2,001 W XOC BIOS for GALAX GeForce RTX 5090D HOF Appears
If you remember GALAX's last overclocking triumph, it was thanks to [Only registered and activated users can see links. Click Here To Register...] for the RTX 5090D HOF. Now, this special XOC BIOS has surfaced online, courtesy of an eagle‑eyed post by [Only registered and activated users can see links. Click Here To Register...]. This firmware unlocks a default power limit of 2,001 W, which exceeds NVIDIA's official cap, and even allows you to adjust the TDP down to 400 W if you need to keep temperatures in check. It only works on the 5090D variant, so don't bother trying to flash it onto the regular 5090. That exclusivity makes sense given GALAX's decision to release just one non‑D HOF card globally, and it shows that true overclocking headroom is reserved for the 5090D platform.
Using liquid nitrogen cooling and finely tuned voltages, they pushed the core clock up to an astonishing 3,650 MHz and achieved a record time of 39.434 seconds on the GPUPI 32B benchmark. OC momentum carried over into graphics tests as well, where 3DMark Port Royal saw the GPU running at 3,570 MHz on its core and 2,250 MHz on GDDR7 memory, resulting in a score of 47,469 points. Meanwhile, the Unigine Superposition 1080p Extreme preset achieved 38,237 points, nearly 29% above the card's standard performance target. Extreme overclocking is not a dead end, and with this XOC BIOS, another overclocking lab could give it a try and potentially set a new world record.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Nikon Introduces 600x600 mm Substrates for Advanced AI Silicon
Nikon announced that it will begin accepting orders today for its Digital Lithography System DSP-100, a back-end tool purpose-built for the next-gen of advanced semiconductor packaging. The company will deliver the first units during fiscal year 2026. The DSP-100 is specifically designed for panel-level packaging (PLP), a technology that industry leaders such as [Only registered and activated users can see links. Click Here To Register...], Intel, and Samsung are adopting to overcome the cost and area limitations of 300 mm wafers. Standardized rectangular substrates, already fixed at 510x515 mm, allow more compute chiplets, HBM4 stacks, and I/O dies to be integrated into a single package. Nikon's engineers pushed the standard further by enabling exposure on glass or resin panels up to 600×600 mm. Key specifications released today show a 1.0 µm line‑and‑space resolution, overlay accuracy within ± 0.3 µm and throughput of 50 panels per hour at the 510x515 mm size.
By eliminating photomasks and instead steering an i-line equivalent light source through a spatial light modulator (SLM), the DSP-100 sidesteps both the optical distortion inherent in large single-lens systems and the expense of mask sets. A proprietary multi‑lens array borrowed from Nikon's flat‑panel display division stitches the pattern seamlessly across the full substrate. With a 600×600 mm panel accommodating 36 of the 100 mm square packages, the system delivers nine times higher throughput productivity compared to 300 mm wafer processes, dramatically reducing the cost per die. The maskless architecture also shortens design iteration cycles, a critical advantage as generative AI workloads drive rapid evaluation of data center accelerators. Nikon states that volume production of the DSP‑100 will commence in 2026, with pricing disclosed only to qualified buyers.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) EIZO achieves EcoVadis Platinum Rating
EIZO Corporation today announced that it has been awarded a Platinum rating from EcoVadis, the highest recognition possible in the global sustainability assessment. This marks a significant milestone for EIZO, which has advanced from Bronze to Platinum in a single annual evaluation cycle, placing it in the top 1% of over 150,000 companies assessed worldwide. EcoVadis, founded in France in 2007, is one of the world's most trusted sustainability ratings providers, evaluating companies on Environment, Labor & Human Rights, Ethics, and Sustainable Procurement. EIZO earned an overall score of 84, reflecting strong performance across all categories.
"This recognition affirms the steady progress we've made in integrating sustainability into our business and supply chain operations," said Masaki Ebisu, President and COO of EIZO Corporation. "We view this Platinum rating not as a goal, but as a foundation for continued innovation and responsibility in all aspects of our operations. We will continue to strengthen our ESG initiatives to create lasting value for society and our stakeholders."[Only registered and activated users can see links. Click Here To Register...]
Intel Skips NPU Upgrade for Arrow Lake Refresh, AMD Cancels Medusa Hal
Intel's Arrow Lake-S desktop update set for the latter part of 2025 might not bring the expected boost in AI capabilities. New information from Jaykihn, a leaker known for sharing regular updates on Intel roadmaps hints that this update will keep the current NPU 3 design instead of using the more advanced NPU 4 found in Intel's Lunar Lake laptop chips. The existing Arrow Lake desktop line uses NPU 3, which came out in 2023 with Meteor Lake and offers 11.5 TOPS of AI power. This falls well short of the 40 TOPS needed for Microsoft Copilot+ certification. Intel's Lunar Lake laptop processors have the upgraded NPU 4, which can reach up to 48 TOPS making them Copilot+ ready. By sticking with NPU 3 in the desktop update, Intel's desktop chips will still trail behind laptop offerings from AMD and Apple in AI speed. Without NPU upgrades, the [Only registered and activated users can see links. Click Here To Register...] seems to offer small increases in clock speed and continued production on Intel's 20A process. This small step forward might not be enough, given Intel's shrinking market share and the need for bigger design improvements to stay competitive.
At the same time AMD might face some problems with reports suggesting that [Only registered and activated users can see links. Click Here To Register...], which was supposed to come after Strix Halo, has been scrapped. This news comes from HXL, a leaker with a decent track record. This could mean that Intel's [Only registered and activated users can see links. Click Here To Register...] is left without any real competition in a market where Strix Halo and Apple's chips are the big players. If this is true, it shows a big change in AMD's plans for high-end mobile computing.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) LG Display Reports Second Quarter 2025 Results
LG Display today reported unaudited earnings results based on consolidated K-IFRS (International Financial Reporting Standards) for the three-month period ending June 30, 2025.
- Revenues in the second quarter of 2025 decreased by 8% to KRW 5,587 billion from KRW 6,065 billion in the first quarter of 2025 and decreased by 17% from KRW 6,708 billion in the second quarter of 2024.
- Operating loss in the second quarter of 2025 stood at KRW 116 billion. This compares with the operating profit of KRW 33.5 billion in the first quarter of 2025 and with the operating loss of KRW 93.7 billion in the second quarter of 2024.
- EBITDA profit in the second quarter of 2025 was KRW 1,054 billion, compared with EBITDA profit of KRW 1,231 billion in the first quarter of 2025 and KRW 1,287 billion in the second quarter of 2024.
- Net profit in the second quarter of 2025 was KRW 891billion, compared with the net loss of 237 billion in the first quarter of 2025 and with the net loss of KRW 471 billion in the second quarter of 2024.
LG Display recorded KRW 5.587 trillion in revenues and KRW 116 billion in operating loss in the second quarter of 2025.[Only registered and activated users can see links. Click Here To Register...]
(PR) NVIDIA GeForce NOW Gets WUCHANG: Fallen Feathers, Tony Hawk's Pro
Sharpen the blade and brace for a journey steeped in myth and mystery. WUCHANG: Fallen Feathers has launched in the cloud. Ride in style with skateboarding legends in Tony Hawk's Pro Skater 1 + 2, now just a grind away. Or team up with friends to fend off relentless Zed hordes in the pulse-pounding action of Killing Floor 3. The adventures begin now with nine new games on GeForce NOW this week.
Rise From Ruin
Dive into the hauntingly beautiful world of Ming Dynasty China in WUCHANG: Fallen Feathers, where supernatural forces and corrupted souls lurk around every corner. Step into the shoes of Wuchang, a fierce warrior battling monstrous enemies and the curse of the feathering phenomenon. Every decision and weapon swing carves a path through a world that's as treacherous as it is breathtaking. The game's rich lore and atmospheric storytelling pull players into a dark, soulslike adventure where danger and discovery go hand in hand. Stream the game in all its gothic glory with GeForce NOW, no legendary hardware needed. Powered by a GeForce RTX gaming rig in the cloud, GeForce NOW enables members to stream instantly across devices and immerse themselves in epic combat and stunning visuals. Ultimate members can soar to new heights and stream at up to 4K resolution 120 frames per second or 240 FPS for even smoother frame rates - all at ultralow latency.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Schenker Announces XMG PRO 16 Value Edition Notebook
The XMG PRO 16 Value Edition expands the PRO 16 line-up with additional entry-level configurations featuring an Intel Core i9-14900HX and NVIDIA GeForce RTX 5070 Ti, 5070 or 5060. Key features such as the 99.8 Wh battery, comprehensive connectivity and the functional full-size keyboard remain unchanged. However, the 1600p IPS display has been improved: with a refresh rate of 300 Hz and brightness of 500 nits, it now covers not only 100% of the sRGB color space but also the DCI-P3 gamut. This enhanced panel is also used in the updated standard XMG PRO 16, which, positioned above the Value Edition, additionally offers a Mini LED display as an optional upgrade.
With the Value Edition of the PRO series, the XMG PRO 16 VE (M25), XMG introduces a new entry-level model of its 2025 gaming and multimedia workstation. In contrast to the standard XMG PRO 16, which features Intel's Core Ultra 9 275HX and an NVIDIA GeForce RTX 5070 Ti, the more affordable, price-performance focused Value Edition comes with a Core i9-14900HX, also offering 24 cores, and a choice of three laptop GPUs: an NVIDIA GeForce RTX 5070 Ti, RTX 5070 or RTX 5060.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Sandisk Forms HBF Advisory Board for High-Bandwidth Flash Memory
Sandisk Corporation today announced the formation of a Technical Advisory Board to guide the development and strategy of its groundbreaking High Bandwidth Flash (HBF) memory technology. The board includes industry experts and senior technical leaders from both within and outside the company. Appointed today, Professor David Patterson and Raja Koduri will provide strategic guidance, technical insight, market perspective, and shape open standards as Sandisk prepares to launch HBF.
"We're honored to have two distinguished computer architecture experts join our Technical Advisory Board," said Alper Ilkbahar, Executive Vice President, Chief Technology Officer, and HBF Technical Advisory Board member at Sandisk. "Their collective experience and strategic counsel will be instrumental in shaping HBF as the future memory standard for the AI industry, and affirming we not only meet but exceed the expectations of our customers and partners."[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Thermaltake Releases MAGFloe Ultra and TT RGB PLUS 3.0
Thermaltake, a leading PC DIY brand for premium hardware solutions, proudly launches the MAGFloe 360/420 Ultra ARGB Sync AIO Liquid Cooler, now available globally. Aimed at users who prioritize both peak thermal efficiency and dynamic design, the MAGFloe Ultra Series delivers exceptional cooling performance and next-generation convenience. Integrated with the brand-new TT RGB PLUS 3.0 software, the series offers an advanced level of visual personalization and system monitoring through its vivid onboard LCD display.
Setting the MAGFloe Ultra apart is its bold 3.95-inch square LCD, featuring a high-resolution 480x480 pixels that bring function to the cooling unit. This vivid screen offers real-time system monitoring, including CPU and GPU stats, pump temperature, and other vital data. In addition, it supports user-generated content such as images, GIFs, and videos, allowing for deep customization, from informative readouts to eye-catching animations.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel "Nova Lake-S" Core Ultra 3, Ultra 5, Ultra 7, and Ultra 9 Core C
Intel will be significantly increasing CPU core counts with its next-generation "Nova Lake" client processor microarchitecture. For the desktop variant, the "Nova Lake-S," this marks a maximum CPU core configuration of 16P+32E+4LPE for an impressive 52 cores per socket. That's 16 "Coyote Cove" P-cores, 32 "Arctic Wolf" E-cores spread across eight E-core clusters; and 4 additional low-power island E-cores based on the same "Arctic Wolf" core design. While the P-cores and E-core clusters share an L3 cache, the LPE cores are not part of the CPU complex, and are located in a low-power island that's part of the SoC region of the chip, an arrangement similar to "Meteor Lake." The top Core Ultra 9 is expected to come with a massive L3 cache of 144 MB, which should benefit gaming workloads.
Intel will give only its top Core Ultra 9 SKUs the maxed out configuration of 16P+32E+4LPE. This chip is expected to come with a processor base power value of 150 W for its unlocked K or KF SKUs. We are now learning what the core configurations of the other brand extensions, 7, 5, and 3, could look like. For the Core Ultra 7 SKUs, Intel is expected to opt for a 14P+24E+4LPE configuration for a total of 42 cores. To do this, the company will disable two P-cores, and two E-core clusters, while also reducing the L3 cache. The top K- and KF-SKUs of Core Ultra 7 are expected to come with the same 150 W processor base power values as the Core Ultra 9 K/KF SKUs.[Only registered and activated users can see links. Click Here To Register...]
(PR) Cronos: The New Dawn Gets First Extended Gameplay Trailer
Bloober Team has released the first extended gameplay video for its highly anticipated sci-fi horror title, Cronos: The New Dawn. This eerie 10-minute showcase offers a gripping deep dive into the game's intense combat, terrifying enemies, and survival mechanics while introducing two of the game's hauntingly distinct environments: Islands in The Mist and The Hospital.
In Islands in The Mist, players navigate a mysterious liminal space where visibility is limited, tension is high, and danger lurks in every fog-drenched corner. Meanwhile, The Hospital delivers a claustrophobic descent into madness, where sterile corridors twist into nightmarish labyrinths, echoing with the remnants of a forgotten past.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Patriot Memory Launches EP Express microSD Card Compatible With N
Patriot Memory, proudly announces the launch of its latest EP Express microSD card, leveraging cutting-edge microSD Express technology. Available in capacities of 256 GB, 512 GB, and 1 TB, the EP Express is engineered to meet the rigorous demands of Nintendo Switch 2 users and next-generation mobile devices requiring both high-speed performance and flexible storage expansion.
Designed for Nintendo Switch 2 and featuring cutting-edge microSD Express technology, the Patriot EP Express microSD card delivers blazing-fast read/write speeds of up to 800/600 MB/s, significantly reducing game downloads, installations, and updates while ensuring smooth performance for save data and high-resolution media capture.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) SK hynix Announces 2Q25 Financial Results
SK hynix Inc. announced today that it has recorded 22.232 trillion won in revenues, 9.2129 trillion won in operating profit (with an operating margin of 41%), and 6.9962 trillion won in net profit (with a net margin of 31%) in the second quarter. Both revenues and operating profits stood at all-time highs, beating the previous best results in the fourth quarter of last year. The company said that an aggressive investment by global big tech companies into AI led to a steady increase in demand for AI memory. Shipments of both DRAM and NAND flash were higher than expected, helping the company log the best quarterly results.
SK hynix expanded sales of 12-high HBM3E in the DRAM space, while registering a growth in sales of NAND for all applications. With the industry-leading competitiveness in AI memory and profitability-first management discipline, the company has maintained a positive earnings trend. With the latest financial results, the company's cash and cash equivalents increased to 17 trillion won at the end of June, up by 2.7 trillion won a quarter earlier. Its debt ratio and net debt ratio stood at 25% and 6%, respectively, as net debt fell by 4.1 trillion won, compared with the previous quarter.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) KLEVV Launches Enhanced SSD Lineup, CRAS C925G, CRAS C910G NVMe S
KLEVV, the leading consumer memory and storage brand introduced by Essencore, is excited to unveil the latest refresh of its SSD (solid-state drive) lineup. This release features the enhanced CRAS C925G and CRAS C910G NVMe Gen 4 M.2 SSDs alongside the upgraded NEO N410+ SATA 6 Gb/s SSD, designed to deliver superior performance, exceptional cooling, and reliable storage that meets the diverse demands of gamers, creators, and everyday users with confidence.
Next-Level NVMe for Demanding Workloads
Building on KLEVV's highly rated CRAS SSD lineup, the updated CRAS C925G and CRAS C910G NVMe Gen 4 M.2 SSDs deliver blazing-fast speeds and rock-solid reliability for today's most rigorous workloads. The CRAS C925G, built on the latest NVMe 2.0 standard, achieves peak sequential speeds of up to 7,400 MB/s read and 6,500 MB/s write, delivering ultra-responsive load times and seamless multitasking, ideal for AAA gaming, 4K content creation, data-intensive AI tasks, and heavy-duty applications.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ZOTAC to Release GeForce RTX 5090 ArcticStorm AIO and GeForce RTX
ZOTAC Technology PTE. Limited is pleased to announce the launch of the ZOTAC GAMING GeForce RTX 5090 ARCTICSTORM AIO and the ZOTAC GAMING GeForce RTX 5060 Low Profile. Two models on the opposing ends of the size spectrum, the ARCTICSTORM AIO is the first ever high-end graphics card by ZOTAC GAMING to utilize a full-sized 360 mm Liquid Cooling AIO, for the ultimate cooling performance, pure speed and exceptional temperatures. The ZOTAC GAMING GeForce RTX 5060 Low Profile, on the other hand, is a half-height, ultra-compact card made for Small Form Factor Enthusiasts.
The ZOTAC GAMING GeForce RTX 50 Series is powered by the NVIDIA Blackwell architecture, bringing game-changing capabilities to gamers and creators. Equipped with a massive level of AI horsepower, the RTX 50 Series enables new experiences and next-level graphics fidelity. Multiply performance with NVIDIA DLSS 4, generate images at unprecedented speed, and unleash creativity with NVIDIA Studio. Plus, access NVIDIA NIM microservices - state-of-the-art AI models that let enthusiasts and developers build AI assistants, agents, and workflows with peak performance on NIM-ready systems.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) G.Skill Announces T5 Neo Series DDR5-6400 CL38 512GB (64GBx8) Ove
G.SKILL International Enterprise Co., Ltd., the world's leading brand of performance overclock memory and PC components, is thrilled to announce the release of its latest high-performance T5 Neo series DDR5-6400 CL38 512 GB (64 GB x8) overclocked DDR5 R-DIMM memory solution. Specifically engineered for AMD Ryzen Threadripper PRO series processors and compatible AMD WRX90 chipset motherboards, this T5 Neo DDR5 R-DIMM memory kit leverages AMD EXPO memory overclocking technology and a high-quality 16-layer PCB design to deliver exceptional speed, high kit capacity, and reliability for professional workstations.
With a total kit capacity of 512 GB across eight 64 GB modules, the T5 Neo series memory kit is built to meet the demands of intensive workloads. From AI model training, large-scale data analytics, memory-intensive simulations, professional applications, and high-resolution content creation, this high-capacity memory configuration enables professionals to work with significantly larger datasets, making it the ideal choice for next-generation workstations that require both exceptional bandwidth and expansive capacity to accelerate productivity. Please refer to the screenshots below for Memtest validation on the ASUS Pro WS WRX90E-SAGE SE motherboard with AMD Ryzen Threadripper PRO 9945WX processor.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Out of Time Revealed As New Roguelike From Manticore Games, Blends Tim
[Only registered and activated users can see links. Click Here To Register...] is an upcoming time travel roguelite that puts players into a cosmic anomaly that blends past, present, and future in chaotic co-op battles. The new game is being developed by Manticore Games, a new game studio comprised of talent formerly of Electronic Arts, Blizzard, Respawn, Xfire, Roblox, Trion Worlds, Crystal Dynamics, and Zynga, and it will be launching as an [Only registered and activated users can see links. Click Here To Register...] and console exclusive on September 25, 2025, although it's currently unclear if a future Steam launch is on the cards. The current pre-purchase price for Out of Time is $24.99, which includes three special mounts, three emotes, and four avatars.
The main premise of Out of Time is that players are put in teams of four players in co-op PvE battles—with PvP slated to be arriving in a future update—against enemies from the Medieval era, Modern era, and The Wastelands, a far-flung apocalyptic era set in the year 2199. At least three more eras are already planned for a later release, although there is no exact release roadmap yet. Out of Time emphasizes team work and ability and gear synergies, and one of the main highlights is that sticking together as a team grants buffs and increases survivability. There are a whopping 24 playable heroes, although Manticore Games says that the heroes don't lock you down into specific classes or roles. Instead, the game's mechanics encourage cooperative experimentation and gives players the freedom to adapt to the anomalies in their own unique way. Out of Time will feature tight fast-paced combat, an MMO-like hub, and a roguelike progression system.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Unreleased AMD Radeon "RX 7950 XTX" Prototype Surfaces Online
A previously unseen AMD graphics-card prototype has unexpectedly surfaced, not in a retailer's warehouse but on a Korean second-hand forum. This week, a Quasarzone user known as FP32 shared high-resolution photographs of what appears to be the cooling assembly for a never-released "RX 7950 XTX," allegedly sourced via China's Xianyu marketplace. At a staggering 34 cm in length and 5.5 cm in thickness, the triple-slot shroud outstrips the standard RX 7900 XTX reference cooler by roughly 5 cm in length and adds an entire slot of girth. The front houses three recessed eight-pin power connectors, suggesting board power well over 450 W, a figure more commonly associated with NVIDIA's RTX 4090 rather than an AMD Radeon, while a dense copper baseplate feeds multiple heatpipes that terminate in three striking red-tipped fins stamped "RDNA 3." Despite its superficial resemblance to AMD's shipping designs, the prototype's mounting points and LED cut-outs align with no known PCB, and the customary rear I/O bracket is entirely missing.
Attempts to trace serial labels in public component databases yielded no matches, reinforcing the theory that it was a one-off engineering sample. No PCB accompanied the cooler, preventing any live demonstrations or performance benchmarks. There have long been whispers about an AMD halo card, whether an RX 7950 XTX or even a dual-GPU RX 7990 XTX, to bridge the performance gap between NVIDIA's 80-class and 90-class offerings. The emergence of this monolithic cooler implies that AMD once considered a fully unlocked Navi 31 silicon pushed to higher clock speeds or paired with faster GDDR6/GDDR6X memory. The project may have been shelved due to soaring production costs, unwieldy thermal envelopes, or a strategic decision to focus on energy efficiency and value-oriented designs. Whatever the reason for its cancellation, this orphaned cooler now stands as a relic of AMD's road not taken, offering a glimpse into the company's highest ambitions before it chose a less aggressive path for its RDNA 3 lineup.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
ZeniMax Workers on Xbox Gaming Layoffs: 'Disgusting' and 'A Betrayal'
ZeniMax is just one of many game studios under the Xbox Gaming umbrella that has fallen victim to a [Only registered and activated users can see links. Click Here To Register...] in the name of profit. The layoffs, which occurred in early July and seemingly affected over 9,000 employees, according to [Only registered and activated users can see links. Click Here To Register...], were motivated by Microsoft's desire to "increase agility and effectiveness." However, workers at ZeniMax Media, the game studio behind Elder Scrolls Online, have recently spoken anonymously to [Only registered and activated users can see links. Click Here To Register...] and said that the layoffs have effectively had the opposite effect. One worker said "Everyone left now has to pick up the pieces as best they can. The morale and general confusion of it all has extended into our general workflow. We used to have very, very reliable people working on things, and they're no longer there." By all accounts, the layoffs have resulted in a severe brain drain and loss of institutional knowledge and experience, and the remaining workers at the studio have been left to pick up the pieces. One employee emphasized that, in some cases, the remaining staff will need to pick up the slack of multiple people who were laid off.
Part of the reason for the outsized effect on the remaining developers is just how chaotically the layoffs were handled, with one employee saying that they were locked out of all their company systems, including email and Slack, for hours before there was any communication from managers or higher-ups about what was going on. The chaotic management of the layoffs and their wide-reaching effects have severely diminished the morale of the workers who are still at ZeniMax, with one worker, Autumn Mitchell, who remains at ZeniMax, saying that "Morale is terrible. It's grotesque. People are stressed. They're crying." She continues to say "I also think we need to bring some people back. I don't see how we get through this work without bringing some people back," further implying that the workload and expectations placed on the workers still at ZeniMax are too much to handle for the remaining workers, especially if there is a standard of quality to be maintained.[Only registered and activated users can see links. Click Here To Register...]
(PR) ASUS Announces New Performance Records for Pro WS WRX90E-SAGE SE
ASUS today announced that the Pro WS WRX90E-SAGE SE workstation motherboard has scored 46 new performance records leveraging the latest AMD Ryzen Threadripper PRO processors, ranging from the PRO 9965WX to the PRO 9995WX. This sets a new benchmark for workstation-class performance, establishing this motherboard as the ultimate platform for professionals and overclockers who want to push the limits of CPU power. These groundbreaking results arrive thanks to the work of professional overclockers CENS, SEBY, bl4ckdot, Paul7347 and jiacheng_liu.
The AMD Ryzen Threadripper PRO 9995WX is the new king of the CPU hill, wielding 96 cores, 192 threads and a 5.4 GHz boost clock to carve out new performance territory. Professional overclockers CENS and SEBY pushed this chip to its limits, maintaining control on a knife's edge with the Pro WS WRX90E-SAGE SE. A raft of records was the result. Of particular note is the HWBOT 265 Benchmark 4K score. SEBY smashed his own previous world record - also attained with the Pro WS WRX90E-SAGE SE - by an incredible 20%.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
