How to use NetworkBrowser Nabilo BH V 0.9
How to use NetworkBrowser Nabilo BH V 0.9 and share DISK with share name d
Example :
1 .Config first your share disk on PC (picture 2 diskd3.jpg is final mount result after all configs and mount with dreambox)
For PC config windows XP SP3 (I m not using password in XP)
use only pic 1 (diskd.jpg) and 3 (diskd3.jpg)
(you can try similar configuration on other OS)
2 .follow my pictures starting with shot1.jpg for dreambox share/mount config
[Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...] [Only registered and activated users can see links. Click Here To Register...]
Re: How to use NetworkBrowser Nabilo BH V 0.9
Final mount result in Media Player File list .
For you info
mount file with all your mounts you can find in BH V 0.9
in /etc/enigma2/automounts.xml
If you have problems with MountManager and NetworkBrowser you can remove this file
restart box and start agn with NetworkBrowser/MountManager.You can also edit this file.
To Make the Story Complete .
Some info about Cifs Mount for Recording .
For Cifs mount for recording we have to mount some folder on our PC
this folder we have to share on the same way we share disk .
(config on PC is the same config for firewall is the same)
in this share folder we have to make subfolder movie for recording.
Mount with NetworkBrowser and MountManager
you cannot use for Recording.
Mount point for this mount is /media/net/....
and Mount point for Cifs recording folder is /media/hdd and folder on PC
with subfolder movie.
For Recording mount we can use Nabilo Mount system
blue button>>blue button>>Nabilo Mount Wizard>>Wizard Cifs>>Continu>>
Config you recording mount in this panel (put info abt your IP and shared folder name on your pc and name of local dreambox directory and this directory is /media/hdd for cifs recording and SAVE.)
Now we can have both mounts
Cifs for recording and Cifs for Network .
On my picture you can see LEFT Recording mount I have make
with Nabilo Mount Wizard
and on the right mount I have make with NetworkBrowser and MountManager.
On the pic top we can see different paths to the same folders .
For info in my Cifs recording example i have shared folder on my PC with name hdd ,
and i have no password on my PC.
__________________________________________________ ____________________
But PLS if you make bad mount point for AUTO CIFS recording is possible you cannot start your image
then you have to start someanother image and edit BH fstab file remove bad mount point from fstab file.
fstab file you can find in /etc
