(PR) IBASE Unveils IB962 3.5-inch SBC with Intel Core Ultra 7/5 100 Se
IBASE Technology Inc., a leading manufacturer of industrial computers and embedded systems, unveils the IB962 3.5-inch single board computer (SBC) built on the advanced Intel Core Ultra 7/5 100 Series processors (formerly Meteor Lake U/H). Featuring 3D performance hybrid architecture, advanced AI capabilities, and available with built-in Intel Arc GPU, the processor delivers an optimal balance of performance and power efficiency and helps unlock the power of AI to create immersive graphics experiences.
The IB962 is available in a variety of models, with high-end models powered by the Intel Core Ultra 7-165H and Ultra 7-165U processors to meet different processing needs while maintaining a compact footprint of just 102 mm x 147 mm (4" x 5.8"). The IB962 series comprises two DDR5 SO-DIMM slots, supporting up to 64 GB of RAM to handle intensive multitasking and high-speed data processing with ease. A standout feature is its extensive display capability, supporting HDMI, DP++, LVDS, and eDP interfaces, allowing flexibility to connect multiple high-resolution displays simultaneously, whether for industrial automation, manufacturing, retail, entertainment, healthcare, or other edge AI applications.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ASRock Launches AMD Radeon RX 7900 Passive Series Graphics Cards
ASRock, the leading global motherboard, graphics card and mini PC manufacturer, today launched the first passive series graphics cards -- ASRock Radeon RX 7900 XTX Passive 24 GB and ASRock Radeon RX 7900 XT Passive 20 GB graphics cards.
ASRock Radeon RX 7900 Passive series graphics cards are powered by the AMD Radeon RX 7900 XTX and Radeon RX7900 XT GPUs. Both of these two cards are supporting multi-GPU collaborative computing, and designed for multi-card parallel computing for better performance. Radeon RX 7900 Passive series graphics cards are featuring a VAPOR-CHAMBER heatsink, efficiency aluminum cooling fins with V-shaped cutting. Furthermore, thanks to the single horizontal 12V-2x6 power connector, to install a couple of ASRock Radeon RX 7900 Passive series graphics cards become much easily due to less power cords.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) EIZO Releases FlexScan EV4340X 4K IPS Monitor
EIZO presents the FlexScan EV4340X, a particularly powerful monitor that has been specifically developed for workplaces where maximum overview is required. With its large screen diagonal of 42.5 inches, the EIZO FlexScan EV4340X is predestined for use in control rooms, control stations, trading centers or similar work environments: Thanks to its high 4K resolution (3,840 x 2,160 pixels), it displays four times as much information as a Full HD monitor and more than twice as much as a WQHD display. With a fine pixel density of 104 ppi, every detail remains recognizable.
The EIZO FlexScan EV4340X fits perfectly into the intended installation with modern connectivity. In addition to two HDMI inputs and a DisplayPort connection, the monitor offers full USB-C docking functionality including DisplayPort Alt Mode, transmission of video, audio and USB data signals and a power supply of up to 94 watts. The FlexScan EV4340X is therefore an ideal match for notebooks, which always come with fewer connections from the factory and even have a stable Ethernet connection thanks to the monitor's integrated LAN port.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) ASUSTOR Surveillance Center is Now Cross-Platform
Surveillance Center is no longer limited to Windows! If you run a computer that supports a modern web browser, Surveillance Center 3 Beta will run! Simply upgrade your ASUSTOR NAS to ADM 4.3.0 or above, then download and install Surveillance Center 3.0 Beta from App Central. Set up network cameras for surveillance, view multichannel live streams as well as play back recordings on browsers like Firefox Edge, Chrome, and Safari, ensuring a seamless and secure surveillance experience.
In addition, ASUSTOR NAS devices provide comprehensive data protection for users. When using web browsers like Firefox or Chrome, your connection between your PC and Surveillance Center 3.0 Beta can be encrypted with HTTPS. For maximum security, use TLS 1.3 to ensure privacy and enhanced communication security while creating a smart home environment.[Only registered and activated users can see links. Click Here To Register...]
(PR) SK hynix Board Approves Yongin Semiconductor Cluster Investment P
SK hynix Inc. announced today that it has decided to invest about 9.4 trillion won in building the first fab and business facilities of the Yongin Semiconductor Cluster after the board resolution on the 26th. SK hynix designs to start construction of the 1st fab to be built in the Yongin cluster in March next year and complete it in May 2027, and have received an investment approval from the board of directors prior to it. The company will make every effort to build the fab to lay the foundation for the company's future growth and respond to the rapidly increasing demand for AI memory semiconductors.
The Yongin Cluster, which will be built on a 4.15 million square meter site in Wonsam-myeon, Yongin, Gyeonggi Province, is currently under site preparation and infrastructure construction. SK hynix has decided to build four state-of-the-art fabs that will produce next-generation semiconductors, and a semiconductor cooperation complex with more than 50 small local companies. After the construction of the 1st fab, the company aims to complete the remaining three fabs sequentially to grow the Yongin Cluster into a "Global AI semiconductor production base."[Only registered and activated users can see links. Click Here To Register...]
Team Group Launches the T-Force GC PRO Gen 5 SSD
Team Group today introduced the T-Force GC PRO, its new performance-segment M.2 NVMe Gen 5 SSD. The new T-Force GC PRO is not to be confused with the [Only registered and activated users can see links. Click Here To Register...] that Team Group launched in January 2024, although the two appear almost identical. The newer GC PRO is powered by the same InnoGrit "Tacoma" IG5666 controller as the GE PRO, but with slightly toned down speeds.
The GC PRO comes in 2 TB and 4 TB capacity variants, with maximum sequential speeds of 12,500 MB/s reads, with 11,000 MB/s writes. For comparison, the flagship GE PRO does 14,000 MB/s max sequential reads, albeit with the same 11,000 MB/s max sequential writes. The GC PRO is hence designed to stike a slightly lower price point which could see it square off against pre-Max14um Phison-powered SSD models. Both the 2 TB and 4 TB models offer identical sequential transfer speeds, but differ with endurance—1,200 TBW and 2,400 TBW, respectively. Although a heatsink is recommended by the manufacturer, the drive comes with a graphene-coated metal-foil heatspreader. The company didn't reveal pricing, the drives are backed by 5-year warranties.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 9 9950X Pre-Launch Sample Overclocked at 6 GHz
Despite the postponement of the Ryzen 9000 launch [Only registered and activated users can see links. Click Here To Register...] on Wednesday, early engineering samples used by motherboard makers reached some users (mainly overclockers). As it is the case with a pre-launch sample of AMD's flagship Ryzen 9 9950X. This CPU is equipped with 16 cores, 32 threads, a base clock frequency of 4.3 GHz with a 5.7 GHz max boost, 80 MB cache (64 MB L3 + 16 MB L2), and a TDP of 170 W.
A user overclocked the 9950X sample to 5.953 GHz using an ASUS ROG Crosshair X670E motherboard equipped with 32 GB DDR5-6000 memory. (Note: There's no information on whether air or water cooling was used.) The user then posted new results in Geekbench 5 and Geekbench 6, which demonstrate impressive performance gains for the 9950X. It's worth noting that AMD also overclocked the processor to 6.6 and even 6.7 GHz, however, they used liquid nitrogen.[Only registered and activated users can see links. Click Here To Register...]
Samsung's HBM3 Chips Approved by NVIDIA for Limited Use
Samsung Electronics' latest high bandwidth memory (HBM) chips have reportedly passed NVIDIA's suitability tests, according to Reuters. This development comes two months after initial reports suggested the chips had failed due to heat and power consumption issues. Despite this approval, NVIDIA plans to use Samsung's memory chips only in its H20 GPUs, a less advanced version of the H100 processors designed for the Chinese market to comply with US export restrictions.
The future of Samsung's HBM3 chips in NVIDIA's other GPU models remains uncertain, with potential additional testing required. Reuters also reported that Samsung's upcoming fifth-generation HBM3E chips are still undergoing NVIDIA's evaluation process. When approached for comment, neither company responded to Reuters. It's worth noting that Samsung previously denied the initial claims of chip failure.[Only registered and activated users can see links. Click Here To Register...]
NVIDIA Plans RTX 3050 A with Ada Lovelace AD106 Silicon
NVIDIA may be working on a new RTX 3050 A laptop GPU using an AD106 (Ada Lovelace) die, moving away from the Ampere chips used in other RTX 30-series GPUs. While not officially announced, the GPU is included in NVIDIA's latest driver release and the PCI ID database as GeForce RTX 3050 A Laptop GPU. The AD106 die choice is notable, as it has more transistors and CUDA cores than the GA107 in current RTX 3050s and the AD107 in RTX 4050 laptops. The AD106, used in RTX 4060 Ti desktop and RTX 4070 laptop GPUs, boasts 22.9 billion transistors and 4,608 CUDA cores, compared to GA107's 8.7 billion transistors and 2,560 CUDA cores, and AD107's 18.9 billion transistors and 3,072 CUDA cores.
While this could potentially improve performance, it's likely that NVIDIA will use a cut-down version of the AD106 chip for the RTX 3050 A. The exact specifications and features, such as support for DLSS 3, remain unknown. The use of TSMC's 4N node in AD106, instead of Samsung's 8N node used in Ampere, could potentially improve power efficiency and battery life. The performance of the RTX 3050 A compared to existing RTX 3050 and RTX 4050 laptops remains to be seen, however, the RTX 3050 A will likely perform similarly to existing Ampere-based parts as NVIDIA tends to use similar names for comparable performance levels. It's unclear if NVIDIA will bring this GPU to market, but adding new SKUs late in a product's lifespan isn't unprecedented.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Intel Names Naga Chandrasekaran to Lead Foundry Manufacturing and
Intel Corporation today announced the appointment of Dr. Naga Chandrasekaran as chief global operations officer, executive vice president and general manager of Intel Foundry Manufacturing and Supply Chain organization. Chandrasekaran joins Intel from Micron, where he served as senior vice president for Technology Development. He will be a member of Intel's executive leadership team and report to CEO Pat Gelsinger.
Chandrasekaran succeeds Keyvan Esfarjani, who has decided to retire from Intel after nearly 30 years of dedicated service. Esfarjani's distinguished career set a strong foundation for Intel Foundry, and his leadership in global supply chain resilience and manufacturing excellence has helped to position Intel's business for long-term success. He will remain with Intel through the end of the year to ensure a seamless transition.[Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen 7 8745H APU Debuts in China
AMD has unveiled its latest processor, the Ryzen 8040H. This new model boasts 8 Zen 4 cores and full RDNA3 graphics with 12 Compute Units. Notably, it lacks the AMD XDNA processor, confirming earlier rumors of a mobile SKU without a Neural Processing Unit (NPU). Contrary to speculation, the 8040H's specifications differ from the Ryzen 8845HS. The new chip has a boost clock of 4.9 GHz, 200 MHz lower than its predecessor. Graphics performance has also been slightly reduced, with the 12 Compute Units clocked at 2.6 GHz, down from 2.7 GHz in the 8845H.
The Lenovo XiaoXin 14 Pro is the first laptop to feature this new APU, priced at 5499 RMB ($768) with 24 GB of memory. For comparison, a similar model with the 8845H and 32 GB of memory is priced at 5599 RMB ($773), suggesting only a marginal price difference between the two configurations.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) S.T.A.L.K.E.R. 2: Heart of Chornobyl Delayed to November 20, Gets
S.T.A.L.K.E.R. 2: Heart of Chornobyl will now be launching on November 20, 2024, moving from the previously planned date of September 5, 2024.
"We know you might be tired of waiting, and we truly appreciate your patience. These two additional months will give us the chance to fix more "unexpected anomalies" (or simply "bugs", as you call them). We are always grateful for your ongoing support and understanding - it means the world to us. We're just as eager as you are to finally release the game and for you to experience it for yourself." said Yevhen Grygorovych, Game Director at GSC Game World.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) Now You Can Plug An XLR Microphone Into Elgato's Stream Deck +
Elgato, a brand of CORSAIR, today introduced two new hardware extensions for their Stream Deck + controller. XLR Dock, a mic interface, helps creators manage all their audio needs from a single device. Meanwhile, USB Hub offers additional ports and power delivery to support a growing setup. Both extensions slot directly into the back of Stream Deck +, tucked away to reduce desk clutter. For creators like streamers and podcasters, it's an opportunity to further streamline their workspace, with Stream Deck + at its heart.
Stream Deck + owners can order XLR Dock and USB Hub today on Elgato's webstore, with shipping expected to begin next week. Starting August 25, both products will also be available at authorized retailers in CORSAIR's global network.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
(PR) NVIDIA GeForce NOW Gets Elder Scrolls V: Skyrim Special Edition a
It's the summer of Elder Scrolls - whether a seasoned Dragonborn or a new adventurer, dive into the legendary world of Tamriel this GFN Thursday as The Elder Scrolls V: Skyrim Special Edition joins the cloud. Epic adventures await, along with nine new games joining the GeForce NOW library this week. Plus make sure to catch the GeForce NOW Summer Sale for 50% off new Ultimate and Priority memberships.
Unleash the Dragonborn
Experience the legendary adventures, breathtaking landscapes and immersive storytelling of the iconic role-playing game The Elder Scrolls V: Skyrim Special Edition from Bethesda Game Studios - now accessible on any device from the cloud. Become the Dragonborn and defeat Alduin the World-Eater, a dragon prophesied to destroy the world. Explore a vast landscape, complete quests and improve skills to develop characters in the open world of Skyrim. The Special Edition includes add-ons with all-new features, including remastered art and effects. It also brings the adventure of Bethesda Game Studios creations, including new quests, environments, characters, dialogue, armor and weapons.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
SilverStone Intros FARA 514X and FARA 314X Cases
SilverStone today introduced the FARA 514X and FARA 314X tower-type cases designed for space and high air-flow. The FARA 314X is a Micro-ATX tower, while the FARA 514X is an ATX mid-tower. Both cases are characterized by their mesh front intakes, and large included 140 mm intake fans, besides an included 120 mm exhaust fan); a tempered glass left side-panel, and room for graphics cards up to 36.5 cm in length, along with CPU coolers up to 17.3 cm in height. Both cases feature a horizontally partitioned layout, with the upper compartment holding the spacious motherboard tray, and the lower one with a PSU with up to 21.7 cm of room for the spaghetti.
The FARA 314X (model: SST-FA312X-BG) measures 220 mm x 410 mm x 412.4 mm (WxHxD), dry-weighing 5.76 kg. It offers 4 expansion slots, and supports Micro-ATX (or smaller) motherboard form-factors. Fan mounts include either three 120 mm or two 140 mm front intakes, which hold onto the two included 140 mm ARGB fans; and two 140/120 mm top exhausts, besides the obligatory 120 mm rear exhaust. Your radiator options include a 280 mm x 140 mm (or smaller) along the front intake, and another 280 mm x 140 mm (or smaller) along the top exhaust. The only drive bay is a 3.5-inch/2.5-inch in the bottom compartment, and there are three aditional 2.5-inch mounts along the motherboard tray. Front-panel connectivity includes two USB 3.x type-A, a 3.5 mm audio jacks.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
TP-Link Launches the $99 Archer BE3600 WiFi 7 Router
To date, WiFi 7 routers have been costing hundreds of dollars, with high-end models going for as much as US$800 for standard routers, with mesh systems easily breaking the US$1000 barrier. TP-Link's new Archer BE3600—also known as the Archer BE230 in some markets—is the polar opposite to those expensive routers, as it's being sold for a mere US$99. We've even found it for less than that in some countries, although we've also seen the BE230 model for twice as much, so the pricing varies quite a lot depending on where you live. You might be wondering how much router you get for your money, since there has to be some trade-offs, right?
Well, you wouldn't be wrong, but there are fewer trade-offs than we expected. As the model name implies, the combined WiFi speed is 3600 Mbps in theory, with the 5 GHz radio delivering up to 2882 Mbps and the 2.4 GHz radio delivering up to 688 Mbps. Both the 2.4 GHz and 5 GHz radios are 2x2, but at least the 5 GHz radio supports up to 240 MHz channel width, although 160 MHz is far more common on the device side. However, there's no 6 GHz radio to be found at this price, which isn't entirely unexpected at this price point. However, new features like Multi-Link Operation (MLO) are supported. You also get a pair of 2.5 Gbps Ethernet ports, something only routers at around twice the price of the Archer BE3600 has featured so far. There's even a USB 3.0 for those that want to connect up a storage device to their router as a makeshift network drive. According to a teardown done by the FCC, the Archer BE3600 is based on a Broadcom SoC with integrated WiFi and a Realtek switch for the Gigabit ports.[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Windows 11 July Update Breaks Bitlocker, Forces Recovery
The Windows 11 "patch Tuesday" update for July 2024 breaks Bitlocker drive encryption, Microsoft notes in its issue discovery. The company releases monthly major update packages for Windows, timing them on every second Tuesday of the month. The July 2024 update carries the knowledge-base identifier KB5040442, and applies to Windows 11 22H2 and 23H2. Bitlocker is a first-party disk encryption feature by Microsoft that's included with Windows 10 Pro, Windows 11 Pro, and Windows 11 Enterprise editions. You are prompted a disk decryption password at every system startup, the disk remains encrypted until either password is input, or a Bitlocker Recovery process is followed.
The KB5040442 causes Bitlocker to forget its own password, forcing you to clear the Bitlocker Recovery process. When you encrypt a volume with Bitlocker, you are given a recovery key that you're supposed to safekeep. Those with online Microsoft accounts have the option to get Microsoft to store their recovery keys, so they could log into their Microsoft account on another device (like a phone), and access the stored recovery key, which they then manually input on the borked machine to create a new Bitlocker password. Microsoft acknowledges that Bitlocker recovery is only a workaround, KB5040442 will cause machines to forget their Bitlocker passwords, and force a recovery. The company is working on an update that fixes this, so if you have an always-on machine with Bitlocker that just got patched to KB5040442, you might want to keep the recovery key handy.[Only registered and activated users can see links. Click Here To Register...]
AMD Ryzen Chipset Drivers 6.07.22.037 Released: Adds Ryzen AI 300 Seri
AMD today released the Ryzen Chipset Drivers 6.07.22.037 WHQL. The drivers are essential for notebooks powered by the latest Ryzen AI 300 series "Strix Point" processors, as they add driver support for the various SoC interfaces of the chip. The drivers are also needed to expose the NPU of Ryzen 7000 "Phoenix," Ryzen 8000 "Hawk Point," Ryzen 8000G desktop APUs, and Ryzen AI 300 "Strix Point" processors as a classified device in the Windows Device Manager, as well as give Windows 11 the ability to read out the NPU in the Task Manager, so you can look for things there such as real-time NPU utilization, memory footprint, and driver version. The driver package also updates the drivers of the various components, including GPIO, PSP, PPM, USB4 host controller, etc. It also adds program support for various interfaces of the SoC, including SMBus, Hetero, and RCEC. Grab the drivers from the link below.
DOWNLOAD: [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
AMD Zen 5 Recall Caused by a Typo?
AMD Ryzen 9000 series "Granite Ridge" desktop processors were supposed to start selling on July 31, 2024, but the launch has since [Only registered and activated users can see links. Click Here To Register...]. Since then, social media has been abuzz with theory crafting behind what could be the cause of the delay. AMD's announcement of the delay mentions: "During final checks, we found the initial production units that were shipped to our channel partners did not meet our full quality expectations," causing some to speculate if there are design flaws such as the ones affecting Intel's 13th Gen and 14th Gen Core desktop processors. A picture doing rounds on social media has a more goofy explanation: there is a glaring typo on the product label printed on the integrated heatspreader (IHS) of the processors.
Apparently, some of the first batches of Ryzen 9000 processors see the brand extensions mislabeled. Ryzen 7 9700X is printed as "Ryzen 9 9700X." This error in the brand extension may have been easily "patched" if it was on the retail packaging (the box), where hardware manufacturers tend to fix typos by simply pasting stickers on them. You can't do this with the IHS, which is a key component of the processor's cooling mechanism. Also, since times immemorial, chip labels (information printed on the chip) have served as crucial last resorts for accuracy of information such as the chip's exact model number, steppings or revisions (if any), and production serial numbers, besides the chip's national origin, which determines the applicable import tariffs. A typo here could prove problematic. We're not entirely sure how AMD is fixing these errors with mere 1-2 week delays. It's likely that they're recalling the affected batch and simply replacing inventory in the channel with "good" batches. The recalled chips will simply have their IHS reprinted.[Only registered and activated users can see links. Click Here To Register...]
