Monkus OpenXCAS Tools 1.1:
- AzBox HD Backup v0.91 (NEW)
- AzBox HD USB Mount Script v2.0
- AzBox HD USB Background Copy Script v1.1
# AzBox HD Backup v0.91 for OpenXCAS
# 0.91 (ChangeLog)
# - DVB-C and DVB-T support
# 0.91 (ChangeLog)
Monkus OpenXCAS Tools 1.3:
- AzBox HD Backup v0.93 (UPDATE)
- AzBox HD USB Mount Script v2.2 (UPDATE)
- AzBox HD USB Background Copy Script v1.3 (UPDATE)
- AzBox HD SwapOn v1.0 (NEW)
ChangeLog (From 1.2):
# AzBox HD Backup v0.93:
# - backup.list change (from /EMU to only /EMU/OpenXCAS[2]) cause archive size
# - writing all buffered filesystem blocks to disk before reboot
# - some warnings in restore.sh script
# - possible to choose archive to restore (./restore.sh /path/to/archive.tar)
# - compatibility with azbox webinterface (by koivo, joseba)
# AzBox HD USB Mount Script v2.2
# - small probe hack to mount some usb devices with isofs (secondary root)
# AzBox HD USB Background Copy Script v1.3
# - check, if usb device exists
# AzBox HD SwapOn v1.0
# - new plugin to add more total memory using swap
# - possible to choose swap device (usb device or internal hard disk)
# - possible to choose swap size (100MB is fine)
WEB IF Ver.1.2 © 2009 - Telesat Team
FIX : Compatibility with older FW , 0.92880 or lower.
apare tot ca v1.0, si dupa restart, nu 1.2
Change cccam mgcamd
trying to create a script to change during the operational to the cam.
Unfortunately I am not yet succeeded.
I noticed that a start in the telnet does not work, if the cam is not in the autostart.
can you help me?
cccam_ modul
openxcas.conf
Code:
[module]
name = CCcamCAS
daemon = cccam_module.sh
version = 1.00
api=yes
wait =10sec
cccam_module.sh
Code:
#!/bin/sh
killall -9 cccam_module &
killall -9 mgcamd &
sleep 2
rm -rf /tmp/*.info* /tmp/*.pid*
sleep 5
cd /EMU/OpenXCAS/CCcamCAS
./cccam_module &
mgcamd
openxcas.conf
Code:
[module]
name = mgcamd
daemon = mgcamd.sh
api = yes
wait = 15sec
version = 1.32
# argument = -a 3
mgcamd.sh
Code:
#!/bin/sh
killall -9 mgcamd &
sleep 2
sleep 5
cd /EMU/OpenXCAS/mgcamd
./mgcamd &
A new plugin for our AzBox HD.
What is it?
This plugin allows your AZBox HD to download updated SoftCam.Key & constant.cw
from remote server.
You don't need any more to download updated keys and send them to the box by
using FTP connection.
How to
Create a new folder in /EMU/ called TechSatAZHDKey
Copy TechSatAZHDKey in /EMU/TechSatAZHDKey/.
Change Files Attributes to 755 (both). Change the .cfg of your favorite EMU
to make possible the reading of the keys.
Exit DCC.
Push Home button in your AzHD remote and go to Installed Plugins.
Select TechsatAZHDKey and press Ok.
That's all.
Just close black screen after few seconds by pressing Exit and... Enjoy.
Why install this plugin?
Because SoftCam.Key & constant.cw is automatically generated from
TechSat Maker keys DataBase, updated in real time!!...
Thanks TechSat Team
un skin dragut
instalare:
1.telnet azbox
2.comanda :
mount -o remount,rw -t ext3 /dev/hda1 /MMP
3. se poate dezarhiva in azboxba.
4. si poate veni curentu!
Monkus OpenXCAS Tools 1.4:
- AzBox HD USB Background Copy Script v1.4 (UPDATE)
ChangeLog (From 1.3):
# AzBox HD USB Background Copy Script v1.4
# - fixed bug during copying data from usb2 to usb1 device
Looking for stable SKY DE/IT HD Channels N Lines for testing purposes (small traffic). Thanx in advance.
TechsatAZHDKey Plugin
nabilosat forum
* AZBox plugin: TeChSAt_AZK beta0.9 *
What is it?
This plugin allows your azbox HD download files
Key.bin & new_biss.key updated directly from the remote server.
how to put the plugin:
- Unpack / copy
folder TeChSat_AZK in the folder: / PLUGINS
set to 755 to file TeChSat AZK
how to launch the plugin:
- Disable MultiCAS
- From the Settings menu -> plugins -> TeChSat_AZK
- Restart reactivate MultiCAS
Because the files are generated automatically by
Database keys Maker TechSat, always updated in real time!
note:
in this beta version does not appear
info screen.
Each process is shown on the AzBOX display
TeChSat_AZK v1.0 - TechSat TEAM
We present the first official version of our plugin for TechSat_AZK azbox.
With this plugin you can download and install automatically files Key.bin and new_biss.key always updated with the latest keys to work.
This plugin is dependent MULTICAS therefore to use it you must also install the plugin OpenXCAS.
Edit the file and add the url plugins.conf [Only registered and activated users can see links. Click Here To Register...] example:
Code:
[SERVER]
PLUGINS_SERVER_1=http://azboxworld.com
PLUGINS_SERVER_2=http://techsat.info/AZPlugins
PLUGINS_SERVER_3=http://islaremota.com
PLUGINS_SERVER_4=http://azupd.com
From this moment you can automatically install the plugin TechSat_AZK and others may be available directly from the server TechSat
Un font care poate fi utilizat in AZBox (recomandat de unii utilizatori) este X360.ttf.
Am inceput modificarea acestuia, in special pentru subtitrare, iar mai jos va prezint a doua versiune a fontului XBOX360M.ttf.
Instalare: Cu MaZ v2.3, in Telnet montati /dev/hda1 read-write, in FTP copiati fisierul XBOX360M.ttf in /MMP/hd/System/font, in Font1.ttf symbol link catre XBOX360M.ttf, iar la final in Telnet montati /dev/hda1 read-only.
TeChSat_AZK v.1.1
Code:We present version 1.1 of our plugin for TechSat_AZK azbox.
This plugin is dependent MULTICASA therefore to use it you must also install the plugin OpenXCAS.
With this version you can view the channels contained in two rows of keys with an indication of coding, channel and satellite.
There are 4 methods of installation:
1) Edit the file and add the url plugins.conf http://techsat.info/AZPlugins example:
Code:
[SERVER]
PLUGINS_SERVER_3=http://azupd.com
From this moment you can automatically install the plugin TechSat_AZK and others may be available directly from the server TechSat.
2) Copy the content of TechSat_AZKV1.1.plugin.zip in / tmp to the receiver and proceed with the installation to install (/ tmp / plugins.lst).
The remote control: HOME => Plug-ins => YELLOW button => Install (/ tmp / plugins.lst)
3) Copy the content of TechSat_AZKV1.1.plugin.zip in own pen-drive and proceed with the installation to install (USB).
The remote control: HOME => Plug-ins => YELLOW button => Install (USB)
4) Copy the content of TechSat_AZKV1.1.file.zip in the / plugins / receiver.
TechSat Team
We present version 2.0 of our plugin for TechSat_AZK azbox.
This plugin is dependent MultiCAS therefore to use it you must also install the plugin OpenXCAS.
News
There are 4 methods of installation:Code:- Added download softcam for MGcam and CCcam and consultation on the channel visible.
- Added the ability to view directly into the plugin through the bulb, the state of the cam:
Bulbs on = Cam Activated
Bulb off = Off Cam
Bulb off with Cam X = not installed
1) Edit the file and add the url plugins.conf [Only registered and activated users can see links. Click Here To Register...] example:
From this moment you can automatically install the plugin TechSat_AZK and others may be available directly from the server TechSat.Code:[SERVER]
2) Copy the content of TechSat_AZK-V2.0.plugin.zip in / tmp of the decoder and proceed with the installation to install (/ tmp / plugins.lst).
3) Copy the content of TechSat_AZKV2.0.plugin.zip in own pen-drive and proceed with the installation to install (USB).
4) Copy the content of TechSat_AZK-V2.0.files.zip in the / plugins / receiver.
***DeformCCC ver 1.ab
improvements:
--more stable than ver 1.aa
--fakeroot was edited for better decoding performance
--unnecassary files were deleted
--handler v1.ab was added
--with handler cccam has beter performance for first decoding and give ecm information from dvbapi_module
--easy to install
thanks for hfmls
***DeformCCC ver 1.ac
--CCcam.prio and CCcam.channelinfo supporting has been added
--dvbapiCAS and DeformCCC have collected in a file in archive file
--to install easyier than ver 1.ab
********How to Install***********
--copyDeformeCCCV1ac.tar file to your main directory(/)
--if you have dvbapiCAS give that command "rm -r /PLUGINS/OpenXCAS/dvbapiCAS" and "rm -r /PLUGINS/OpenXCAS/DeformCCC"
-- go to / dircetory with "cd /" give tar xf DeformeCCCV1ac.tar commands
--add dvbapiCAS your module.soq file and open it after that disable Multicas
--change CCcam.cfg file under cccam directory and give file permission as 755
--add your prio and channelinfo file under cccam directory
--open dvbapiCAS your openxcas menu and they should be active
...DeformE
Azmail 1.1 - Mail client manager
Mail client manager for azbox
How to install:
download and unzip the archive into a folder
copy the contents of the decompressed folder in pen drive or the temporary folder dell'AZBox.
go nalla window plugins and press the red button for add
select azmail and wait.
After installation, find azmail list of plugins installed.
Throwing a window where you can enter our e-mail account.
I tried with a mailbox of Virgilio and it worked without problems.
Have fun all
tks@karbit
1 Install "setup.exe Fausto v1.43 Windows on a PC.
2 Insert FTP files "cccam.cfg" and "newcamd.cfg in AZbox folder / plugins / OpenXCAS / MultiCAS (NOTE: prior to insertion in each file set the IP address that has a PC, that is where all writes N: 192.168.xy type IP address of your PC)
3 Insert file "FaustoServers.cfg in the following sub-folder on the PC where the installed Fausto (C: Program FilesFaustoEMUCardServer) (NOTE: prior to inserting the file set the IP address that has a PC, that is where all writes N: 192.168.xy enter the IP address of your a PC)
4 Unpack the archive "Fausto keys.zip" and put all files in the following sub-folder on the PC where the installed Fausto (C: Program FilesFaustoKeys)
5 Fausto Start by clicking the icon on the desktop PC.
6 Select Tools ->; Emulator ->; Server ->; Manager, click the Load and Start.
7 TAB select Monitor, click on the folder icon with the green arrow to enter the path to KEYS.BIN file (C: Program FilesFaustoKeys)
8 Make a MultiCAS restart to connect to the server Fausto.
9 Switch to a channel package from CanalDigitaal (19.2E), for example. Film1.1, TMF, RTL4, and so on. and will open it immediately. In addition to the package, opens the new Cy (13E) channels as well as Bulsatcom (39E) + Arena Sports 1-4. Note: Cyprus Cy new channels at any time change the keys and see them on the homepage and manually add in Fausto Emulator.
traducerea din sarba in engleza by google
