La mine merge foarte bine, e transponderul cu Eurosport HD. Ai AAf 1.5?
sal.
nu am 1.3
Nu ai nici o sansa cu 1.3. E un bug la canalele DVB-S2 8PSK. In 1.5 s-au rezolvat aceste probleme.Quote:
Originally Posted by dragos [Only registered and activated users can see links. Click Here To Register...]
Intre timp se pare ca apar alte probleme cu noul pachet HD de pe THOR.
Pinal la urma merge acest receiver in sharing cu CCcam?
Din pacate nu.Quote:
Originally Posted by ovi_jer [Only registered and activated users can see links. Click Here To Register...]
Merge gbox client prin mgcamd , camd3 .
f11
Uite ce se zvoneste.
Sper sa fie adevarat.
CCcam 3.0 - soon ?
Said to be tested in Spain:
" for a perfect CCcam 3.0 "
Zitat:
AUTOMATIC keyupdate for following providers
Premiere, Premiere Star, Digital+ ( Nagra 2 )
SSR SRG ( Schweizer Fernsehen ) ( Viaccess )
Cryptoworks hardencoded bug on CAID 0d22 ( Arena / Tividi )
Only ok with version Version 2.0.1
Channels : AXN, RTL Crime, History Channel, Kinowelt TV don't work because of parental control ( PIN )
NAGRA 2/3 new ROM 142 support
TV Cabo on Hispisat 30 degrees
( Polsat in future )
IRDETO card support improovement
and IIRDETO 2 Version 2 card support
Entitlements corrections
some cards are showing entitlements in HEX form
Chid 7D2B - date 0xcb5 valid 0xfe
Chid 00E1 - date 0xcb5 valid 0xf1
KATHREIN UFS 910 receiver support
TRIPLE DRAGON receiver support
REELBOX receiver support
FRITZBOX ROUTER support
( executable in FRITZBOX router )
NSLU2 support Debianslug
( LSB executable )
Multi EMU
CCcam should be able to run in one session with an other EMU
( CCcam with MGCAMD or CCcam with CAMD3 or CCcam with NP )
NEWCS card's -> LOAD BALANCE
CCCam should be able to identify identical cards connected by newccamd protocol to balance load onto these cards
CAID remapping
CCcam should request ECM under a different CAID
( for example : TV Cabo CAID remap 1802 -> 1801)
LOG output via UDP Port
@zildan
Man, suna atit de frumos de parca... imi pica tare greu sa cred ca e adevarat.
In alta ordine de idei: am pus cititorul ala de 6mhz si se pare ca e totul in regula cu driverii si conexiunile pe newcs, dar refuza sa vada cardul ala nemtzesc. Poate, mai spre seara, bagi o geana in cutie la mine, poate vezi unde-i baiul. :D
AAF Version 2.0
Poate deja in Weekend!
PS:
Se pare ca o sa aiba modificatii importante! :-)
Originally Posted by Discoman [Only registered and activated users can see links. Click Here To Register...]
De unde ai informatia...Posteaza si tu link-ul
Ce s-a intamplat cu rdi-board ? scuze de offtopic...
treci pe la offtopic si citeste
Link-ul este normal ca acasa la mama lor : [Only registered and activated users can see links. Click Here To Register...] iar despre rdi cauta la offtopic ca se consuma multa cerneala:)Quote:
Originally Posted by bobbob [Only registered and activated users can see links. Click Here To Register...]
On topic :
Se para ca rusii au dat sursele pentru mgcamd , un lucru bun pentru posesorii de kathrein si ipbox si sa speram in continare la comilarea unor drivere pe kathrein in asa fel incit sa vedem pe el divx-uri si mai ales mkv-uri.
f11
Se anuntza unele imbunatatiri pe care Kathrein le-a anuntat pt. ultimul update si nu le-a implementat.Quote:
AAF-team nu spun ce anume va contine image, dar au spus ca in urmatorul weekend poate sa apara, numai daca totul va merge stabil.
insa daca lucrurile pot merge spre mai rau, atunci vor merge :)Quote:
Originally Posted by wambertos [Only registered and activated users can see links. Click Here To Register...]
murphy
Al naibi sharpele asta :lol:
Salutari!
@wambertos
:lol:
Diseqc 1.1 si 1.2 implementat cum trebuie= pt. mine ajunge!
Daca fac diseqc1.1 si 1.2 trebuie sa faca ceva si cu "favoritii", pt. ca nu mai ajung 8.Quote:
