Am un dreambox 500 S cu gemini si cccam 2.011,posed un m.o.s.c si as vrea ca el sa nu mai poate primi trama , cum pot sa fac asta pe cccam.
Multumesc de ajutor
Multumesc de ajutor
Iata solutia, pentru cei ce vor sa stie cum se face:
dans CCcam.cfg
Code:
# configure what EMM blocker you want. Add as many as readers you have attached
# default is blocking nothing
# B: /dev/sci0 01
# 00 - nothing
# 01 - sa blocked
# 02 - ua blocked
# 04 - ga blocked
#and sum of for combinations << donc pour tout bloquer il faut mettre 07
#examples
#B: /dev/tts/0 07
#B: /dev/sci0 01
# disable all local EMM readers
# saves lots of CPU, but you won't get any updates anymore
# (unless you get updates from your clients)
# default: no
#DISABLE EMM : yes
# with this setting you can
# allow a client on two hops away
# to send the updates to the cardserver
# default : no
#EXTRA EMM LEVEL : yes bien entendu, pour que la line soit active il faut enlever le "#" :)
