Octagon SF918 HDTV - Linux Kernel - LAN
Feature:
Linux Kernel
-- Image soon with all known EMUs g incl ** x, newcamd
An elegant HDTV digital satellite receiver
With LG tuner, 32-bit 1000 MHz processor and 400 MB of memory provides
OCTAGON the HD SF 918 for a strong and first-class reception.
Enjoy the HD quality with less than 1 sec switching time of the programmes.
With the Ethernet LAN connectivity, USB, eSATA and HDMI, they have the choice of agony
Over the remote controlled tuner gain (AGC value) also enables the weak channels without interference to receive this receiver was unique.
Individual color settings (brightness, contrast, color saturation) to its Sendungsart (film, news, sports, users) allow them the best image quality.
Only Arte features:
1000 MHz - 32-bit processor
400 MB RAM
10 000 places (TV & Radio)
Ethernet LAN - 10/100 Mbps
E-SATA port
USB 2.0
HDMI connector
VFD display (Dot Matrix Vacuum Fluorescent Display)
2 x CI slots for modules
Smart Card reader for encryption CONAX
Features:
Digital Satellite Receivers MPEG 4/H.264 & DVB-S2 (DVB) compatible
Format Resolution: 576p/720p/1080i
3D user-friendly OSD menu
Clear and simple on-screen interface
Color Adjustment: color, brightness, contrast and color saturation
Bedienfreundlicher EPG (electronic program guide) for the display of program information and program preview
254 satellite programmable
Level control DiSEqC 1.0, 1.1, 1.2 and 1.3 (USALS)
LNB voltage 13/18V & 14/19V adjustable in long lines
Video format in 4:3, 16:9 and letterbox
Zoom & pause function
Recall function: storing the last 20 selected stations
Find function: stations can be found alphabetically
Program timer function
Sleep timer function
8 favourite lists for the organization of TV programmes (film, news, sports, music, children, drama, family, Misc.)
8 favourite lists for the organization of radio stations (film, news, sports, music, children, drama, family, Misc.)
Parental Controls for menu and programs
Several clear channel sorting functions such as delete, rename, move and block
Backup & restore the setting (Backup / Restore)
8 buttons on the front panel
Front buttons on / off switch
Support for Teletext and subtitle
Software - Updates on USB/RS-232 (PC-STB / STB STB)
Data transfer: receiver to receiver
Menu in 24 languages
Games menu: Sokoban, Snake, Tetris, Mines, Slot Machine, Othello
Calendar and calculator function
Automatic NTSC / PAL detection
Very fast channel search
Multi-Search: several satellites can be marked and searched
Manual input PID (audio, video and PCR)
Volume difference for each channel individually adjustable
Main background and radio background image changed
Boat image on / off
Div. Selectable menu animations: Stripe, spray, Slide, Fade
Power switch on / off
HF Modualtor
Dolby Digital 5.1 SPDIF output (optical)
2 x Scart (TV / CVR)
2 x RCA audio output (R / L)
1 x RCA video output
Following component (YUV - YPbPr)
Dimensions: 340 x 60 x 268 mm
Weight: about 2.5 kg
The remote control there in black and silver!
Readme_Version_02-06-08_EMU_AU_V0948
for Octagon HD SF 918 HDTV :
Changes :
- PW (Premiere) AU udapte OK (Astra 19,2°east)
- LIG-TV Digiturk AU update OK (Astra 23,5°east)
- Polsat AU update OK (Hotbird 13°east)
- TPS Multivision AU update OK (Hotbird 13°east)
- DigiTv Romania AU update OK (Thor 1°West)
- ART AU update OK (Nilsat 7°West)
- Showtime AU update OK (Nilsat 7°West)
- Premiere PW HD OK
- Premiere Star OK
- ORF HD OK
- ORF SD OK
- Rai Italia OK
- GloboTv Globecast OK
- Multicanal OK
- Mediatech OK
- Absat OK
- AXN Portugal
- BTV Sirius OK
- FOX TV Serbia OK
- Megasport AMOS OKS
- TET Sirius OK
- AU update still works ;-)
Please make factory settings after SW update.
EMU and other CAS Setup`s :
Pls. press Menu --> Modules --> RED Button --> Enter 0000
--> CAS menu for EMU and other CAS Setup`s
--> EMU Key for Enter Key and Keyreset (Keys Initialize) with Yellow Button
Memory Setup`s :
Menu --> STB Status --> Memory Setup --> Options : Memory Backup and Memory Restore
Update : File --> OCTAGON_HD_SF918_EMU_AU_V09.48__02_06_08_HDTV.bin --> Pls. copy of USB Stick and update STB !
Ethernet LAN / RS232 : NewCamd, Gbox, Homeshare, HSIC, Xcrypt etc. ;-)
enjoy :-)
Date 02 June 2008
Re: Octagon SF918 HDTV - Linux Kernel - LAN
da are si un pret informativ?
dupa cum se poate citi este un concurent serios pt. dm800, ipbox 900hd cel putin prin raportul pret/performanta (dotari).
la o prima cautare pe google:
sant curios sa vad la ce pret apare luna aceasta ipbox-ul 900hd.
un procesor la 1000MHz..... cred ca merge si XP pus :D :D :D ( Samsung mai avea un asa reciver DVB-S )
pare sa fie in jur de 300 Euro.
da are un procesor cam mare....fata de alte receptoare...si dupa cum am inteles merge cu Ethernet LAN / RS232 : NewCamd, Gbox, Homeshare, HSIC, Xcrypt etc. ...
Pretul e foarte interesant, la prima vedere pare un competitor redutabil pentru celelalte receivere HD existente pe piata.
la ce stie, cum arata si mai ales la pretul asta baga in buzunarul mic (ala din fata de la blugi) cam tot ce a aparut pana acum.
asteptam dezvoltarea software
numai bine
oare care dintre firmele de profil de la noi din tara il va comercializa si la ce pret?
nu cred ca se va vinde si la noi in tara...receptoarele Octagon sunt demult pe piata Germana si la noi nimic...dar nu stie....
Fara sustinere soft nu prevad viitor bun, chiar daca raportul pret-HW(daca imi dati voie sa fac comparatia!) e imbatabil. Chiar e nevoie de un I-Had-A-octagon :) ca sa nu fie irosite resurse aiurea.
Sa vedem ce va fii...
ca sa aiba software disponibil trebuie sa cotizeze acolo unde e nevoie asa cum fac cei de la dream multimedia.
pt mai multe detalii descarcati manualul de utilizare : [Only registered and activated users can see links. Click Here To Register...] engleza si germana.
Exista vreun forum dedicat?
E mult mai puternic decat Dream 800 si mai ieftin!
l-am pus si pe rapidshare [Only registered and activated users can see links. Click Here To Register...]
numai bine
multe au aparut ....si au bagat in buzunarul mic concurenta....dar dream a ramas lider...
ps.software-ul este dezvoltat de o SINGURA ECHIPA!!!
drept graiesti @outcast cu toate ca, cam toti ne-am dori un competitor serios la DM dar cam greu ...fiecare are bubele lui, poa sa aiba si dual core 2 duo procesor da daca nu are suport =0
aici in general contribuie si o proasta publicitate, ex: la noi in tara daca as intreba pe la firmele de profil nu stiu cati l-ar aduce sa numai zic cati ar fii auzit de el ca reclama = 0 pt. el , deci cati au stiut de acest model sau altele similare fara o publicitate mai puternica sau pe ici colo niste anunturi aruncate.
acest receiver are deja cam tot ce trebuie (incl. usals, subtitrari etc.)- daca merge gbox-ul, pt. mine e ok.
poate sa nu mai apara nicio img. ca nu ma mai intereseaza
Sunt curios ce linux are pe el...
Pare un procesor cu instructiuni x386... hmm.In situatia asta dezvoltarea soft nu ar fi o problema mai ales ca VDR-ul in ultimul timp e din ce in ce mai complex.Cu un mic hack se pate pune si cccam.
Nu ma pricep la programare , dau si eu cu parerea dar la ce hardware au pus pe el , DM8000 ramine un vis si atat.
f11
