SifTeam - 1.9.3E DM 500 MaxVar
IPBOX200S:
Usable to flash
* Enigma of: 05.04.2009 (patched for native version)
* Linux version 2.6.17 (patched from sandali)
* Web Interface: 6.0.2-Expert
* Busybox 1.01
* U-BOOT 1.2.0 (patched from sandali)
* New driver from sandali
* MMC Drivers included with script for load
* Have to SET mID 20
IPBOX200S 64mb:
* For ipbox-200@64mb you have:
1) Install normal image (32mb)
2) Install "serial_uboot_64.img"
* Thanks to Sandali for serial_uboot_64.img
IPBOX250S:
Usable to HDD (CF) or flash
* Busybox 1.01
* Tuxtxt v. 1.99
* Have to SET mID 25
IPBOX350S:
Usable to HDD, USB or flash
* Busybox 1.01
* Tuxtxt v. 1.99
* Have to SET mID 26
IPBOX400S:
Usable to HDD or flash
* Busybox 1.01
* Tuxtxt v. 1.99
* Have to SET mID 40
DB500:
Usable to flash
* Linux version 2.6.9
* GCC 3.4.4 Original CVS
* Busybox 1.01
* Tuxtxt v. 1.99
DB5620:
Usable to flash
* Busybox 1.01
* Tuxtxt v. 1.99
DB7000:
Usable to HDD, USB, CF or flash
* GCC 3.4.4 Original CVS 1.1.0
* Busybox 1.01
* Tuxtxt v. 1.99
DB7020:
* Usable to HDD, USB, CF or flash
* OE Build Configuration:
BB_VERSION = "1.6.2"
OE_REVISION = "format_version "1"
new_manifest [0000000000000000000000000000000000000004]
old_revision [8384ee468ef9c285a8c9b35ef333e53be78b6445]"
TARGET_ARCH = "powerpc"
TARGET_OS = "linux"
MACHINE = "dm7020"
DISTRO = "opendreambox"
DISTRO_VERSION = "1.4.0"
TARGET_FPU = "soft"
DB600PVR:
* Usable to HDD or flash
TARGET_OS = "linux"
MACHINE = "dm600pvr"
TARGET_FPU = "soft"
DB500PLUS:
* Usable to flash
TARGET_OS = "linux"
MACHINE = "dm500plus"
TARGET_FPU = "soft"
Qbox-one:
Usable to flash
* Busybox 1.01
ALL DECODER ( same options not present to Qbox-one - IPBOX200s - DM500 - DM500+ - DM5620 ):
Buttons:
* 1 x BLUE = Emu Panel
* 1 x Yellow = Plugins
* 1 x Green = Addons Panel
* 1 x Red = EPG ( settable from Control Pannel )
* BLUE > 1 sec = Control Panel ( new version "visual" )
* Yellow > 1 sec. = Personal Plugin ( settable from Control Pannel )
* Green > 1 sec. = Personal Plugin ( settable from Control Pannel )
Features:
* Advanced MINICROND system configuration, with more script added (restart cam, restart openvpn ecc..)
* Advanced FIREWALL with graphics start/stop/configuration
* Advanced HDD with graphics configuration
* Advanced SWAP with graphics start/stop/configuration
* Advanced OPENVPN with graphics start/stop/configuration (have to install online package)
* Advanced DROPBEARSSH with graphics start/stop/configuration (have to install online package)
* Advanced INADYN-DNS with graphics start/stop/configuration
* Advanced NFS with graphics start/stop/configuration (have to install online package)
* Settable PICON directory
* Automount HDD USB CF
* Advanced SCRIPT options for personal set ( name to button is modifiable from Control Panel)
* Formatting USB ( into 500 and 200 not have USB option, have manage remote control and free memory)
* Advanced EPG options (is possible set personal EPG from Control Panel or use standard EPG)
* Advanced Manage of Button Yellow and Green, is possible add one plugin to this buttons
* Simple BACKUP with graphics start/stop/configuration (for save one dir. to extern support)
* Advanced SAMBA with graphics start/stop/configuration (7020 - 600pvr - 500plus have samba installed from default)
* Color set to RGB from default ( for lcd TV)
* Inserted DM7020 Network Fix
* Reiserfs and VFAT supported
* Synchronize date from Internet
* WebIf information (ecm.info with reload option)
* New Button for second url (for download personel addons)
* Autostandby if decoder turn off in bad mode (crash power ecc..)
* Lock EMU panel from Parental Control option
* Save downloaded packages (from expert menu)
Display Function:
* Set zap without OSD (if press OK return OSD)
* Set OSD always on when OK is pressed (required from nokia9k8)
* Display Snr, Agc, Ber
* Display video information
* Display frequency, polarization, symbol rate
* Display emu in use
* Display service providers name
* Display CaID, ProvID, PID (you can hide from options)
* Display Decoding Source (you can hide from options)
* Picon, already inserted to enigma code (thanks to jlmota)
* SkinPreview (thanks to jlmota)
* Skin Lite/Full, when Lite ..if no OSD present, and press OK see Full (thanks to tension for help)
* Emu Panel now have image with icon report of decode
* Fulltime
* Analogic Clock
* Move OSD (thanks to tension9000)
* Always 16:9 settable in all decoder
* Time visible in screen
* Name channel visible in screen
EMU:
* Set Default CAM
* Set channel CAM
* Set provider CAM
* Stop active CAM
Addons:
* Internet addons download
* Manual addons install
* Remove installed addons
Misc:
* Italian, English language
* Many language in download
* Picon for -skyit+italian channel- is already installed
* Several Plugins/Games/Addons installed
* IPBOX200S have UHF in/out
* IPBOX200S ...for free memory (if is necessary):
1) Go to free channel
2) Click to "Free Memory"
...now is possible to start/stop install/remove visualize script ecc..
* For use your personal Addons server, create file:
/var/etc/SifTeam/tmp/url2 (that it contains your link)
after, into server have write your cpanel-dream.xml (for dream decoder)
or cpanel-ipbox.xml (for ipbox decoder), that contains your packages
(for simple system, download cpanel*.xml from sifteam URL)
THANKS TO:
See Yellow from Control Panel for other help into this work.
All IPBOX > ..special thanks to sandali for its branch of development ..and Blakskettle for any info.
FOR ALL > porto, MaxZ4, tension9000, jlmota ..and other?
Thanks to all and good fun :)
VARIOUS:
This image is based, beyond that my "much" code and hard work, to Dream-cvs, parts of old Hydra
source (EMU/ADDONS ...emubroker is this) ...and other?
ATTENZIONE:
QUESTO FIRMWARE NON CONTIENE CHIAVI, NE' EMULATORI, NE'
INDIRIZZI PER SCARICARE MATERIALE ILLEGALE DI NESSUN TIPO.
L'AUTORE NON E' RESPONSABILE IN NESSUN MODO DELL'USO CHE
GLI UTENTI NE FARANNO, DI LORO SPONTANEA VOLONTA'.
THIS FIRMWARE DOES NOT INCLUDE KEYS, NOR EMULATORS, NOR
URLS FOR DOWNLOADING ILLEGAL STUFFS OF ANY TYPE.
AUTHOR IS NOT RESPONSIBLE IN ANY WAY FOR WHAT
THE USERS WILL DO WITH THIS FIRMWARE.
NOTE:
Per la versione ipbox-200@64mb si deve:
1) Installare l'immagine del 200 normale
2) Installare il file "serial_uboot_64.img"
..entrambi con Flashtools o Flasher
Programmi:
Per avviare programmi personali, valido per tutte le immagini SifTeam:
Aggiungere il comando voluto in /var/etc/rcS.d/S99user_start.sh in fondo
al file (ci sono gia' presenti diversi esempi pronti all'uso, basta
decommentarli rimuovendo il simbolo #)
Tips:
Per entrare nel Pannello di Controllo se ci si trova nel Pannello Emu basta
premere il bottone giallo, funzione aggiunta per l'uso nella WebIf.
Per aprire il menu' Script mentre ci si trova nel Pannello di Controllo basta
premere lo 0 (zero).
[Only registered and activated users can see links. Click Here To Register...] SifTeam - 1.9.3E DM 500 MaxVar
Re: SifTeam - 1.9.3E DM 500 MaxVar
O imagine care merita mult mai multa atentie decat i se acorda,nu ar trebui sa va sperie diversitatea.:)
este o imagine OK..se misca bine in sharing
da si mie imi place cum se misca...dupa mine este pe locul 2 dupa PLI.
De ce se restarteaza dreamul ? Am cccam am spatiu liber destul , ocupat e doar 65%. E ok dar asta ma deranjeaza rau.
Daca nu setez sa ramana numele programului si ora pe ecran e super ok . Pentru cccam cred ca e cea mai buna imagine .
