CCcam instalation
What do you need
1. DCC – latest version is 7.04a – other versions will do
2. CCcam – latest version is 2.0.11( 2.1.0 ) – this version has got some fixes over the older version
3. Install CCcam
Install CCcam on your Dreambox
On most Dreambox images you can download and install CCam directly from your Dreambox – please refer to your Image help file for installation.
You can also install CCcam manually if you have the necessary expertise – I will leave it up to you!
Once you install CCcam set it up as your Default Cam in your Dreambox
4. Install DCC
DCC is a straightforward setup – proceed with defaults throughout the setup
5. Setting up and working with DCC
Open DCC - Update your Dreambox IP address, User and Pass
Connect and go down and choose FTP
Choose var/etc, rightclick CCcam.cfg and press edit
6. Adding Servers (people from whom you are going to get cards) to your CCcam
So now you are ready to insert servers in CCcam. You need to set up a line in the CCcam.cfg we just opened:
The C line will enable you to connect to the server
This is the information you need to set up a basic C line (all the information is given to you by your friend and will come in this format):
C: change-to-server-ip.dyndns.biz 12000 userfree satfreek
1: Your server’s dns ip: change-to-server-ip.dyndns.biz
2: Your server’s CCcam Listen Port: 12000
3: Your server’s CCcam User: userfree
4: Your server’s CCcam Password: satfreek
So most of the time you just copy the C line sent by server, and paste it in the CCcam.cfg.
7. Adding a Peer (people you are going to give cards to) to your CCcam
If you are sharing it is usually two way. You give your cards and the other person gives you his cards. So you need to allow the server to connect to your CCcam. You will need to set up an F line to enable your Friend to connect to your server.
This is the information you need to set up a basic F line (you decide all the information to set up in this format):
F: proton mazzuti
1: User: proton
2: Password: mazzuti
F: proton mazzuti
Please note that every user needs a different user and password.
Now just put the two lines in the CCcam.cfg file, save and restart CCcam from dreambox.
8. C line for your Peer
Now you need to give the information in point 7 above to your peer/friend:
1: Your dns ip: change-to-your-ip.dyndns.biz
2: Your CCcam Listen Port: 12000
3: Your CCcam User: proton
4: Your CCcam Password: mazzuti
C: change-to-your-ip.dyndns.biz 12000 proton mazzuti
9. Port Forwarding
Make sure you forward port 12000 to your dreambox ip, and also to allow your dreambox to access the ports given by servers.
CCcam Basic Tutorial – Part 2
1.To exclude known fake and old cards you have to insert this line after the password of each single Cline:
no {002, , 100:3, 100:4, 100:5, 100:9, 100:c, 100, 100:f, 100:10, 100:11, 100:12, 100:19, 100:1c, 100:1d, 100:21, 100:25, 100:26, 100:31, 100:33, 100:34, 100:37, 100:64, 100:66, 100:67, 100:6b, 100:6d, 100:70, 100:71, 100:72, 100:73, 100:100, 100:8227, 100:beef, 100:ffff, 500:80, 500:500, 500:1570, 500:2100, 500:2500, 500:5500, 500:7000, 500:8000, 500:8c00, 500:8c10, 500:9c00, 500:a000, 500:c400, 500:c410, 500:e400, 500:10c00, 500:10c10, 500:10c20, 500:10c30, 500:11c00, 500:15000, 500:16400, 500:16800, 500:16810, 500:18c00, 500:19410, 500:1a400, 500:1ac00, 500:20a10, 500:20a20, 500:20a30, 500:20c00, 500:20c10, 500:20c20, 500:21510, 500:21570, 500:21c00, 500:22100, 500:22110, 500:50000, d00:4, d00:8, d00:14, d0c:c, d0c:10, d0c:14, d0c:18, d01:50, d01:54, d02:8c, d03:c8, d05:c, 1702:6a, 1800:4101, 1800:4901, 1800:7001, 1800:7101, 1800:7401, 1800:7501, 4a60:0, 4aa0:0 }
-The ‘no’
The 'no' means that you will not take EMM (Emu’s) from your peers. CCcam can do its own EMM work if you add a recent Autoroll.key and Softcam.key in the var/keys folder. Change to ‘yes’ if you want to receive peer’s emu.
-The ‘002’
The 002 means that you will only receive cards at a Hop 2 from your peers. Just decide how many Hops away you want to receive (1,2,3,4,5)
The rest will eliminate all known old and fake cards from your server.
2. You have to insert the following after the password of each F:line
2 0 0 { 0 0 3 } { } { } change-peer-ip.dns.org
-The 2 0 0
The 2 means that the peer will get all cards at a maximum of 2 hops away from you.
The first 0 means that the peer gets no emus from you.* Change to 1 to get peer’s emu.
The other 0 means that the peer is not allowed to send us emm. Change to 1 to take peer’s emu. Please note that there has to be a corresponding entry in the in the server you are sharing with.
-The { 0 0 3 }
The 3 means that the peer can share your cards down two further levels beyond his own level. (If you have servers who are not allowing you any reshare, you should change this number to 0 or 1)
-The IP or DNS address at the end of the F line
The IP Address at the end of the F:line makes sure that only the specified peer connects to your server. This may prove very useful with hackers!
-Restricting shares
If you want to restrict what your peers get, you have to configure your peer's F line to which you want to block a card in the following manner. The following example restricts Canal+ Digitaal Nederland (19E). You can change to whatever caid you want:
F: user pass 3 0 1 { 0 0 3, 0100:00006a } { 0100:00006a:07d4, 0100:00006a:07d5 } { } change-to-user's-ip
Therefore user will not be allowed to view Canal+ Digitaal Nederland (19E) (0100:00006a) but is allowed to view the following two channels on Canal+ Digitaal Nederland (19E): Rtl 4 (0100:00006a:07d4), Rtl 5 (0100:00006a:07d5)
If you want to allow him to view Canal+ Digitaal Nederland (19E) but not to share it you have to add a ‘:1’ :
F: user pass 3 0 1 { 0 0 3, 0100:00006a:1 } { } { } change-to-user's-ip
The above settings should work well with most servers.
