Salut,
Am un router linksys caruia ii clipeste ledul de power cand este pornit. Uneori se aprind si 2-3 leduri de la porturile LAN. Asta s-a intamplat in urma unei pene de curent. Am facut azi un jtag, dar nu vrea sa se conecteze deloc.
JTAG cable.
DIY at home.
DB25 male connector
4x 100ohm resistor
12-14pin ribbon as shor as possible to to avoid problems with electrical noise - 15-20cm.
DB25 JP2 on PCB of router
13 ---------|100|-------- 5
2 ---------|100|-------- 3
4 ---------|100|-------- 7
3 ---------|100|-------- 9
20 ---------------------- 6
25
Connect only pins 20 and 25 together.
If your cable is finished you can solder wires to PCB.
Am respectat intocmai instructiunile, dar nu se conecteaza deloc.
A mai incercat cineva resuscitarea routerului cu ajutorul jtagului?
Multumesc.
