E1 Remote All
The main remote controls we use today (there are others)
What difference do you see between these two remote?
- The difference in size
- The one of the left is for the DM600, DM7000, DM7020, DM7025, DM800
- The one of the right is for the DM500plus, DM56xx and the DM500 [Only registered and activated users can see links. Click Here To Register...]
- The features and functions on the remote controls are different
- The remote on the left has a video or record button the DM500 does not
- The remote on the left as a different volume buttons to the DM500
- The remote on the left has bouquets buttons the DM500 does not
Daily use
Changing Channels
- DM500 (the remote on the right above)
- Use the up and down arrows keys to change the channel or press the OK button twice to see the channel list
- All other models (the remote on the left above)
- Use the up and down arrows or the left and right arrows to change the channel
Selecting the Channels Lists
- press the OK button twice to see the channel list
Selecting bouquets
- Press the OK button twice to see the channel list and then the BLUE button to select the bouquets
- Use the bouquets button to select the bouquet you require
Changing the Volume
- Use the left and right arrows keys to change the volume
- Use the volume buttons to change the volume
Recording
- DM500, DM56x0, DM500+ users see below
- DM7025, DM800 - press the RED button
- DM600, DM7000, DM7020 - press the VIDEO button
The Help button on all remote control units is your friend!
On the 7025 & 800 you have interactive help screens (not shown here)
Here is a list of the functions on your remote control.
Howto access the Video button with the small silver remote above prior to Jade2
The video menus give you access to the record button and several others as shown below.
1. From the TV screen press the OK button so you see the OSD popup like this example below
2. Now press the Help button and the screen above will change to be like this;
3. To get more help press the help button again and these screen will provide you with all the commands
Tip: For this tip above to work you need to have the correct remote control unit defined in [Only registered and activated users can see links. Click Here To Register...]
Re: E1 Remote All
Howto access the Video button with the small silver remote with the Jade2 software
The video menus give you access to the record button and several others as shown below. But
before we can do this you have to select the remote control you have on your DM500. To do this
you have to ( [Only registered and activated users can see links. Click Here To Register...] )
1. Press the menu | setup | hardware | remote control selections
2. select silver remote
3. Go to TV screen
4. From the TV screen press the OK button so you see the OSD popup like this example below
5. Now press the Help button and the screen above will change to be like this;
6. To get more help press the help button again and these screen will provide you with all the commands
The VIDEO controls will NOT appear until you select the correct remote control (Silver)
WARNING: By making this selection of the silver remote your WEBIF remote may not work correctly
Tip: press the RED button to see the Electronic Programme Guide (EPG)
Tip: To assign new functions to your Yellow and Blue buttons, [Only registered and activated users can see links. Click Here To Register...]
Tip: The old blue button for softcams and downloads is still there but in a different layout [Only registered and activated users can see links. Click Here To Register...]
Tip: The old PPanels menu is now under the "yellow" button [Only registered and activated users can see links. Click Here To Register...]
Tip: a DM500+, DM600, DM7000, DM7020 [Only registered and activated users can see links. Click Here To Register...] will now work on your DM500 ..
Accessing the remote control function from your desktop
By [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
Using the Windows operation system, I needed to send remote control
codes/presses via the LAN to control the Dreambox:
1. Download WGET for Windows and place it in C:\ (google is your friend)
2. Lunch a command prompt window (CMD) and type:
C:\wget.exe –quiet –delete-after [Only registered and activated users can see links. Click Here To Register...][Only registered and activated users can see links. Click Here To Register...]
(where ipofyourdmbox might = 192.168.1.3)
By replacing X with the correct code number,
the wget command will send a remote control
key press/code to the Dreambox. The flag –quite will make the
command silent, and –delete-after will make wget not write any files to C:\
Here is a list of remote command codes:
116=Power
2=1
3=2
4=3
5=4
6=5
7=6
8=7
9=8
10=9
158=previous
11=0
159=next
115=volume up
113=mute
402=bouquet up
114=volume down
1=lame
403=bouquet down
358=info
103=up
141=dream
105=left
352=OK
106=right
392=audio
108=down
393=video
398=red
399=green
400=yellow
401=blue
385=tv
377=radio
66=text
138=help
The above method can be used in many situations, but the way I use it
is with IR Server Suite to control my Dreambox from a different room using Media Center PC.
