oscam 8917 8920 8950
oscam9868.tar.gz
oscam9871.tar.gz
oscamymod49 pentru imaginea RSP
Merge cu SoftCam.Key
Code:+-------------------------------------------------------------------------------
| OSCam ver: 1.20-ZILDAN_ rev: 9082 target: sh4-linux
| Tools:
| CROSS = /tdt/tufsbox/devkit/sh4/bin/sh4-linux-
| CC = /tdt/tufsbox/devkit/sh4/bin/sh4-linux-gcc
| Settings:
| CONF_DIR = /var/keys
| CC_OPTS = -O2 -ggdb -pipe -ffunction-sections -fdata-sections
| CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-styl e-definition
| CFLAGS =
| LDFLAGS = -Wl,--gc-sections
| LIBS = -lpthread -ldl
| UseFlags =
| Config:
| Addons : WEBIF HAVE_DVBAPI IRDETO_GUESSING CS_ANTICASC WITH_DEBUG WITH_LB C S_CACHEEX CW_CYCLE_CHECK
| Protocols: CAMD35 NEWCAMD CCCAM CCCSHARE CONSTCW
| Readers : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD
| CardRdrs : PHOENIX INTERNAL MP35 SMARGO STAPI
| Compiler : sh4-linux-gcc (GCC) 4.6.3 20120613 (STMicroelectronics/Linux Base 4.6.3-111)
| Binary : Distribution/oscam-1.20-ZILDAN_9082-sh4-linux
| OSCam ver: 1.20-ZILDAN_ rev: 9105 target: sh4-linux
| Tools:
| CROSS = /tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-
| CC = /tdt/tdt/tufsbox/devkit/sh4/bin/sh4-linux-gcc
| Settings:
| CC_WARN = -W -Wall -Wshadow -Wredundant-decls -Wstrict-prototypes -Wold-style-definition
| CFLAGS =
| UseFlags =
| Config:
| Addons : WEBIF HAVE_DVBAPI IRDETO_GUESSING CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK
| Binary : Distribution/oscam-1.20-ZILDAN_9105-sh4-linux
| OSCam ver: 1.20-ZILDAN_ rev: 9533 target: sh4-linux
| Tools:
| CROSS = tdt/tufsbox/devkit/sh4/bin/sh4-linux-
| CC = tdt/tufsbox/devkit/sh4/bin/sh4-linux-gcc
| Settings:
| CFLAGS =
| LIBS = -lpthread -ldl -lrt
| UseFlags =
| Config:
| Addons : WEBIF HAVE_DVBAPI CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX
| Binary : Distribution/oscam-1.20-ZILDAN_9533-sh4-linux
| OSCam ver: 1.20-ZILDAN_ rev: 9811 target: sh4-linux
| Tools:
| Settings:
| CFLAGS =
| UseFlags =
| Config:
| Addons : WEBIF WEBIF_LIVELOG WEBIF_JQUERY HAVE_DVBAPI WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX
| Protocols: CAMD35_TCP NEWCAMD CCCAM CCCSHARE CONSTCW
| Readers : NAGRA CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD
| CardRdrs : PHOENIX INTERNAL SC8IN1 MP35 SMARGO STAPI
| Binary : Distribution/oscam-1.20-ZILDAN_9811-sh4-linux
OSCAM EMU 9864 cu Patch-ul [Only registered and activated users can see links. Click Here To Register...]
| OSCam ver: 1.20-RSP_svn rev: 9864 target: sh4-linux
| Tools:
| CROSS =sh4-linux-
| CC = sh4-linux-gcc
| Settings:
| CFLAGS =
| LDFLAGS = -Wl,--gc-sections -Wl,--format=binary -Wl,SoftCam.Key -Wl,--format=default
| UseFlags =
| Config:
| Addons : WEBIF WEBIF_LIVELOG HAVE_DVBAPI CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX WITH_EMU
| Protocols: CAMD33 CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE CONSTCW
| CardRdrs : PHOENIX INTERNAL SMARGO STAPI
| Compiler : sh4-linux-gcc (GCC) 4.7.2 20130218 (STMicroelectronics/Linux Base 4.7.2-119)
| Binary : Distribution/oscam-1.20-RSP_svn9864-sh4-linux
Am facut update la lynk-ul de Key din panel !
Daca faceti update de softcam.key cu oscamul de mai sus activ merge ce trebuie !
Am adaugat si un oscamemu la panel.
Oscam 9868 EMU cu ultimul patch de [Only registered and activated users can see links. Click Here To Register...]
| OSCam ver: 1.20-EMU_Zildan_svn rev: 9868 target: sh4-linux
| Tools:
| CROSS = sh4-linux-
| CC = sh4-linux-gcc
| Settings:
| CFLAGS =
| UseFlags =
| Config:
| Addons : WEBIF WEBIF_LIVELOG WEBIF_JQUERY HAVE_DVBAPI CS_ANTICASC WITH_DEBUG WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX WITH_EMU
| Protocols: CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE
| Binary : Distribution/oscam-1.20-EMU_Zildan_svn9868-sh4-linux
| OSCam ver: 1.20-unstable_svn rev: 9883 target: sh4-linux
| Tools:
| | Settings:
| CFLAGS =
| UseFlags =
| Config:
| Addons : WEBIF WEBIF_LIVELOG HAVE_DVBAPI IRDETO_GUESSING CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX WITH_EMU
| Protocols: CAMD35 CAMD35_TCP NEWCAMD CCCAM CCCSHARE CONSTCW
| Binary : Distribution/oscam-1.20-unstable_svn9883-sh4-linux
| OSCam ver: 1.20-RSP_svn rev: 9890 target: sh4-linux
| Tools:
| Settings:
| CFLAGS =
| UseFlags =
| Config:
| Binary : Distribution/oscam-1.20-RSP_svn9890-sh4-linux
OscamEMU9914 pentru imagini RSP
OscamEMU9945
| OSCam ver: 1.20-unstable_svn rev: 9945 target: sh4-linux
| Tools:
| CFLAGS =
| UseFlags =
| Config:
| Addons : WEBIF WEBIF_LIVELOG HAVE_DVBAPI CS_ANTICASC WITH_DEBUG MODULE_MONITOR WITH_LB CS_CACHEEX CW_CYCLE_CHECK CLOCKFIX WITH_EMU
| Readers : NAGRA IRDETO CONAX CRYPTOWORKS SECA VIACCESS VIDEOGUARD BULCRYPT
| Binary : Distribution/oscam-1.20-unstable_svn9945-sh4-linux
Code:You may use OSEmu instead and add it as a reader to your plain oscam server.
OSEmu can be found at https://github.com/oscam-emu/OSEmu
Supported systems
Currently only the following crypto systems are available:
- Cryptoworks
- SoftNDS
- Viaccess 1/2/3
- Nagra 2
- Irdeto 2
- Biss (Mode 1) [Note: only 1 key possible for a sid/pid combination, use the oscam constcw reader if you need more]
OscamEmu9997 RSP SH40
