aaf board....
aaf board....
n-ash preash crede :)Quote:
Originally Posted by dan2000 [Only registered and activated users can see links. Click Here To Register...]
mai stai o mana...
mo eu nu pot sa intru acolo si nu inteleg de ce . am primit in schimb mail de la ei.Quote:
Originally Posted by whitesnake [Only registered and activated users can see links. Click Here To Register...]
aici:
care se baga? :)
e2-USF910 [Only registered and activated users can see links. Click Here To Register...]
<<team DuckTales proudly presents the first enigma2 alpha image for Kathrein UFS-910.>>
a incercat cineva mgcamd pe katy ca si client gbox pe router ( wrt54gl ) ?
Video cu en2 care ruleze pe kathrein e identic cu dm800
AAF2.0-EM-Edition2008
noutati, ceva?
ca-mi vine si mie un k910...
AAF2.0-EM-Endspiel-Edition2008 Image for the UFS 910
Barry Allen & KCC included, with documentation.
functioneaza perfect cel putin la mine . cred ca e cea mai stabila img de pana acum.
Se poate download AAF2.0a Flash, ceva imbunatatiri+animatieboot pe display...
INSTALARE DISEQC1.2 CARE MI-A FUNCTIONAT CU TOATE IMAGINILE INCEPAND CU FW1.4 PANA LA AAF2.0 SI RUDEBOX 1.05
ATENTIE : IMEDIAT DUPA INSTALARE RESTART SI APARE NUMELE SATELITULUI PE DISPLAY LA KATHI IAR ANTENA PLEACA DUPA 3 SECUNDE DE LA COMANDA.....FOARTE RAPID !!!!!
1. In /data/bin : " diseqcsend1.2 " si
"diseqc_mon " care are urmatorul script :
#!/bin/sh
# diseqc_mon - diseqc monitoring script
sleep 3
if [ -f /data/diseqc/diseqc.cfg ]; then
cp -p /config/PROPERTY_TABLE /tmp/property.tmp
satellite=`/data/bin/curchan -satname | /data/bin/awk '{print substr($0,6)}'`
/data/vfdctl -c "$satellite" &
while :
do
if [ /config/PROPERTY_TABLE -nt /tmp/property.tmp \
-o /config/PROPERTY_TABLE -ot /tmp/property.tmp ] ; then
newsat=`/data/bin/curchan -satname | /data/bin/awk '{print substr($0,6)}'`
if [ "$newsat" != "" -a "$newsat" != "$satellite" ] ; then
satellite=$newsat
satpos=`grep "$satellite" /data/diseqc/diseqc.cfg | /data/bin/awk '{print $1}'`
if [ "$satpos" != "" -a "$satpos" != "255" ] ; then
/data/bin/diseqcsend1.2 224 49 107 $satpos 1>/dev/null 2>&1
fi
fi
fi
sleep 1
done
else
/data/vfdctl -c "No diseqc.cfg!" &
fi
2. In /data/diseqc : diseqc_cfg
3. In config " init.sh " cu urmatorul script :
!/bin/sh
# universelles Startscript by AAF-Team
# Swapfile aktivieren
#[ -e '/tmp/usb/VIDEO_DISC (1)/swapfile' ] && /bin/mkswap '/tmp/usb/VIDEO_DISC (1)/swapfile'; swapon '/tmp/usb/VIDEO_DISC (1)/swapfile'
#[ -e '/tmp/usb/VOLUME (1)/swapfile' ] && /bin/mkswap '/tmp/usb/VOLUME (1)/swapfile'; swapon '/tmp/usb/VOLUME (1)/swapfile'
#[ -e '/tmp/usb/USB_DISK (1)/swapfile' ] && /bin/mkswap '/tmp/usb/USB_DISK (1)/swapfile'; swapon '/tmp/usb/USB_DISK (1)/swapfile'
# Cifs aktivieren
insmod /data/bin/cifs.ko
# NFS mounten
# mount -t nfs 192.168.0.20:/mnt/IDE1/nas /mnt/nfs -o rw,nolock,intr,soft,udp,rsize=4096,wsize=4096
# Cifs mounten
# mount -t cifs //192.168.0.20/video /mnt/nfs/ -o user=harry,passwort=hase
# EPG auslagern
if [ -e /config/epg_move ]; then
cp /data/epg.dat /tmp/epg.dat
rm -f /data/epg.dat
ln -s /tmp/epg.dat /data/epg.dat
/data/vfdctl "EPG ausgelagert"
sleep 1
fi
# fuer Snapshot verlinken
ln -s /tmp/ /data/www/
# Http-Daemon starten
/bin/busybox httpd -h /data/www &
# Radio Infos auf VFD
if [ -e /config/radio_on ]; then
/data/bin/radioinfo -o 1 -d /data/plugins/radioinfo &
/data/vfdctl "Radioinfo gestartet"
sleep 1
fi
# Clock on display
if [ -e /config/time_show ]; then
/data/plugins/addon-man/Stime.sh &
/data/vfdctl "Stime gestartet"
sleep 1
fi
# Symbole im VFD Display
if [ -e /config/symb_off ]; then
/data/plugins/addon-man/symboff.sh &
fi
#HDD Standby nach 1 Min Untaetigkeit
#/data/plugins/stbauto.sh &
# DiseqC 1.1/1.2 autoswitch
/data/bin/diseqc_mon &
# OSD Menue starten
/data/menue/make_dev.sh
/data/plugins/osd/osdsh.sh
Salut
Am si eu un UFS910 de cateva zile. Mi-am montat antena pe HB 13E si as vrea sa prind si eu macar 1 program HD. Nu stiu ce si cum se configureaza. Ma puteti ajuta cu niste sfaturi sau o documentatie?
Thanks
hello nimic nou de 2 saptamani pt. acest receiver, a "murit" pe acest forum pacat.
Nu Kathrein este problema. Problema se afla in firea noastra de romani: dorim sa ne rezolvam problema fara a ajuta si noi pe cineva.
Sfatul meu este sa postezi problema ta punctual pe un site "de afara".
noutati !
Enigma2 merge neasteptat de bine pe Kathy. Inclusiv toate tipurile de diseqc, din cite am citit pe net.
Personal am testat doar Diseqc 1.1 cu 8 sateliti si merge perfect, schimba instantaneu.
Hardware-ul (diseqc) folosit de mine e de marca Spaun.
E clar ca e rezolvata si problema cu Favoritii/Bouquets si anume nu mai exista limita de 8 ca la softul original.
Mai lipseste doar emu, care e pe vine.
Imi pun sperante in Mbox care l-am testat pe AAF image si merge destul de bine insa are si unele lipsuri care vor fi remediate.
Kathy cu enigma2 la un pret mediu de vreo...280€ este un receiver nu bun ci foarte bun, chiar daca nu are cardreader.
Pe Mbox se va putea face si reshare de pe cardreader extern gen Phoenix.
Probabil se vor putea lega chiar mai multe Phoenix-uri si se vor putea shar-ui mai multe carduri.
Nu m-am indoit niciodata de potentialul acestui receiver. Eram convins ca mai devreme sau mai tirziu va merge orice pe el.
Chinezii il cloneaza deja din momentul cind au aparut zvonuri si filmulete pe youtube care anuntau enigma2 pt. Kathy.
Daca ei il cloneaza, inseamna ca exista cerere pe piata.
Sint bucuros ca am 2 Kathy si sint bucuros ca mi-am convins unii(nu toti) prieteni
sa isi cumpere Kathrein UFS 910 si sa nu dea banii aia in plus(150-200€) pe DM 800.
PS: inca nu-l recomand celor care nu se descurca cu un program FTP sau nu au cunostinte de PC si nici celor care vor imediat sharing sau decodari.
Inca este un aparat pt. pasionati, pt. cei care au placerea de "a se juca",de a experimenta in timpul liber si asi consuma nervii. :D
KATHREIN UFS 910 mi l-au adus fara telecomanda, se poate de pornit cumva fara telecomanda. Sau daca face sa-l iau shi fara telecomanda. Se gaseshte ea ushor. Cam cat ar face el fara telecomanda? Va rog un sfat. multumesc anticipat.
Extraterestrii l-au adus?Quote:
Originally Posted by vladcarama [Only registered and activated users can see links. Click Here To Register...]
Se poate dar e pretentios. Eu am 2 telecomenzi cu macro si programare pe PC Logitrch si nu prea merge bine cu ele.
Sunt alte telecomenzi cu care merge bine.
Da, exatratereshtrii, numai ca cei care lucreaza in afara pamantului nostru (peste hotarele tarii). :D
