Cand ti-a fost sters postul ti s-a indicat un link [Only registered and activated users can see links. Click Here To Register...]
Ai in el explicatia.
Sanatate!
OK, am citit mai atent postul #159 si nu mai am obiectii la actiunea colegului @zmeura.
Ca sa nu se mai inflameze nimeni, folosesc sablonul postului #160 (urmatorul):
*******************************************************************Quote:
Originally Posted by amu92 [Only registered and activated users can see links. Click Here To Register...]
Asa e bine ?
A-propos, NU raman dator.
Nu, trimite-le lor mail direct; ai nevoie de intermediari?Quote:
Originally Posted by mateda [Only registered and activated users can see links. Click Here To Register...]
Nu este cazul.Quote:
pai vezi,voi santeti pauza la capitolu regulament:)vezi tu ca la acel quote nu a fost citat tot postul tau,intelegi?no offence:)
cat despre polemica cum zici tu,cu toate ca la mine sant 13 grade:)
Salut, noi aici, Im doar navigat pe in Irlanda de la
Vă rugăm să familair este cineva cu
Extracţia din cheile de decriptare master DT08
(Dintr-un rom 180 nagra 3 Card), lucru care pentru toţi
abonaţi pe furnizorii noştri special pentru a construi
le in codul cam pentru a permite partajarea pe Dreambox ..
Hi, Im new here, just surfed on in from Ireland
Please is anyone familair with the
Extraction of the master DT08 decryption keys
(from a rom 180 Nagra 3 card) that work for all
subscribers on our particular providers to build
them into the cam code to enable sharing on Dreambox.
I don't think that is somebody who can do this from N3 cards.Best chance is from receiver,for the moment.
Is thyere any softwares that will help with the location of RSA in flash if box can be Jtag.
Thanx
No,depends of the receiver software and the location may be diferent from an receiver to another.
factory reset ar trebui sa minimizeze diferentele intre receivere :p
Why in the explianation here below using Rqcs is their no mention of an absolute need for RSA.
Code:
Added support for ROM180. Several European providers such as Digital+ (Spain) use this
N3 card.
- rqcs now supports 4 methods of session negotiation: DT08, DT06 Key 0D Expansion,
Plain CAM N, and Secondary Key methods. Please read carefully rqcs.conf as I have given a
detailed description of how they may be used and also the pieces of data that are needed
for each one of them to work. This is to add flexibility.
- Another batch of small bug fixes and improvements.
# ----------------------------- Session Negotiation ---------------------------
# Following is a set of 4 parameters that may be used to achieve successful
# session key negotiation with the card.
# DT08 session negotiation method. Just the Box Key is required for this
# method to work. This is the simpler, preferable method, however, not all cards
# have DT08's.
box_key=8CA6A88CFDE2E263
# DT06 Key 0D session negotiation. An alternative method for when the card does
# not have a DT08. Useful when you have the card's DT06 and not the IRD's
# Secondary Key.
# If this value is specified, the DT06 method will be attempted instead
# of the DT08 one.
# IMPORTANT: BOTH the Box Key and the DT06 are needed for this method to work.
# HINT: The DT06 Key 0D *does not* change when a card is swapped, if you
# have this for an old card that was married to an IRD, it will work for
# newer cards on that same IRD.
dt06_key_0d=
# Plain CAM N negotiation method. Another alternative method for when the card
# does not have a DT08. It is somewhat equivalent to the DT06 Key 0D method and
# again, useful when you have the card's CAM N obtained from an expanded
# DT06 Key 0D. As a sidenote, this parameter is equivalent to newcs's
# <rsa></rsa> parameter.
# IMPORTANT: BOTH the Box Key and CAM N are needed for this method to work.
cam_n=
# Secondary key session negotiation method. If your card does not have a DT08,
# and you can't extract the cam's N key or DT06 Key 0D, this is the only possible
# method. The secondary key must be extracted from a provider IRD's TSOP dump.
# If this value is specified, it will supercede the DT08, DT06 Key 0D and Plain
# CAM N session negotiation methods. Neither the Box Key, DT06 Key 0D nor CAM N
# parameters are needed for this method to work, and will be ignored if they
# are provided.
# The secondary key is 96 bytes long and has the following structure:
# II II II II XX XX XX XX XX XX XX XX XX XX Y1 Y1 Y1 Y1 Y1 Y1 Y1 Y1
# SK SK SK SK SK SK SK SK SK SK SK SK SK SK SK SK
# Y2 Y2 Y2 Y2 Y2 Y2 Y2 Y2 CS CS
# II = IRD serial number.
# XX = Unimportant.
# Y1, Y2 = SK signature and also used to calculate the box key.
# SK = Actual secondary key data (CAM N, public modulus).
# CS = Checksum.
# NOTE: The Secondary Key should be specified as a single line without spaces
# (like the Box Key), and should be the exact 96 bytes as extracted from the IRD.
# NOTE: You can copy the 64 bytes that are labeled 'SK' from the Secondary
# Key, and use them in the cam_n parameter. This will also work, in that case
# the Box Key parameter must also be provided.
secondary_key=
# Optional. Card provider's IRD RSA key (only relevant for DT08 session
# negotiation method.
rsa_key=
that is a very sensitive isue mate u won't get ur answers here trust me and i don't know it
despre polonez si sculele lui:
Salutare tuturor!
am citit tot threadul asta in speranta ca voi gasi ceva despre extragerea bk si rsa dintr-un 7160 (cutia dubla de la gigitv cu carduri rosu/albastru),d ar pana acum n-am gasit nimic concret.
A reusit cineva?
Craciun Fericit!
Am un hss 1160, cum se poate rezolva rsa key?
il duci la doctor sa-l opereze:)
Caut doctor pt. 1160!
Ce fel de doctor cauti ?
Threadul acesta nu are sens, ar trebui sters !!!
voi propune stafului stergerea lui ... pana atunci acest thread se inchide
