A aparut Sifteam R 9341
Bassed DGS release r9341: 1/May/2009
1. Update trick speed in File play and live banner
Original : X2, X3, X4, X5 and (X1/5), (X1/4), (X1/3), (X1/2)
Advanced : X2, X4, X8, X16 and (X1/16), (X1/8), (X1/4), (X1/2)
2. ADD Proportional jump function in File play
If you press the numerical button in File play, it works as below.
- Press ¡°1¡± : Jump to 10% of the recorded file
- Press ¡°2¡± : Jump to 20% of the recorded file
- Press ¡°3¡± : Jump to 30% of the recorded file
- Press ¡°0¡± : Jump to beginning of the recorded file
3. Updated Russian language.(Russian is translated by Andrei Nazarenko, thank you Andrei)
4. support NTSC display(you can find u-boot on our homepage)
5. Update DB
6. Fixed Greek Teletext bug on ERT World Hotbird 13, tp 11642.
7. Fixed the bugs that doen't display TTXT on the specific page.
The 777page of TTXT on Hotbird 8 (13.0E) - 11919.00 V
8. Fixed many small bugs
Note.
1. Our Video player is related with CODEC, FPS(frame per second) and resolution.
As you know, even if the Filename Extension is different each other,
if the video codec is same each other, the two files work like same.
If the video file's resolution is more than 720 X 576, it will works very well.
So, we recommend below conditions.
1) resolution : 720 X 576.
2) FPS : 24, 25 and 30 fps.
3) Following video and audio codec.
Video Codec : XVID(Without GMC and Qpel), OpenDivx(less than Divx5.2), MPEG1, MPEG2, H.264
Audio Codec : MP2, MP3, AC3
When file's codec is Xvid, If you remove the GMC and Qpel, it works well.
If the file's video codec is MPEG series, it doesn't support the adjusting sync function on video player.
2. ext3 file system is slower than ext2 normally.
If you record two HD channels with ext3 at the same time, it may fail in record.
we have checked the speed as below
ext2 speed : approximately 7MB/s
ext3 speed : approximately 3MB/s
Known issues(on going).
1. Artefact with Premiere HD channels from satellite or cable.
Caution.
1. we strongly recommend to format your USB memory stick before the new image copy in it, otherwise, it may happen "ER10".
2. you should download usb_all_noboot.img into STB for improving Web interface and plugins, otherwise, the function will be the same as previous one
