netflix - 1.11.0
- under Kodi Stream Cinema - 1.3.28
- under Kodi Stream Cinema Community - 1.8.12
Login :
Password: sapro
Installation:
- copy the file on the USB stick and install via Online image change.
You can download version for SF8008 from
You can download version for SF8008mini from
OCTAGON SF8008 & SF8008M MINI DUAL OS Linux SW V10537 06-12-2020
Changes:
1. Default sort by number for Stalker - Option Button.
2. Add. User Agent for Stalker - Stalker Option - System.
3. Modified ATR of for Slovakia.
4. Disable change freq of GPU.
Online Update:
Menu - Software Update OK - 0000 - Internet Upgrade: v10537 OK
Online Aktualisierung:
Menü - Software (Firmware) Update OK - 0000 - Internet Methode: V10537 OK
Online güncelleme:
Menü - Yazilim güncelleme OK - 0000 - Internet methodu: V10537 OK
SW offline - USB:
Recovery Bootmenu (E2):
OCTAGON GERMANY SUPPORT
__________________
OCTAGON SF8008 4K UHD E2 (Single, Combo, Twin
OCTAGON SF8008 4K UHD E2 Treiber (Driver) Update 19.12.2020
- [SF8008] + [SF8008m] Update:
* New Driver Update
* New Fastboot
* New Partition Files
* Adda GPIO for WiFi Power
* Some minor issues fixed
Ab morgen in den Images!
From tomorrow in the Images!
Yarindan itbaren Imajlarda!
__________________
OCTAGON SF8008 4K UHD E2 (Single, Combo, Twin)
Christmas SAPRO Image for OCTAGON SF8008 + SF8008mini
Use distro: OpenATV 6.4 - 21.12.2020
Enigma version: 15-12-2020
DVB version: 18-12-2020
Default skin: HD Glass 17
- ArchivCZSK Premium - 10-06.11-2020
- ArchivCZSK with SCC - 1.3.7 - 2.1.19
- HBBTV - 2.0-r0-34
- webradioFS - 19.30
- XStreamity - 2.69.20201213
- Youtube - git618
- HD Glass 17 - 5.09
- YoutubeTV - 24.11.2020
- SatVenus Panel - 7.3.2
- KODI 18.9
- under Kodi Netflix - 1.12.0
- under Kodi Stream Cinema Community - 1.8.15
Login :
Password: sapro
Installation:
- copy the file to the USB key and install via Online image change.
Se poate instala uh hhd pentru pvr in acest receiver ? Ca nu prea vad unde ar fi loc cum e in 4008.
Bineinteles ca se poate. Pe usb, un hdd extern
Vad ca au aparut prin decembrie si variante cu hdd intern ...
cine poate sa-mi spuna de ce sunt imagini recovery emmc zip si mmc zip !?
imaginile cu recovery includ pe langa imagine si bootloaderul , sa ma corecteze cineva daca nu e bine ce zic.
Deci daca tu stii ca din decembrie sf8008 are si suport HDD intern atunci care mai e sensul intrebarii tale de la #155?
Modelul meu nu are!
poti pune o poza cu octagon sf8008 care are loc de pus hdd intern sau un link? eu am cautat si nu am gasit....
Da,se poate găsi!Si Satking.de are de vânzare!Dar am impresia că ei le montează in aparat,nu din fabrică iese asa!Si acuma au pe stoc cu HDD de 2T:
Sau si aici este:[Only registered and activated users can see links. Click Here To Register...]
am cautat pe internet si am gasit o poza cu ---octagon sf8008 with hdd intern---
hdd intern este conectat la circuitul integrat GL850G prin intermediul unui USB to SATA converter
The IC is a GL850G, a USB 2.0 HUB
imagini preluate de pe dxtv.de
Posibil sa-i fi pus si o sanie pentru hdd la acele modele noi.
Versiunea combo de 110 euro nu are suport intern hdd.
Iar de la pretul de 110 euro la 220 euro pentru aceeasi specificatie e o diferenta cam mare doar pentru atata lucru.
Vezi ca pe langa sania dedicata vine si cu un hdd de 2TB si de acea pretul e mai mare - [Only registered and activated users can see links. Click Here To Register...]
- Lieferumfang:
1x Octagon SF8008 4K Single Sat Receiver, 2TB HDD, Schwarz
1x Fernbedienung
1x HDMI Kabel
2x Batterien
1x Netzteil (Stromversorgung, DC12V-2A)
1x Bedienungsanleitung (Deutsch & Englisch)
In schimb NU este combo - - DVB-S2X Single Tuner (Silabs Si2166-D60 & RDA5815m) si cel de :
- 224.90 euro cu hdd 2TB , dar doar DVB-S2X - are codul - Artikel-Nr.: RECOCT0952T - pe cand cel ieftin/combo
- 117.00 euro fara hdd , dar DVB-S2X & DVB-C/T2 combo (2x tuner) - are codul - Order number: RECOCT094 - [Only registered and activated users can see links. Click Here To Register...]
