Samsung Shows Galaxy Book5 Pro and Galaxy Book5 360 at CES 2025
Samsung has revealed two new laptop models at CES 2025: the Galaxy Book5 Pro and Galaxy Book5 360, both featuring Intel's latest processors and artificial intelligence capabilities. The Galaxy Book5 Pro comes in two sizes. The 16-inch version weighs 1.56 kg and includes a 76.1Wh battery, while the 14-inch model weighs 1.23 kg with a 63.1 Wh battery. Both laptops use AMOLED displays with 2880×1800 resolution and variable refresh rates from 48 to 120 Hz. Storage options reach 1 TB, with either 16 GB or 32 GB of memory available.
The Galaxy Book5 360 features a 15.6-inch touchscreen that can fold back 360 degrees, effectively turning the laptop into a tablet. It has a 1920×1080 resolution display and weighs 1.46 kg, with a 68.1 Wh battery. Both models use Intel's Core Ultra processors with built-in NPUs that Samsung uses for features like AI Select for searching and Photo Remaster for image enhancement. The laptops also integrate with other Samsung devices through features like Multi Control for unified device navigation and Quick Share for file transfers. The new laptops include standard connectivity options like Wi-Fi 7 and Bluetooth 5.4. Samsung claims the Pro models can achieve up to 25 hours of battery life, though real-world usage typically yields shorter durations.[Only registered and activated users can see links. Click Here To Register...]
LG Showcases UltraGear GX9 OLED Bendable 5K2K Gaming Monitors at CES 2
LG unveiled its UltraGear GX9 gaming monitor series at CES 2025, with three primary models featuring WOLED display technology and curved panels. The 45GX990A features a 45-inch bendable WOLED panel that transitions between flat and 900R curvature. The display offers 5K2K resolution (5,120 x 2,160), a 21:9 aspect ratio, and a 0.03 ms gray-to-gray response time. The 45GX950A utilizes the exact panel specifications but with a fixed 800R curve. Both models include DisplayPort 2.1, HDMI 2.1, and USB-C connectivity with 90 W power delivery. The displays support variable refresh rates through NVIDIA G-SYNC and AMD FreeSync Premium Pro certification. The second-generation Dual-Mode system is a distinct feature that enables switching between different aspect ratios (21:9 and 16:9) and screen sizes (39-, 34-, or 27 inches). The system provides eight preset configurations for resolution and refresh rate combinations.
The 39GX90SA rounds out the lineup with a 39-inch OLED panel featuring an 800R curve. This model integrates webOS for direct streaming functionality and includes USB Type-C ports for device connectivity. All monitors in the series utilize WOLED technology for color reproduction and incorporate Anti-Glare & Low Reflection coating to reduce screen reflections. The panels are certified for reduced blue light emissions. The 45-inch models achieve 125 pixels per inch through an RGWB subpixel layout. These displays maintain compatibility with current graphics cards while supporting the latest variable refresh rate technologies. The monitors feature a 4-side borderless design and, in the case of the 39GX90SA, include an L-shaped stand for space efficiency.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
LG Updates Gram Laptop Lineup at CES 2025 with AI Capabilities
LG Electronics has announced its 2025 Gram laptop lineup at CES 2025, featuring Intel's latest processors and a new AI system that combines on-device EXAONE language processing with cloud-based GPT-4o capabilities. The flagship Gram Pro (17Z90TR) features a 17-inch WQXGA LCD display with 2,560 x 1,600 resolution and a 31-144 Hz variable refresh rate. Powered by Intel Core Ultra 9 or Ultra 7 processors and an NVIDIA RTX 4050 with 6 GB GDDR6 memory, it supports up to 32 GB of LPDDR5X RAM at 8,533 MHz. The device includes dual SSD slots supporting up to 2 TB Gen 4 NVMe storage and a 90Wh battery, all within a 3.26-pound chassis.
The Gram Pro 2-in-1 (16T90TP) employs a 16-inch WQXGA+ OLED panel with 2,880 x 1,800 resolution and a 48-120 Hz refresh rate. Running on Intel Core Ultra 7 or Ultra 5 processors with Intel Arc graphics, it features up to 32 GB of LPDDR5X memory at 8,400 MHz. The convertible weighs 3.08 pounds and includes a 77Wh battery and a mega dual cooling system. At 2.73 pounds, the Gram Pro 16Z90TS combines Intel Core Ultra 7 processors with Intel Arc graphics, featuring a 16-inch WQXGA LCD display and 77Wh battery. All Pro models include dual USB4 Gen3x2 Type-C ports with Thunderbolt 4 support and HDMI 2.1 outputs capable of 4K@60 Hz.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
XFX Radeon RX 9070 Series Graphics Cards at 2025 International CES
XFX at the 2025 International CES showed off a pair of Radeon RX 9070 series custom-design graphics cards. The company will keep these designs common to both the flagship RX 9070 XT, and the RX 9070. Both board designs were shown off at AMD's RX 9070 series booth. The premium custom design is being referred to as "Black." There are actually two sub-variants of this card, one called Black, which lacks any RGB LED lighting, but a second more premium one where the top of the card has an RGB LED diffuser spanning the entire top-front edge, including the triangular ends with the XFX and Radeon logos. This card wasn't shown to use, but is part of AMD's CES pre-brief.
The premium Black card features a large aluminium fin-stack heatsink, along with a trio of what look like 100 mm and 90 mm axial airflow fans. The metal backplate has a ridged pattern. The PCB underneath appears to be about three quarters the length of the card, with a large cutout in the backplate letting much of the airflow from the third fan go through the heatsink and out the back. This card draws power from three 8-pin PCIe power connectors, for a total power input configuration of 525 W, which is obviously high for what is expected to be a 300 W-class GPU, but this isn't the only card with an over-the-top power input configuration. The ASUS TUF Gaming has three 8-pin PCIe power, while the ASRock Taichi uses a 16-pin 12V2x6. Most RX 9070 series cards we've seen have just two 8-pin power connectors.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Huion Showcases Camvas 16 Gen 3 Professional Pen-Display
Huion specializes in graphics tablets and pen displays. Its products go up against those from Wacom. We've seen a host of announcements at the [Only registered and activated users can see links. Click Here To Register...], but the company was saving its next-gen for the 2025 CES. The company showed us their latest Kamvas 16 Gen 3, a 16-inch high-precision pen display for hand-drawn graphics applications. The display comes with a QHD resolution (2560 x 1440 pixels), which lends a respectable 184 ppi of pixel density. The display also featuers a 120% sRGB wide color gamut. The display features Huion's PenTech 4.0 technology, a high-resolution graphics pen input interface that the company introduced in 2024. This gives the input surface 16,384 pressure sensitivity levels. The display is compatible with Huion's PW600, and PW600S digital pens.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
HAVN x King Mod Systems Gaming PC Showcased at CES 2025
HAVN and King Mod Systems have partnered up on putting together a high-end gaming PC—a sample build was assembled in good time and sent out to Las Vegas. TechPowerUp inspected the fruit of their labors earlier this week at CES 2025. Unsurprisingly, the two collaborators have opted to use a white finish HAVN HS 420 VGPU Edition case—feel free to check out Darksaber's glowing [Only registered and activated users can see links. Click Here To Register...]. A black variant was positioned close by, so it was convenient to compare and contrast between the sibling enclosures. Coincidentally, TechPowerUp and HAVN teamed up on a [Only registered and activated users can see links. Click Here To Register...] of four HAVN HS 420 models last month.
The HAVN x King Mod Systems Gaming PC utilizes some fine internals, but its AMD [Only registered and activated users can see links. Click Here To Register...] processor will become less cutting-edge in the near future. Team Red is lining up the [Only registered and activated users can see links. Click Here To Register...] CPU for launch around March 2025. HAVN and King Mod Systems have selected Gigabyte's B650E AORUS Elite X AX ICE mainboard for their showroom build, along with a white TRYX PANORAMA 360 mm AIO ARGB liquid cooler, an [Only registered and activated users can see links. Click Here To Register...] graphics card, and a 32 GB (2 x 16 GB) Corsair Vengeance RGB DDR5 5600 CL36 memory kit.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Cervoz Launches T445 Single-sided M.2 NVMe SSD
Struggling to balance space, performance, and thermal management in compact industrial platforms? The new Cervoz [Only registered and activated users can see links. Click Here To Register...] M.2 2280 NVMe PCIe Gen 4x4 SSD delivers with its space-saving single-sided design, high-speed capabilities, and wide temperature resilience. Ideal for IoT gateways, industrial tablets, and automation systems. Ready to elevate your storage solution? Discover how the T445 drives efficiency in demanding industrial environments.
Single-Sided Design for Space-Limited Environments
One of the standout features of the T445 is its single-sided design, making it especially suited for space-constrained systems. By consolidating critical components like the NAND flash, controller, and power management IC on one side, it optimizes space efficiency and improves thermal management for better airflow and heat dissipation. This design is particularly important for fanless systems and compact environments, ensuring reliable performance even in extreme conditions. With a slim profile—single-sided design that reduces height by 1.35 mm compared to dual-sided models—the T445 is engineered for easy installation in tight industrial setups, providing high efficiency without compromising durability or speed.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
MAINGEAR Presents Shroud Signature Edition Gaming PC at CES 2025
MAINGEAR has collaborated on developing and building a Signature Edition Gaming PC with popular Twitch streamer "Shroud" (aka Michael Grzesiek). This high-performance system made its debut at CES 2025—the TechPowerUp team took a closer look during a demo session with MAINGEAR. Shroud and his partners at the New Jersey-based gaming and workstation specialist have settled on building inside HAVN's HS 420 VGPU Dual-Chamber ATX mid-tower case (available in black or white finishes). This premium chassis is a great match for the crème de la crème of high-performance gaming-centric components—naturally, AMD's [Only registered and activated users can see links. Click Here To Register...] is the de-facto choice of CPU here.
Shroud's Signature Edition Gaming PC will be specced with the latest NVIDIA flagship graphics card—TechPowerUp noticed that the demonstration build featured a Founders Edition GeForce RTX 4090. It is possible that MAINGEAR is working on updating this system with a GeForce RTX 5090 card, once the "Blackwell" GPU family heads to market. The specification sheet also lists MAINGEAR's Epic 420 mm AIO liquid cooler, an AsRock Phantom Gaming X870E Nova WiFi motherboard, 48 GB (2 x 24 GB) T-Force Xtreem ARGB 8000 MHz CL34 memory, a 2 TB T-Force Cardea A440 Gen 4 M.2 SSD, and an FSP PTM Pro Gen 5 80+ 1200 W PSU.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Microsoft Flight Simulator 2024 Devs Discuss Upcoming Sim Update
After a break for the holiday season to recharge, refresh, and spend time with our families, we're back this week and hard at work updating Microsoft Flight Simulator 2024! As we begin the new year, our teams are focused on delivering the first major updates, including Sim Update 1, while also finalizing preparations for the Marketplace launch in Microsoft Flight Simulator 2024.
We have analyzed all the feedback provided over the past weeks and months and are prioritizing bug fixes and improvements based on community input. Because of this, we are spending this week working on the Feedback Snapshot and will have an updated version for you in next week's blog. We are also excited to announce that World Update: Brazil is on the horizon! These updates are coming soon, and we will provide more information on the timeline as it becomes available. We appreciate your support as we continue to enhance the simming experience for our community.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
MSI Shows Off "Project Zero X" PC Build at CES 2025
MSI's Back-Connect motherboard design provides the foundation of Project Zero X—specific components were not listed when TechPowerUp examined this sleek PC build. A panoramic glass case design houses an all-MSI ecosystem that is "clean and cable-free" thanks to the aforementioned back-mounted layout. Clutter is kept out of view in a rear compartment and the I/O panel is positioned at the back of Project Zero X's enclosure (see photo below). TechPowerUp enjoyed looking at this refreshingly simple arrangement through the case's four-sided glass panel. The build's vertically-mounted MSI-brand GeForce RTX graphics card is positioned next to a signature Project Zero X-branded motherboard.
A product placard mentions that Project Zero X features an integrated "Full-Coverage Heatsink"—providing "comprehensive" cooling coverage across the system. MSI also claims that there are no air circulation dead spots—thanks to a unified airflow design. The cooling system seems to be mostly hidden away inside the enclosure's rear and bottom compartments.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Hyper Light Breaker Launches To Early Access on Steam With Surprising
Hyper Light Breaker, [Only registered and activated users can see links. Click Here To Register...] has finally launched to early access on Steam, and despite the surprising success of its predecessors, Hyper Light Drifter and Solar Ash, Hyper Light Breaker isn't looking like the break-out indie hit of the month. While the game has garnered a solid 5,230 peak concurrent players just five hours after launch, the Steam reviews are hardly anything to write home about so far.
According to [Only registered and activated users can see links. Click Here To Register...], Hyper Light Breaker has a review rating of just 35.5%, with 31.4% of the reviews giving the game a positive rating, while 68.6% of Steam reviewers gave it a negative score. Fortunately, or unfortunately, depending on how you look at it, it looks like most of the issues with Hyper Light Breaker stem from the game's early access status. Early reviews on Steam report that the game's core mechanics and gameplay loop are satisfying, but that the game, overall, seems like it needs more time in the oven. Some of the more serious complaints when it comes to Hyper Light Breaker relate to the game's combat being somewhat difficult to grasp, progression feeling unsubstantial, initial difficulty being too high, and a steep learning curve. Others pointed out that there appears to be a lot of missing content. That said, as some reviewers have pointed out, the game is in early access. If we look at the likes of Windblown—or No Man's Sky for an example on a longer timeframe—it's easy to see the value in an early access period and community feedback. If Heart Machine, the developer behind Hyper Light Breaker, uses its community feedback properly and implements fixes to issues as they arise, it seems like it could be a game enjoyed by many indie gamers.
GOG Amps Up Game Preservation Efforts with New EFGAMP Game Archive Pro
We [Only registered and activated users can see links. Click Here To Register...], with the storefront preserving two 30-year-old Warcraft games. Now, however, [Only registered and activated users can see links. Click Here To Register...] for future preservation efforts. EFGAMP is "the largest organization in Europe dedicated to preserving video games as cultural heritage," giving GOG's commitment to game preservation a lot more weight than previously. The partnership could also help GOG work within and with European governmental and non-governmental institutions, like museums and other organizations, in order to further the game preservation cause.
Perhaps more interestingly, as a game distribution platform with some development talent behind it, GOG actually brings something to the table that was previously missing from EFGAMP as a foundation. In the announcement, the foundation and GOG claim that 2024 was something of a tipping point for consumers when it comes to both the erosion of game ownership and game preservation as a whole. The subject of game ownership was a recurring theme in 2024, with games like [Only registered and activated users can see links. Click Here To Register...] joining the aforementioned Warcraft games in being delisted from stores—at least with the GOG delisting, the games are still maintained for existing owners. The goal of both GOG and EFGAMP is to preserve the history of gaming culture, allowing future generations to experience and learn about important moments in gaming history.[Only registered and activated users can see links. Click Here To Register...]
(PR) NVIDIA DLSS Comes to Assetto Corsa EVO, DYNASTY WARRIORS: ORIGINS
More than 700 games and applications feature RTX technologies, and each week new games integrating NVIDIA DLSS, NVIDIA Reflex, and advanced ray-traced effects are released or announced, delivering the definitive PC experience for GeForce RTX players. On January 30th, DLSS gets even better with the launch of DLSS 4. Featuring improvements to all existing DLSS technologies, and our new DLSS Multi Frame Generation performance multiplier, DLSS 4 delivers supreme speed and superior visuals, powered by AI. Ahead of DLSS 4's release, there are another 5 DLSS games available to play this week: Assetto Corsa EVO, DYNASTY WARRIORS: ORIGINS, Honkai: Star Rail, SMITE 2, and Tankhead.
NVIDIA DLSS 4 With Multi Frame Generation Available January 30th
NVIDIA DLSS is a suite of neural rendering technologies powered by GeForce RTX Tensor Cores that boosts frame rates while delivering crisp, high-quality images that rival native resolution rendering. On January 30th, we're upgrading DLSS once again with the release of DLSS 4, featuring DLSS Multi Frame Generation for GeForce RTX 50 Series graphics cards and laptops, and upgrades to all other DLSS technologies.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Moondrop Showcases Meteor Wired and Robin Wireless IEMs at CES 2025
Leiyin Audio, the same brand that had kindly invited us to attend the [Only registered and activated users can see links. Click Here To Register...] last year, had a large booth at CES where Moondrop also had a presence thanks to its new Moondrop Global company that is now responsible for all operations outside China. There was a large showing from Moondrop thus, with most recently launched products from the past year to be found here. Our eyes were caught on the recently released Meteor, a 1 DD +2 BA +4 planar magnetic tribrid driver set that uses a relatively large 13 mm dynamic driver fit into a large faceplate protrusion that is capped by, as the name suggests, a piece of genuine meteorite fragment. It uses Moondrop's new XTM crossover technology and promises good quality bass as part of a balanced tuning for [Only registered and activated users can see links. Click Here To Register...]. Expect a full review on TechPowerUp, as the CES sample was already impressive despite the noisy show floor conditions.
Also at the booth was Moondrop's immensely popular Robin, a true wireless stereo (TWS) set developed in collaboration with Honkai: Star Rail, an even more popular video game. Robin is a playable character in the game, and you will see it adorned on the TWS set too. To no surprise, this is right up Moondrop's marketing alley given how much it likes to use female artwork to attract customers, although at least here we do get a legitimately well-tuned set of TWS IEMs—quite rare even in 2025—with app support for customizable tonalities and touch controls too. The carry case further builds upon the theme and, at $99, [Only registered and activated users can see links. Click Here To Register...] has already proven to be a huge commercial success less than a month into its global launch.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Yeston Reveals GeForce RTX 50 Series Sakura & Game Ace Custom Models
Yeston's social media accounts have revealed upcoming NVIDIA "Blackwell" GPU-based Sakura Atlantis, Sakura and Game Ace models—a single teaser image shows off three different cards that will eventually contain GeForce RTX 50 series graphics hardware. Yeston has deployed common aesthetic traits across the three ranges—notably white PCBs and I/O brackets. Yeston previously revealed their new Sakura Atlantis shroud design with its [Only registered and activated users can see links. Click Here To Register...] model. Today's product unveiling does not include any information about specific Team Green GPU SKUs, but it would be safe to assume that the upper-echelon models will sport Sakura Atlantis livery.
The older Yeston Sakura and Game Ace designs have been rolled out across a number of current-gen "Ada Lovelace" GeForce RTX 40 series GPUs. A quick analysis of Yeston [Only registered and activated users can see links. Click Here To Register...] hierarchies shows lower-end GPUs ([Only registered and activated users can see links. Click Here To Register...] and 4060) sporting the Game Ace shroud. The Sakura design is available across a selection of mid-tier GeForce RTX 4070 Ti and [Only registered and activated users can see links. Click Here To Register...] models. VideoCardz proposes that the Sakura Atlantis cooling solution could be robust enough—based on the Radeon RX 9070 XT's rumored 300 W TBP—to take on GeForce RTX 5080 (360 W) and 5070 Ti (300 W) GPUs. TechPowerUp expects Yeston to make further announcements closer to NVIDIA Blackwell's market debut at the end of this month.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) NCSoft Announces Blade & Soul NEO's Upcoming USA & EU Launch
NC America announced today Blade & Soul NEO, the modern reinterpretation of Blade & Soul's signature fantasy universe, is coming soon to PC in North America and Europe. Featuring a beautiful visually enhanced experience, the original, well-crafted storyline, Infinite Windwalk (the "glide" ability), and a handful of enticing gameplay features, Blade & Soul NEO fulfills players' desire to re-live that pure MMO action fantasy experience they once knew.
Offering an exclusive pre-registration package, available today -- including a cosmetically enhanced character outfit, in-game currency, and more -- NC America will actively roll out new information, community activities and more on its revamped website between today and launch. [Only registered and activated users can see links. Click Here To Register...] now.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Intel 12th Gen "Alder Lake" Mobile CPUs Face Retirement, HX-series Spa
Intel product change notification documents—published on January 6—have revealed the planned "End of Life" (EOL) phasing out of 12th Generation "Alder Lake" mobile processor models. [Only registered and activated users can see links. Click Here To Register...] has pored over the listed products/SKUs and concluded that the vast majority of Team Blue's mobile-oriented Alder Lake selection are destined for retirement. Team Blue's HX series is being kept alive for a little while longer. Two documents show differing "discontinuance timelines" for their respective inventories—including lower-end Celeron and Pentium Gold SKUs, as well as familiar higher-up Core i3, i5, i7, and i9 families. U, P, H and HK-affixed models are lined up for the chopping block.
Intel's 13th Generation "Raptor Lake" mobile processor selection—comprised of Core 100 (series 1) and Core 200 (series 2)—offers similar silicon makeup. Many equivalent alternatives to older generation "Alder Lake" chips reside here—Tom's Hardware presented a key example: "[Only registered and activated users can see links. Click Here To Register...], which is designated for thin and lightweight laptops. OEMs can instead opt for the [Only registered and activated users can see links. Click Here To Register...], the [Only registered and activated users can see links. Click Here To Register...], or the [Only registered and activated users can see links. Click Here To Register...], as they're just better bins of the 1235U on the same FCBGA1744 socket." A significant number of Alder Lake mobile SKUs will be available to OEMs for ordering up until 26 April, with final shipments heading out on 25 October. The rest have been assigned a July 25 order cut-off date, with final shipments scheduled on 26 January 2026.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Ultra Accelerator Link Consortium (UALink) Welcomes Alibaba, Appl
Ultra Accelerator Link Consortium (UALink) has announced the expansion of its Board of Directors with the election of Alibaba Cloud Computing Ltd., Apple Inc., and Synopsys Inc. The new Board members will leverage their industry knowledge to advance development and industry adoption of UALink - a high-speed, scale-up interconnect for next-generation AI cluster performance.
"Alibaba Cloud believes that driving AI computing accelerator scale-up interconnection technology by defining core needs and solutions from the perspective of cloud computing and applications has significant value in building the competitiveness of intelligent computing supernodes," said Qiang Liu, VP of Alibaba Cloud, GM of Alibaba Cloud Server Infrastructure. "The UALink consortium, as a leader in the interconnect field of AI accelerators, has brought together key members from the AI infrastructure industry to work together to define interconnect protocol which is natively designed for AI accelerators, driving innovation in AI infrastructure. This will strongly promote the innovation of AI infrastructure and improve the execution efficiency of AI workloads, contributing to the establishment of an open and innovative industry ecosystem."[Only registered and activated users can see links. Click Here To Register...]
YouTuber Stumbles Upon NVIDIA GeForce RTX 4090 "TITAN" Part at CES 202
NVIDIA is focused on forward momentum—Jensen & Co. pounded the showroom floor at last week's CES trade with their next-gen "Blackwell" GPUs in hand. Team Green's GeForce RTX 50-series was one of the headline acts, but the preceding RTX 40 "Ada Lovelace" family made occasional appearances. Hardware enthusiasts were not expecting the re-emergence of an older unreleased model at CES 2025, but a YouTuber discovered the supposed RTX 4090 "[Only registered and activated users can see links. Click Here To Register...]" prototype's cooling solution frame. TechPowerUp's reported on this rare beast [Only registered and activated users can see links. Click Here To Register...], and Gamers Nexus obtained an example for analysis (view their video feature below).
Industry experts believe that an unnamed contract manufacturer was tasked with producing the TITAN's quad-slot cooling solution—informed sources say that it was designed to temper the full-force of Team Green's unlocked [Only registered and activated users can see links. Click Here To Register...]. This contract company reportedly displayed various NVIDIA-related component parts in Las Vegas last week. RTX 40-era Founders Edition font was evident on the TITAN's frame—a VideoCardz news piece highlights the component's silver/magnesium color scheme. This presents further proof of inclusion within that Founders Edition generation.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Gigabyte Brix Extreme Mini PC Launched With Ryzen 7 8840U "Hawk Point"
The list of mini PCs available on the market has grown quite a bit in the past few weeks, with a bunch of such systems getting unveiled at CES 2025. Now, Gigabyte clearly does not wish to be left out of the party either, and has unveiled its Brix Extreme mini PC powered by a last-gen, but decently powerful AMD "Hawk Point" APU and a plethora of connectivity options in a compact package.
The system, as mentioned, boasts the 28-watt Ryzen 7 8840U PRO APU, which sports 8 Zen 4 cores and 16 threads. Performance should be identical to its non-PRO counterpart, which should put it roughly in the same class as the Intel Core Ultra 256V "Lunar Lake" CPU. The APU is paired with up to 64 GB of DDR5-5600 memory. Dual M.2 2280 slots take care of storage requirements, both of which are user-accessible.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
