In EXCLUSIVITATE ABCOM r9057
La [Only registered and activated users can see links. Click Here To Register...]
salut la toata lumea e cineva care a probat imaginea cum merge
ca imagina de DGS 9047 nu ceva exeptional!
eu nu inteleg, abcom ce ii face, ii schimba doar numele si webif?
Da ai dreptate asa face plus ceva bug-uri minore.Se ocupa cu alte lucruri acuma :dance:
Azi o sa aveti o mare suprinza din partea RSP forum pt posesori de IPBOX 910, si daca reusim si pt posesori de ipbox 900.O sa fie ceva care o sa exista la forum asta si are legatura cu firmware lui IPBOX!!!!
MBox Web Interface by cable_stork
Version: 1 BETA 1 - PRE
Release date: 11 Mar 09
Supports MBox version: 0.4 BETA 023-4
Installation instructions:
1. Place binary file in /var/bin or any other desired location
mbox-wi.x86 - linux pc
mbox-wi.ppc - dreambox (ppc)
2. Copy mbox-wi-templates directory (and contents) to /var/etc/mbox-wi-templates/
3. Copy mbox-wi.cfg to /var/keys/mbox-wi.cfg
4. Change web server listen port in mbox-wi.cfg (or leave as default - 23000)
Changelog:
- First release
- No 'Reset' support
- Known styling bug on CwShare Configuration page
- No HTTP authentication
- Largest supported cwshare.cfg is 4.9kb
o sa il gasiti la sectiunea EMU-MBOX
Incubuscam v.075
12/03/1956, V0.75
- fixed auto-reconnection on servers
- fixed multi-server connections
- fixed many bugs on memory that caused cam's crashes
- fixed timeshift
- fixed audio change selection wich cause the stop of video/audio on original dgs firmware
GBOX protocol still not fully supported (i can't test it but i think it shouldn't work in this version)
Dupa testuri de 3-4 ori am ajuns la concluzia ca ultima versiuna de incubus camd 0.75 e peste de asteptarile noastre!Merge fara sa opreste brusc,se deschide canale destul de repede....Mai mult nu spun va las sa il instalati si sa vedeti ce tare merge!!!
Now added to nlb panel hotfix update.
DA! Am facut si eu niste teste cu noul Incubus pe imaginea nlb9047-910 si e surprinzator de stabil.
Merge perfect cu mai multe linii.
Se pare ca problema CCC@m pe ipbox e rezolvata perfect.
Daca cineva are pe ipbox 91HD va rog sa verifica daca cu noua ABCOM firmware care a iesit limba romana e bine tradusa.Din pacat sunt inca la serviciu si nu am cum sa verific!
Dupa 2 zile de test pot sa spun ca incubusCamd e foarte stabil!!!!!Daca nu incerci sa deschizi pe canale Digiturk si UPC 19.2E.Cind o sa fie rezolvat si asta bug o sa fie o mare lovitura la Dream multimedia....Acuma nu exista o scuza ca sa nu cumpari asta receptor.Iar daca doresti sa dai linii din cartela ta poti sa folosesti pe newcs.
Am vesti proaste pt posesori de QBOX HD.Incubus team asa cum se vede nu o sa mai suporta pe receptor asta cu noi versiuni de incubus.Acuma ramune sa vedem ce se intimpla si cu Kathrein.
:sorry:
cu alte cuvinte sa inteleg ca nu o sa fie nici pentru enigma pe IPBox?
